4K Sony VW 1000 first short Test - Page 22 - AVS Forum | Home Theater Discussions And Reviews
Old 02-19-2012, 01:37 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 263
Originally Posted by millerwill View Post
I would be very interested to hear what other VW1000 owners think about this choice: with a 16x9 source (i.e., HDTV) do you prefer to use 'Normal' aspect and thus get the std 16x9 pic, or do you prefer to use '2.35 Zoom' aspect and see a larger pic but with a small amount of the top and bottom of the 16x9 pic lost? (In switching from 'Normal' to '2.35 Zoom' the pic ht stays the same and it get a bit wider.)
Looking a lot last night and today, I'm leaning toward going to '2.35 Zoom' aspect for 16x9 input (as well as BD). Yes, i loose ~ 5% of the vertical pic, but that is hardly noticeable. And I get a larger pic.
To summarize: for my case, with a 16x9 signal I have a 17x9 pic that is 72"Hx136"W; a 16x9 pic that is 136"W would be 76"H, so I'm loosing 4" in ht from the 16x9 pic. For 2.35 pic (BD) I have a 144x60-62"H (depending of 2.35, 2.40, etc). So I use '2.35 Zoom' aspect for both 16x9 (HDTV) and 2.35 (BD) sources. Sweet.
millerwill is offline
Old 02-19-2012, 01:47 PM
sytech's Avatar
Quoted: 2000 Post(s)
Liked: 1411
Don't know if this has been posted before, but here are 2160p video samples to download for those of you capable of playing them with your computer and new Sony 4K projector.
http://xhmikosr.1f0.de/index.php?fol...xlcy8yMTYwcA==
DON'T ARGUE WITH ME. I AM NEVER WONG.
sytech is offline
Old 02-19-2012, 02:21 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
I was doing a very quick first calibration with calman and have a question. When I calibrated the RS20 it was posted everywhere not to raise offset (bias on the 1000), and GAIN had no ability to move it higher than 0. This projector starts both sliders in the middle at 0 and we can raise or lower gain and bias.
So, is there any reason NOT to raise bias or gain if Calman is telling me to? On the rs20 raising offset significantly raised the black floor. Is that projector dependent and not necessarily the right instructions for each PJ? Calman told me to raise my bias by 3-7 pts for each color (which isnt a ton).
By the way, I dont think I lost much top end brightness at all after the calibration...
I also, for the first time, blew up the picture in 2:35 mode so that it would be the size of my future EN4k screen (160"w scope) and measured the EN4k sample in the middle of the screen..... 15 ftL! I am happy with that and its as much or slightly more than I expected. That is calibrated, with all my settings that I posted in my lumen measurement post. Black level still on off. Once I actually get the screen I will experiment with black level on low, high, etc to see if I like the effect.
Once again, reality creation on or off did not change my brightness.
hifiaudio2 is offline
Old 02-20-2012, 10:03 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 939
Keep pondering minds informed of your outcome............looking forward to your analysis.
In a quandary regarding projector and screen material. Thought I was settled on Runco LS-10i, but then the LS-12 has transpired. Now this new 4k Sony has my head spinning.........
Same is true regarding screen material.........thought I was settled on SE Enlightor 4k material, but now wondering if a microperfed Stewart ST-130 would be better choice due to light output.......assuming I go Sony 1000.
But then again..........pixel structure with a perf screen would defeat the purpose of a 4k projector.........go figure.
Decisions............decisions..........
doublewing11 is offline
Old 02-20-2012, 11:12 AM
lovingdvd's Avatar
Quoted: 2220 Post(s)
Liked: 360
Dealing with offsets is a rather deep and complex matter. The short of it is that it may be useful in combination with the Brightness control or in isolation to get the proper response at video level 17. I would not increase offset except for that specific purpose. Though you may get results without jeopardizing much by reducing the other 2 colors instead of raising the one color. But be prepared to rebalance with Brightness. It is very delicate to get the optimal results. And yes this varies by pj make/model - what applies to JVC may not apply to the Sony.
lovingdvd is offline
Old 02-20-2012, 11:13 AM
lovingdvd's Avatar
Liked: 360
Bill - great story! That is classic.
