4K Sony VW 1000 first short Test - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Old 02-16-2012, 07:28 AM
coolscan's Avatar
Quoted: 18 Post(s)
Liked: 88
Originally Posted by mariner888 View Post
4k_QHD_RoastDuck_30p.mp4
Which camera is used for this clip?
coolscan is offline
Old 02-16-2012, 07:30 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
I would be interested in hearing how various ones of you are choosing for the iris (DI high or low) or Manual, and also Motion Flow (high, low, or off).
I use 'low' for Motion Flow but haven't really done a thorough study to decide if that's best for me.
For the iris, I find that the DI on 'high' is the brightest (same as having it fully open on Manual) for scenes with any significant light in them; and then when all the light disappears it shuts down very quickly. I don't think I care much for this. So I have been using the 'low' setting of the DI. And more recently I've been comparing this to Manual, set at ~ 20 to 30 (I have PLENTY of brightness to spare!); this gives very good black level and and avoids any DI effects.
And another combo I'm going to try is to move Contrast all the way up to 100 (now use 90 to 95), and close the Manual iris down even further. The idea would be to get even better CR and black level, but to keep the brightness and dynamism of the whites, i.e., to maximize the dynamic range.
Any thoughts from those of you that are more experienced would be interesting to hear!
millerwill is offline
Old 02-16-2012, 07:39 AM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
Originally Posted by DaveN View Post
Nothing like the good old CRT days when I had to rent a drywall lift to mount the projector.
Here we just was 3 people -but our arms was week 5 hours after ( and that was "only" a 8" CRT )
dj
d.j. is offline
mariner888's Avatar
Red.
mariner888 is offline
Old 02-16-2012, 08:24 AM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
Originally Posted by Oliver Klohs View Post
Yes exactly - colors were almost spot on, too and better than with the previous unit in cinema 1 mode where I needed to dial down green.
Oliver and others
I dont get this it shouldnt matter what preset you start with - if you calibrate it for max light output at D65 ( where the red probely will be the limiting factor for how high you can adjust it, before clipping ) all the presets should end up outputing the same amount off light !? ( or there must be something other, in the different presets, who restricts the bulbs RGB light output !? - can that be the case ?)
BTW. this is offcause with all other settings at the same - ( color gamut, gamma, iris etc. ) and no extra filters inserted ( like the DCI green filter )
dj
d.j. is offline
Old 02-16-2012, 09:16 AM
lovingdvd's Avatar
Quoted: 2226 Post(s)
Liked: 360
A few thoughts:
1) Regarding MotionFlow - assuming its like the VW95 - for sports, I use it all the time on Low (I haven't noticed much benefit to using it on High under any type of viewing, except for 3D in which case I always use it on High regardless of the content). For TV shows I usually use it on Low too.
For movies I usually will start off in Low but if I find it distracting because of the SOE or artifacts (it causes flickering in certain fine materials/patterns) then I switch it off. A good example of this was the movie Blackthorn. Normally the SOE is very slight and doesn't bother me, but with this movie it just made it feel fake - like I was sitting by the stage watching them film it rather than watching the movie.
2) Regarding boosting contrast - I would not recommend this unless you know for certain that a) you will not crush 235, and b) you will not create a noticeably color shift at the top end. Some folks have reported here that with the 1000 they could push contrast so something may be different compared to the 95 here. In my case I cannot go over 89 without crushing 235.
I can't remember if you have a meter and software. If you do it'll be easy to figure out what increasing contrast does to D65 at 100%. If you don't then I suggest this:
- put up a gray bars pattern that has 5% steps and check out what the bars at 90, 95 and 100 look like with your normal contrast setting. Then start increasing it and observe these bars. If at any point the 95% bar starts to disappear, or any of these bars starts to shift in color (such as pinkish) then reduce contrast back to the point just before where that starts to happen. This then is the maximum contrast setting to even consider, but still may be too high. So then you need to do part 2 of the test, which is to put up the blinking bars contrast pattern on the AVS HD 709 pattern disc and make sure you can see bar 234 blinking. It you can, then you are at the maximum contrast. If you can't, back the contrast down until you can barely see 234 blinking. Then you have reached the maximum that you can push contrast without introducing issues.
