5 pin mini din m/m - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-05-2012, 10:43 PM - Thread Starter
juandyx's Avatar
Hello and first of all i'm sorry if i'm posting in the wrong section , i'm looking to buy a 5pin mini din cable m/m , 50 to 75ft long for my HC9000D projector emitter , i've looked everywhere on the net with no luck , can somebody please point for me where i could buy this? thanks
juandyx is offline
post #2 of 4 Old 03-06-2012, 07:51 AM
I cannot say for sure there is not one made, but I doubt it. On many of my installs I have had to make one. The easiest method is run a CAT5/6 point to point, and take the cable included and cut/splice. As long as you keep the pinouts correct, it works aokay. The only real limitation is if the projector had a weak output (though I have not tried the Mitsu, I have not run into this issue...just wanted to present the possible option).
AV Science Sales 3 is offline
post #3 of 4 Old 03-06-2012, 08:43 AM
b curry's Avatar
Quoted: 317 Post(s)
Liked: 160
b curry is offline
post #4 of 4 Old 03-06-2012, 11:28 AM - Thread Starter
juandyx's Avatar
thanks to both of you guys
juandyx is offline
