7-10K to spend on a 'film festival' projector... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 03-29-2012, 08:17 AM - Thread Starter
KBMAN's Avatar
Quoted: 287 Post(s)
Liked: 155
Hey fellow AVS'ers,
I frequent this particular forum because I've had almost a dozen home theater projectors, including my current JVC RS20.
I wanted to pick your brains on what pj in the 7-10K range can get me for a local film festival that happens every year. The screen will be 16ft x 9ft; a true 16:9 setup. So it needs to be at least 1080P, BRIGHT, and GREAT CONTRAST. I am NOT looking into single-chip DLP's...I don't think 3D is a requirement, but if it has it, then that's ok. The projector also has to have a fairly flexible zoom range, and lens shift is pretty much a given. Can anyone here point me to a few contenders??? Many thanks in advance!!!
KBMAN is offline
post #2 of 22 Old 03-29-2012, 09:36 AM
jmcguire525's Avatar
Stack 2 JVC's? Should be enough light for 2D and if you wanted to do 3D you could kit a filter kit but you wouldn't be able to light up that size screen with 3D filters.
jmcguire525 is offline
post #3 of 22 Old 03-29-2012, 10:36 AM
Some questions...Is this for an indoor or outdoor setup? Will the location be totally light controlled? How many people will be viewing, and will they be mostly centered, or out wide?
How often are you using it as well I suppose... I ask because if say 1x a year, you might be better off renting one each time. You could likely get more projector for your money, and each year as new stuff comes out, get better and better... Just a thought...
AV Science Sales 3 is offline
post #4 of 22 Old 03-29-2012, 12:38 PM
Tryg's Avatar
Buy it? why not rent it..that makes more sense
Tryg is offline
post #5 of 22 Old 03-29-2012, 12:43 PM
What I said.
post #6 of 22 Old 03-29-2012, 01:51 PM - Thread Starter
KBMAN's Avatar
Quoted: 287 Post(s)
Liked: 155
I need to ask myself the same question..."How much will it be used?". I've rented from Sacramento, CA before, and I got some bogus pj's. This will be used indoors with the lights basically all off. Audience size and location will vary. The idea of stacking projectors is really too much to deal with, with such a small staff; it needs to be fairly easy to setup and use....hope that helps....
KBMAN is offline
post #7 of 22 Old 03-29-2012, 02:50 PM
Pete's Avatar
Quoted: 238 Post(s)
Liked: 84
Why have you ruled out a single-chip DLP? RBE is not as much of an issue as it was in the past. You could get brightness with contrast and decent color in the price range you are contemplating (Runco, SIM2, DPI). Alternatively, depending on how far back your first row is, you could get a used 720p 3-chip projector with 10bit processing that would light up that size screen.
Pete is offline
post #8 of 22 Old 03-30-2012, 11:59 AM - Thread Starter
KBMAN's Avatar
Quoted: 287 Post(s)
Liked: 155
thanks Pete for the advice. Here is a little more info....
Projector needs interchangeable lenses for different throws..
Projector will be rented out to different venues and used about 3-4 times a month.
I saw a sony on ProjectorPeople that is LCD (not my best choice, but ok) at 1920x1200 with 7000 lumens, changeable lenses, and is 45 lbs.....it lists for just under 10K, but only has a contrast ratio of 2500:1.
KBMAN is offline
post #9 of 22 Old 03-31-2012, 03:10 PM
Pete's Avatar
Quoted: 238 Post(s)
Liked: 84
Contrast is key. Without it, even a bright picture will look washed out and details will be obscured. You don't need 7000 lumen unless you're lighting up a super jumbo screen in a stadium or something. If the projector is intended for cinema (i.e. watching movies), contrast and color are as important as (if not more important than) brightness. When you start talking about interchangeable lenses, however, the challenge becomes greater. You might need to increase the budget or decrease your want list.
Pete is offline
post #10 of 22 Old 04-02-2012, 06:36 AM
Not likely going to happen. The only projectors with interchangeable lenses in that price range are business units (like what you found at PP). Plus, each lens is going to cost you to buy... 2500:1 contrast is poor, especially for a film festival. Plus it is a 16:10 unit, not a 16:9 which is WAY more common for movie watching...
You would be better buying an HT unit with a zoom lens that has a long range...
post #11 of 22 Old 04-03-2012, 08:47 AM
http://www.fullcompass.com/product/393476.html
Over you budget, but maybe worth a look?
post #12 of 22 Old 04-03-2012, 08:52 AM
post #13 of 22 Old 04-03-2012, 01:11 PM
emf
emf's Avatar
There is discussion here about RED LASER projector at $10K. Not yet available, some conjecture maybe within a few months.