3) Try running in High lamp mode with the manual iris fully closed. This most likely is best configuration for maximizing native CR. I would use this at times on my 95, but it results in half the brightness compared to using the auto iris so its a no-go for me. But if you have plenty of brightness to spare it could work out. Give it a try and see what you think - I'm curious to know how you like it.
lovingdvd is offline
Old 02-16-2012, 09:19 AM
thrang's Avatar
Quoted: 1613 Post(s)
Liked: 1387
Originally Posted by lovingdvd View Post
I would use this at times on my 1000...
Ric, you got a 1000 or you meant to say 95...?
thrang is online now
Old 02-16-2012, 09:43 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
A few thoughts:
3) Try running in High lamp mode with the manual iris fully closed. This most likely is best configuration for maximizing native CR. I would use this at times on my 1000, but it results in half the brightness compared to using the auto iris so its a no-go for me. But if you have plenty of brightness to spare it could work out. Give it a try and see what you think - I'm curious to know how you like it.
Thanks very much for these insights, Ric. I think the 1000 does behave in many ways as the 95, though of course not in all. Re Contrast, with the Spears&Munsil disk (my standard), all the white bars just up to and slightly past 235 are clearly visible even at Cst set at 100. [This is consistent with W. Mayer's report that the 1000 does not clip whites with Cst up to 100.] Tom Huffman, though, noted that he got better colors (more uniform?) with it at 90; with Cst at 90 I see the white bars on M&S up to 245 or more. Good idea to check out the grayscale pattern for any color changes wit Cst above 90.
Re brightness, I'll try high lamp with Manual iris fully closed to see how it looks. With my RS20 I most recently used high lamp and iris fully OPEN since the lamp (with many hrs on it) had gotten down to something like 300-350 lumens.
Old 02-16-2012, 09:55 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
On my two units, with IRIS off, contrast starts to clip 253 at about 86. With IRIS on full auto, changing contrast does not affect clipping. No changing of contrast in any setting ever allows 254 or above to be visible.
(Reference mode, d65, rec 709, reality creation ON)
hifiaudio2 is offline
Old 02-16-2012, 10:00 AM
lovingdvd's Avatar
Liked: 360
Edited. Would be nice, although likely overkill for my room with smallish (106") screen and 2x viewing distance.
Old 02-16-2012, 10:19 AM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
Hey guys, I checked the Mack Camera lamp replacement warranty, and they allow 2 lamp replacements over a 3-yr period for $125! I got such a warranty for my RS1 and my RS20(through Texas Tape Works) and did indeed get 2 lamps for each over the time I had them. Can they really offer this for the VW1000 lamp? Seems like a no-brainer.
Old 02-16-2012, 10:45 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
I emailed and asked the same a few weeks back. Tapeworks told me it is definitely valid for this projector. (Of course I kept the emails) . They said it doesnt matter the cost of the bulb.
Old 02-16-2012, 10:47 AM
thrang's Avatar
Liked: 1387
Freud might say that subliminally, you've already made the decision to upgrade...!
Old 02-16-2012, 11:02 AM
samalmoe's Avatar
beach camera has the mack for 75$!!
samalmoe is offline
Old 02-16-2012, 11:06 AM
Oliver Klohs's Avatar
Quoted: 40 Post(s)
Originally Posted by d.j. View Post
Oliver and others
dj
This is how it should be. Most projector manufacturers don't seem to work with their presets like that, certainly Sony and JVC don't..
I have my own opinions as to how I would go about a memory system for a projector like the Sony, but that does not change the fact that we have to work with how it is now.
Oliver Klohs is offline
Old 02-16-2012, 11:10 AM
Quoted: 40 Post(s)
Looks delicious
Are there any exterior shots where these came from?
Old 02-16-2012, 11:38 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Do you have a link? I cant find it on the beach site.
Old 02-16-2012, 01:00 PM
samalmoe's Avatar
samalmoe is offline
Old 02-16-2012, 01:23 PM
DaveN's Avatar
Quoted: 70 Post(s)
I have had the Mack bulb warranty but it had to be purchased with a projector warranty also. The bulb warranty is cheap but I can't find a site that lists a PJ warranty from them for a projector costing above $10,000.