Yes, I have used Mark in the past prior to his joining AVS and agree he goes above and beyond. AVS is lucky to have him.
Old 02-20-2012, 11:44 AM
Lawguy's Avatar
I spoke with Mark a few weeks ago and he revealed the plan to ship the PJ as a carry-on. I expressed some surprise at doing this. Mark was not phased. Very matter of factly, he said something like "There's no problem. We'll protect the lens with a towel." I was like "Oh, as long as you've got a towel . . . "
Classic.
Affable Nitwit
Lawguy is offline
Old 02-20-2012, 12:43 PM
AV Science Sales 4's Avatar
Its already protected by a plastic automated door in front of the lens. The towel was more to protect the case finish. It really worked well.
AV Science Sales 4 is offline
Old 02-20-2012, 01:48 PM
JustMike's Avatar
Quoted: 57 Post(s)
Liked: 54
Classic.
Hitchiker's Guide was right...
Mike Kobb
(Formerly "ReplayMike". These opinions are mine alone, and in no way reflect the opinions of employers past or present!)
"Mike's Money Pit" Build Thread
JustMike is offline
Old 02-21-2012, 08:59 AM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
I told you not to give up on the 160" , glad your findings seem to confirm that! With the Carlton Bale spreadsheet, somewhat optimistic on lumens after some bulb age (1200), and and using .86 gain for a realistic guess on EN4k, I get 13.8 ftL. That's the latest worst-case numbers I have been using, but I'm kind of stuck now since the Sony is here sitting in the box (I unboxed but haven't put up the bedsheet yet to test, still under construction here), and the 160" EN4k showing up within the next week or two...
Matt
UMR on HDR vs 4K: The benefit of greater saturation and luminance capability is...not very evident in all images unlike more pixels which can be seen in every scene.
turls is offline
Old 02-21-2012, 09:16 AM
adidino's Avatar
Quoted: 326 Post(s)
Liked: 258
Curious what the bedsheet will tell you? Is it just a reference for size or is the ENk4 comparable to a bed sheet for brightness?
adidino is offline
Old 02-21-2012, 10:08 AM
lovingdvd's Avatar
Liked: 360
Classic.
Thanks for the best AVS laugh I've had in a long time.
Old 02-21-2012, 10:17 AM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
This is a new theater room. The screen wall is not built and the current front wall is covered with black InsulShield. It will tell me little to nothing except that I have a working projector or not, but I do have both EN4k, EN2k, and SmX samples I can put up as well. Just have to get the contractors out of there and quit grinding concrete long enough to want to turn the thing on...
Matt
turls is offline
Old 02-22-2012, 12:00 PM
Gradius2's Avatar
Quoted: 20 Post(s)
Please, let us know which screen was better: EN2K, EN4K or SmX and why?
I read a bit about SmX 4K as well, but so far nothing confirmed (rumors says is almost the same thing as standard SmX).
[]s,
Fernando
Gradius2 is offline
Old 02-22-2012, 01:06 PM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
hifiaudio2
Do you have a EN4K now ? ...and are you happy with it ?
Im testing one piece of it now versus my old Studiotek 130 microperf and for now, I have to say that the tek 130 looks sharper, but it can probely be the gain who cheats me - the 4K is dimmer, softer looking, but it dosnt moire, wich my Tek do and I can just see the micrperf at my distance, but not on the 4K
dj
Edit: reread you reply, and you do write SAMPLE - sorry , but then again what´s your impression for now ?
d.j. is offline
Old 02-22-2012, 01:12 PM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
For now - just a fast test - the bedsheet has a better gain then the 4K
dj
d.j. is offline
Old 02-22-2012, 01:40 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Originally Posted by d.j. View Post
hifiaudio2
dj
Yeah its only a sample for now. Up close, the high power its right next to is sharper.. thats to be expected though. Backing up a few feet (lets say 6 feet just to be conservative and not understate) they both look about the same on sharpness. I cannot see the weave past about that same distance. With a non 100 ire screen I cant see the weave much at any distance except maybe a foot from it. Certainly not with program material.
