How to calibrate and measure ft lamberts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-14-2012, 02:10 AM - Thread Starter
EJ
EJ's Avatar
Aside from an isf calibration, how do I measure the correct amount of light I'm throwing? First, I have a 1.0 gain screen. What image do I project, a 100 ire full-frame white field? Then, do I get a light meter and try to get close to the 16 ft lamberts recommend?
Former USSB uplink operator.
EJ is offline
post #2 of 13 Old 03-14-2012, 07:29 AM
schm66's Avatar
Quoted: 12 Post(s)
schm66 is offline
post #3 of 13 Old 03-14-2012, 07:39 AM
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Yep, use the instructions in the link given, or buy one of the versions of Calman or Chromapure with the i1 Display meter and the software will give you a ftL reading off your screen.
(I assumed by "aside from an ISF calibration" you meant paying someone else to come in and calibrate. )
hifiaudio2 is offline
post #4 of 13 Old 03-14-2012, 11:35 AM
AV Science Sales 4's Avatar
If you are using a light meter than reads out in lux, just put the meter at your screen center and aim it at the projector displaying a white full screen pattern filling your screen. Take the reading, multiply it by your screen gain and divide by 10.76. Since my screen gain is 1.0, all I need do is read the meter in lux and divide by 10.76.
AV Science Sales 4 is offline
post #5 of 13 Old 03-14-2012, 07:22 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
Most light meters allow you to read out in lux or fc (footcandles). If you switch to read the value (measured as you describe) in fc, then the lumen output of the projector is (# of fc)x(screen area in sq ft). The ftL coming off the screen is (# of fc)x(screen gain).
millerwill is offline
post #6 of 13 Old 06-11-2015, 03:29 PM
Quoted: 151 Post(s)
Liked: 31
I need some help from you people in figuring out the correct conversion from foot lambert to the equivalent lux.
Some say that 1 foot lambert is equivalent to 1 foot candle, others that 1 candela per square foot is Pi of 1 foot lambert.
1 foot candle is shown to be equivalent to 1 lumen per square foot and, since there're 10.76 square foot in 1 square meter, then 1 lumen per square foot is 10.76 lumen per square meter, which is equivalent to lux.
So, if I start from 14 foot lambert, I have to divide by Pi and multiply by 10.76 to obtain the lux equivalent of circa 48.
Is it correct?
Optimus_Fine is offline
post #7 of 13 Old 06-12-2015, 05:57 AM
stanger89's Avatar
Quoted: 2619 Post(s)
Liked: 1345
My research indicates what millerwill posted above, that on a unity gain screen, 1 Foot Candle = 1 Foot Lambert. Understand that they are different measurements though, fc is a measure of illuminance, ie the light illuminating a surface. fL is a unit of luminance, ie the light reflecting off a surface. If you know the real gain of your screen, then ftL = fc * gain, just beware that gain specification is usually not equal to the actual gain of the screen.
stanger89 is online now
post #8 of 13 Old 06-12-2015, 11:03 AM
Quoted: 151 Post(s)
Liked: 31
Problem is that I have a display and a lux meter, so I must know the exact ratio between foot lambert and lux. Some websites say that to convert candela per square meter to lux one must multiply by Pi, but if I measure maximum luminance possible (clipping whites), the value shown at the center of the screen is 380 lux, which, divided by Pi, would be 120 nit. But the same display has been measured at well over 300 nit in some websites.
So either a lux and a nit have the same energy or colorimeters give bogus numbers for luminance with 200% margin of error.
post #9 of 13 Old 06-12-2015, 11:21 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3028 Post(s)
Liked: 2957
My AEMC CA813 light meter does a better job - the i1 Display meter isn't as good for measuring foot lamberts. And, I compared my CA813 with a less expensive Dr Meter yesterday - the Dr measured much higher. I still think the CA813 is a better light meter.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #10 of 13 Old 06-12-2015, 12:01 PM
stanger89's Avatar
Liked: 1345
A fc is 10.76 lux. A fL is 1 fc (assuming unity gain screen). So your fL is 10.76 lux * gain.
post #11 of 13 Old 06-13-2015, 04:23 AM
Quoted: 151 Post(s)
Liked: 31
I've found the definition of foot-lambert:
foot-lambert
noun
1. a former unit of luminance equal to the luminance of a surface emitting or reflecting 1 lumen per square foot. A completely reflecting surface illuminated by 1 foot-candle has a luminance of 1 foot-lambert ft-L
Collins English Dictionary - Complete & Unabridged 2012 Digital Edition
© William Collins Sons & Co. Ltd. 1979, 1986 © HarperCollins
Publishers 1998, 2000, 2003, 2005, 2006, 2007, 2009, 2012
So, 14 foot-lambert is the luminance of 14 lumen per square foot, which multiplied by the ratio to a square meter, gives circa 151 lux.
post #12 of 13 Old 06-16-2015, 03:04 PM
Quoted: 151 Post(s)
Liked: 31
I've found out that, to meaure 48 cd/m2 in lux from a direct view screen, one must divide 48 cd/m2 by the distance squared from screen to photo diode facing the screen (for an easy conversion) of 1 meter which gives 48 lux, then multiply by the screen area in m2 of the 100% white window and that will be the lux reading the meter must report.
post #13 of 13 Old 12-18-2015, 09:19 AM
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Do you know much about the i1 Display 3 and how accurate it is for luminance measurements? I'm trying to decide on the proper backlight setting for my LED TV, but I'm not sure if I trust it completely. What I measure conflicts with some of the settings posted on review sites. If I use the suggested backlight setting, I only measure 24 ftL. This looks decent (maybe just a little dim) in a totally dark room. What's the typical margin of error on these meters? Thanks!
milehighou is offline