Projector will be rented out to different venues: this rules out stacking pj's.
emf is offline
post #14 of 22 Old 04-03-2012, 02:00 PM - Thread Starter
KBMAN's Avatar
Quoted: 287 Post(s)
Liked: 155
thanks for those links! These look to be more of what I'm looking for, however I'm not sure if anyone in the audience will experience RBE......
KBMAN is offline
post #15 of 22 Old 04-03-2012, 04:13 PM
emf
emf's Avatar
KBman - You mentioned PPeople had Sony with 2500:1 contrast ratio.
Allow me to discuss a bit about contrast ratio of projectors in actual use. Home theater users strongly prefer excellent contrast ratio as JVC products have become famous for.
Unlike home theater, public theaters generally have insurance coverage, and insurance folks want lights along the floor and along steps. They don't want to deal with audience injuries. These safety lights constitute ambient light that to some extent destroys constrast ratio.
Some measurements in commercial theaters indicated 1000:1 as the limit of contrast ratio capability. These studies were performed 15 years ago and may be outdated. Assuming theater condition have not improved all that much, a projector with 2500:1 contrast ratio is worth a try.
Before trying a projector, find a theater and reserve time schedule to try the projector in actual working conditions. Floor and step lights on. Exit indicator lights on. How does the picture look with ambient lights? Looks pretty good? Not as good as your RS20?
For the audience, the primary thing is the story. After the story, the major value is brightness. Locked into the story and totally distracted by it, they might not notice the color seems not quite accurate and the contrast ratio sucks. Good luck!
emf is offline
post #16 of 22 Old 04-03-2012, 05:29 PM - Thread Starter
KBMAN's Avatar
Quoted: 287 Post(s)
Liked: 155
thanks emf for that info,
The sony seems attractive, but also the sanyo's in the above link. All 3 of these projectors will throw a very bright pic, so that is pretty much already covered. My question is whether the 2500:1 contrast of the Sony is going to tromped by the Sanyo's 7500:1 contrast? and will it be NOTICEABLE......AND, will the Sanyo DLP be a problem for some people with 8000 lumens???
KBMAN is offline
post #17 of 22 Old 04-03-2012, 06:27 PM
imws's Avatar
So you're saying projected images have that low of a contrast ratio... That seems off to me and my eyes even from 15 years ago...
imws is offline
post #18 of 22 Old 04-03-2012, 11:30 PM
theres a guy on the forum, Space2001, he has two of the sony projectors at work and has set them up for dual passive 3D. Try talking to him some, he could at least give you an idea of how good the contrast is in real life.
post #19 of 22 Old 04-04-2012, 12:40 PM
Pete's Avatar
Quoted: 238 Post(s)
Liked: 84
If possible, avoid 5-segment color wheels that have a clear segment for added brightness. Six segment (red, green, blue, red, green, blue) will be more likely to give accurate color. Add some dynamic black, and you're off to the races. A 280 to 300 watt lamp should give you adequate brightness.
Pete is offline
post #20 of 22 Old 04-06-2012, 06:57 AM
Understand that is likely not really 8000 lumens. A lot of projectors out there are grossly exaggerated... It will be plenty bright, but for the size you are thinking I doubt "too" bright.
post #21 of 22 Old 04-17-2012, 04:52 PM
donaldk's Avatar
Quoted: 461 Post(s)
Liked: 111
Originally Posted by jmcguire525 View Post
or this in your budget http://www.fullcompass.com/product/365367.html
That's the second generation Delta single DLP/Dual lamp exchangable colourwheel unit? The first generation got a single positive review in the 20K+ section, as sharp, bright and even reasonable/good colours using the 'presentation colour wheel', instead of the darker video wheel. The first generation started at an MSRP of $20/21K plus a $2K MSRP lens. Ended up for around 12K US close out. Sanyo is being folded in the Panasonic line-up, so that might why you see good deals like these. Unit is also available as Eiki, or Christie, and perhaps a few other brands, first generation went on to be sold by Vivitek.
donaldk is online now
post #22 of 22 Old 04-17-2012, 04:59 PM
donaldk's Avatar
Quoted: 461 Post(s)
Liked: 111
@jason, come-on the 4K Barco DLPs are only 2200:1 the bright 2k DLPs peak at 2500-2600:1. Wolfgang has not once complained at the contrast ratio, the brightness of his high-contrast Home Theater 4K Sony is something he can't stop complaining about, as it is lacking. An HT projector for rental and staging applications, better not be 'dry hire' then...
