Flashing lights? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 03-24-2012, 05:22 PM - Thread Starter
Raine0's Avatar
Quoted: 57 Post(s)
I was wondering, if playing a movie that consist of a lot of scenes with flashing lights, would that add a higher risk in the bulb blowing? Just like normal light bulbs, if you constantly switch it on and off, there's a high risk in blowing the bulb due to such action. Thx!
Raine0 is online now
post #2 of 10 Old 03-24-2012, 08:01 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Nooo..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 10 Old 03-24-2012, 08:25 PM
drcrazy's Avatar
I wouldn't think so, no. Make sure you wait for other peoples opinions before trying it out. I would call the manafacturer.
drcrazy is offline
post #4 of 10 Old 03-25-2012, 12:38 PM
rovingtravler's Avatar
The light bulb on your projector does not strobe. Only a very few new ones do this and LEDs, but your standard PJ use the DLP chip or the LCD chips or L-COS to modulate the light.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #5 of 10 Old 03-25-2012, 01:36 PM - Thread Starter
Raine0's Avatar
Quoted: 57 Post(s)
But theoretically I would think that even tho the lamp doesn't strobe but if u have a video with constant strobe like effects and images that go from completely dark and then to full brightness in a short amount of time, it would stress the lamp more? Cuz at the end of the day the lamp would generate more heat as it goes to full brightness and cools down a bit when it goes to total darkness/ as dim as it can. So you'll hv a constant constriction and expansion for period of time, therefore smth is more likely to break/crack no?
For example, you hv two identical pjs. One plays a static medium lit image and the other one plays a video that constantly strobes. Should the both lamps last the exact same time?
post #6 of 10 Old 03-25-2012, 07:45 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
It doesn't matter how dark or bright the video scene is, or how often it flashes. The bulb remains burning at a steady brightness. The light output from the bulb does not change one bit.
The bulb generates the light. The LCD or DLP panel generates the image and brightness.
It would be like taking a flashlight and putting a thin piece of white paper over it, then putting a piece of dark paper over it. The projected light changes brightness, but the bulb stays the same brightness.
sebberry is offline
post #7 of 10 Old 03-25-2012, 07:55 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
If you do a google for this "how a digital projector works" then read a few of the links, you will see how the different types of projector technologies work.
Doug
post #8 of 10 Old 03-25-2012, 10:31 PM
The bulb is on full the entire time the projector is on no matter what the material is on the screen. no difference to the bulb.
David
post #9 of 10 Old 03-26-2012, 05:12 AM - Thread Starter
Raine0's Avatar
Quoted: 57 Post(s)
Ok. I got it. Thx!
post #10 of 10 Old 03-26-2012, 10:37 AM
ferbal's Avatar
Ok. I got it. Thx!
The only (mechanical) part of a PJ that I think could suffer stress with these images is the iris. If your PJ has an auto-iris, this iris will move with each flash rapidly from an open wide position to a fully close position, but IMHO the iris is made to move much, much more than that.
ferbal is offline