Old 02-22-2012, 02:05 PM
DigsMovies's Avatar
Quoted: 34 Post(s)
Liked: 57
hifiaudio2
dj
What distance does the microperf disappear on the StudioTek?
-Thanks
DigsMovies is offline
Old 02-22-2012, 02:13 PM
Mike Garrett's Avatar
Quoted: 5612 Post(s)
Liked: 3593
Keep in mind that dust will be floating around in that room for several days.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 02-22-2012, 02:52 PM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
I took a picture, but it won't tell much (I haven't got it pulled off of my camera yet). Plus I had the bed sheet as a background which probably doesn't help. They all looked very similar to me from far back, the only one noticeably brighter was the EN2k.
Very inconclusive testing.
Matt
turls is offline
Old 02-22-2012, 02:54 PM
turls's Avatar
Quoted: 466 Post(s)
Liked: 196
Good point, luckily that wasn't the actual room where most of the dust was being generated.
Matt
turls is offline
Old 02-23-2012, 08:49 AM
d.j.'s Avatar
Quoted: 167 Post(s)
Liked: 73
-Thanks
About 8 - 10 feet depending how god your eyes is
dj
d.j. is offline
Old 02-23-2012, 08:58 AM
adidino's Avatar
Quoted: 326 Post(s)
Liked: 258
Guys,
I would like to propose we ask Wolfgang if he is ok with closing this thread and renaming Lawguy's thread the official VW1000 Owner's thread. We could add a link to this thread on the owner's thread for reference.
It would make it much easier to have one thread on the VW1000.
We would need Wolfgang's permission for the admins to close it and LawGuy to rename his thread. Or the reverse. Close Lawguy's and rename this one. As long as we have one Owner's thread.
Is everyone ok with this? I'll reach to one of the mods if we have are in agreement.
adidino is offline
Old 02-23-2012, 10:34 AM
pilotb777's Avatar
What is the best Ceiling Mount for this projector
pilotb777 is offline
Old 02-23-2012, 10:45 AM
adidino's Avatar
Quoted: 326 Post(s)
Liked: 258
Chief with the Sony plate
adidino is offline
Old 02-23-2012, 11:00 AM
pilotb777's Avatar
Do you have model number
Old 02-23-2012, 11:22 AM
adidino's Avatar
Quoted: 326 Post(s)
Liked: 258
I need to look at the box when I get home. I didn't end up using it since I decided to shelf mount it in my equipment closet.
adidino is offline
Old 02-23-2012, 11:41 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
It looks like an ISCO 4XL.
That is the Isco IIIL not the 4XL
EDIT: After seeing the right side of the lens, I see this is a 1.25x lens, not the IIIL.
GetGray is offline
Old 02-23-2012, 11:58 AM - Thread Starter
W.Mayer's Avatar
Quoted: 220 Post(s)
Liked: 266
the tread was for some very first pictures and measurement and first impressions.
i am ok to close this tread but put a link in the new thread inside.
i like the sony vw 1000 a lot and i will together with the 1,25 anamorphic lens use it only for all what is 2d.
all tv sports and so on as well bds in 2d.
i will leave always the anamorphic lens inside and just switch with the
aspect ratio bottom from the pr. between scope and flat.
that makes it very easy for me.
i have with the lamp at 38 hours 10,6 center ftl for both formats at my huge screen.
very likely i have to change my lamp every 500-600 hours to keep the high lumen out the pr.have.
i can not live anymore with under 8 ftl.
i will measure my lamp again after around 50/100 hours to see how much the light decrease will be.
than i can change the location from both 3d infitec filters from outside the optic my 2 barco 4k dlps have to
inside the optic and this will increase the 3d performance.
it was my original plan to have a only 2d pr. system and one that only run 3d and i will do this now.
the only bad thing was that i give a up to see 2d bds with less ftl i lately like but i take this trade off as the other advantages are bigger.
wolfgang
W.Mayer is offline
Old 02-23-2012, 11:59 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Guys,
agreed