It appears now that you can get the bulb warranty alone. I used it once for my Ruby. It took a very long time to get the paperwork processed and get a check from Mack but they did come through in the end. It really is a great deal.
DaveN is offline
Old 02-16-2012, 01:33 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
I had it on my RS20. I filled out the paperwork and had a new bulb at my house from them in 4-5 days. They just sent it to me, I didnt get reimbursed.
Old 02-16-2012, 02:14 PM
Gradius2's Avatar
Quoted: 20 Post(s)
Is interesting to see they are still using HDMI (even if is 1.4a).
To me the real future will be HDBaseT (IMHO):
http://hdbaset.org
Is coming like fire in this year (I hope).
[]s,
Fernando
Gradius2 is offline
Old 02-16-2012, 02:17 PM
Gradius2's Avatar
Quoted: 20 Post(s)
Looks delicious
Is from Taiwan forum, is restrict to "VIP" users, this was the only 4K video available to the public there.
Here you go:
http://www.hd.club.tw/thread-112837-1-1.html
Oh yes, and chinese only.
[]s,
Fernando
Gradius2 is offline
Old 02-16-2012, 03:05 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
What does the high/middle/low black level adjustment do?
Old 02-16-2012, 03:18 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
And Mark you are saying that to use the full panel we select the 2:35 zoom setting and then just size it to whatever aspect we need?
Old 02-16-2012, 05:39 PM
OzHDHT's Avatar
Quoted: 791 Post(s)
Liked: 418
Originally Posted by HoustonHoyaFan View Post
Next to a VW95 from Cine4Home.de
I'll trump that view with front and slightly above, plus a side one I took yest. They are iphone so not perfectly sharp:
OzHDHT is online now
Old 02-16-2012, 06:14 PM
Quoted: 40 Post(s)
Here you go:
Thanks, seems they are really enthusiastic about 4k!
Old 02-16-2012, 06:34 PM
OzHDHT's Avatar
Quoted: 791 Post(s)
Liked: 418
I just got my HIS Radeon 7950 today. So time to hit the 4k clips tonight I'd say and also have go at 4k HTPC general output with various formats. Be also kind of interesting to see how sharp a 4k windows desktop looks on the VW1000 out of curiosity vs the 'basic' 1080p upscaled one I was looking at last night.
Old 02-16-2012, 06:50 PM
AV Science Sales 4's Avatar
The native panel is 1.89. If ypu are watching a movie with an aspect ratio higher than 1.89, providing your screen is of an aspect ratio of higher than 1.89, you should set the aspect control on the Sony from Normal to 2.35 Zoom. You can then zoom your projector to get the black bars off screen and to fill the width of ypur scope screen. You can zoom or not zoom, it really makes no difference to what the panel is doing or to pixel use on the panels. If you keep the projector aspect at Normal. you will never be using full panel width. Your machine will act as it only has 1.78 panels with black side bars filling the width between 1.89 and 1.78. There is one exception. If you put up the zoom etc test pattern you will light the whole 1.89 chip. Alsao you have the choice of setting the aspect to 1.85 Zoom. The machine then will act like its panels are 1.85 aspect (useful for 1.85 aspect sources) and have onlky a few lines of black pixels on the sides.
AV Science Sales 4 is offline
Old 02-16-2012, 09:34 PM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
Dave, where are you getting that it is now allowed to purchase the bulb warranty alone? Right there on Beach Camera's site is a review by somebody who got burnt. I have no need for the extended warranty that I know of with this PJ because I get 3 years from Sony and an additional year from AmEx.
And just because it might have worked for some of you in the past, what guarantee is there they will honor it in the future?
Not that $75 isn't worth it, but I hate ambiguity with warranties.
EDIT: The FAQ from Texas Tape Works indicates this is true. I bought from them before, but Beach Camera is a little too much cheaper this time around:
http://www.tapeworkstexas.com/extend...-3yr-bulb.html
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
Old 02-16-2012, 09:40 PM
mariner888's Avatar
Looks delicious
Filmed at the Taipei Silks Palace.
