Projector for huge screen in local alternative cinema? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2012, 01:25 AM - Thread Starter
tolpol's Avatar
Hello everyone,
A local alternative cinema is looking for a not-too-costly digital projector to replace its ancient 4:3 beamer. It's a place run by volunteers and budget is limited to around US$10,000-12,000. The place mainly shows 35mm vintage prints, but there's need for a better digital option since more and more distributors offer solely digital versions of their catalogue titles, often on digibeta, sometimes blu-ray.
The screen has a width of 8.4 metres (27.6 ft) and height of 3.9 metres (12.80 ft) - the projector has to be placed 10 metres (33 ft) from the screen. The place is completely light-controlled, obviously.
Can anyone share some tips when it comes to models within the budget range - with enough lumen to cope with a huge screen and a usable placement option for the stated range of 10 metres?
tolpol is offline
post #2 of 3 Old 02-09-2012, 01:59 AM
Grubert's Avatar
Here is a recent thread by someone with similar requirements:
http://www.avsforum.com/avs-vb/showthread.php?t=1387565
You may have problems with placement though - not many projectors have a 1.1x throw ratio. You may get around that with an anamorphic lens, especially considering that you have a scope-ratioed screen to begin with. A horizontal-expand lens would shorten the throw and give you some extra brightness. Have a look in the 2.35:1 Constant Image Height Chat.
Freedom is the freedom to say that two plus two make four. If that is granted, all else follows.
-George Orwell, Nineteen Eighty-Four
Grubert is offline
post #3 of 3 Old 02-09-2012, 01:00 PM
donaldk's Avatar
Quoted: 418 Post(s)
Liked: 86
The Single chip DLP from Sanyo/Eiki/Christie, first generation is also available from Vivitek. 6K lumens max. Sharp and bright from the single review in the 20K+ forum. Yeah list was 2K plus 2K for lens, but it ended up going around 12K. So right in your budget.
donaldk is offline
