SHARP 9000 Turn on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-02-2012, 02:41 PM - Thread Starter
sentryman's Avatar
I just replaced the Lamp in my 9000 and after plugging the PJ back and pressing the on/reset buttons the 2 red lights came on.
However I am still not able to actually turn the PJ ON.
Any ideas what's wrong?
sentryman is offline
post #2 of 5 Old 03-02-2012, 06:14 PM
G-Rex's Avatar
Quoted: 442 Post(s)
Liked: 269
If you bought a new lamp with a new housing, I would start by removing the lamp housing...then reseat it. Nice projector I owned one for quite a while.
G-Rex is offline
post #3 of 5 Old 03-03-2012, 12:13 PM - Thread Starter
sentryman's Avatar
Thanks. I'll try it again.
Jim
post #4 of 5 Old 03-05-2012, 02:11 AM
mpyw's Avatar
Quoted: 46 Post(s)
You need to hold down the "Enter", "Down" & "right" button and press the "ON" for reseting after replacing the lamp.
it's on page E-48 of the manual.
btw, I've just change my Z9000 to a Sony HW30ES, night & day different!
To be or NOT to be......YOU are WHO you ARE
mpyw is offline
post #5 of 5 Old 03-05-2012, 08:06 AM
Well also start at the basics... Make sure it was just a lamp and not another issue that it is having...
AV Science Sales 3 is offline
