Help me spend $5000! Photos + details inside. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 02-21-2012, 10:53 AM - Thread Starter
Patrick G's Avatar
Originally Posted by stanger89 View Post
Do you actually have anything that supports Deep Color? Blu-ray doesn't, nor do any other consumer video sources.
I'm not worried about today, I'm worried about tomorrow. I'm worried that once I get the cables in the wall, they are there to stay, given the length and contour of the run. So, I need to be sure whatever I put in is going to support 4K + Deep Color.
Patrick G is offline
Old 02-21-2012, 01:06 PM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Whatever you run, be sure to put some cat 6 (probably 2 lines just in case) in there with it. Some current and many future projectors will allow a RJ45 network connection for various control, firmware update, and automation features, AND you might get lucky and HDbaseT catch on and that cable serve as your video connection. Of course if you go with one of the extenders you will already be using Cat5/6.
hifiaudio2 is offline
Old 02-21-2012, 10:17 PM
Buttabean's Avatar
Liked: 29
http://www.siliconimage.com/products...t.aspx?pid=205
is there any hdmi chips out now that support deep color at 4k? It seems like 1080p is the cut off. This is only one chipset. What others are there?
If there isn't, it seems like a waste of money spending a lot on a hdmi extender. Buy one that's relatively cheap that does 1080p and forget about 4k and deep color. Worry about that when you go and buy a 4k projector. My understanding the JVC won't even take 4k content, right?
4k content seems like at least 5 years down the road. Can dual cat 6 cables handle the bandwidth of 4k? It looks like a single cat 6 and cat 6a can do 10gbit/sec so it's the same speed as hdmi 1.3 and above
http://en.wikipedia.org/wiki/10GBASE-T#10GBASE-T
* http://en.wikipedia.org/wiki/HDMI#Version_1.4
Sounds like an extender is the way to go.
If you MUST have deep color this one says it supports it
http://www.hdtvsupply.com/hdmi-14-cat5.html interesting that it will only do 36bit not 48bit deep color.
*36-bit support is mandatory for Deep Color-compatible consumer electronic devices, with 48-bit support being optional.
Joe.T
Buttabean is offline
Old 02-21-2012, 10:40 PM
Buttabean's Avatar
Liked: 29
Old 02-24-2012, 07:35 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Old 02-24-2012, 07:40 AM - Thread Starter
Patrick G's Avatar
Originally Posted by hifiaudio2 View Post
Was this already mentioned? Not too pricey...
http://www.audioholics.com/news/indu...re-active-hdmi
Oh man, that is EXACTLY what I need! Wonder how soon it will be available.
Old 02-24-2012, 08:11 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Article said 1st quarter availability. Call Monoprice and see if they know.
Old 02-24-2012, 08:12 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Still run the cat 6--- super cheap and I think one day you will be glad you did.
