Can a 30ft HDMI cord do 1080p/3D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-09-2012, 07:49 PM - Thread Starter
RocknRolla's Avatar
I need a 30 foot long cable to complete the run between my receiver and projector, but I got a little worried reading that cables over 25 feet don't seem to be High Speed?
The cable I'm interested in is a BJC Belden Series-1 Bonded-Pair HDMI 30 ft cable (via Blue Jeans Cables) but it says that it's standard and high speed. Will it still be able to do 3D/1080p and be near the same quality as a high speed cable?
Also, if it can, would it be best to use a shorter BJC Belden Series-1 Bonded-Pair HDMI from my Blu-ray player to my receiver so the HDMI cables are exactly the same through the entire process? Or does it matter if the HDMI cable from the projector to the receiver is a different type than the HDMI cable from the Blu-ray player to the reciever?
RocknRolla is offline
post #2 of 7 Old 04-09-2012, 08:01 PM
plasmaowner's Avatar
Quoted: 46 Post(s)
I've been using this 30ft 22AWG CL2 Standard HDMI cable from Monoprice for the past 3 years with no problems at all. Everything works and looks beautiful (2D, 3D, etc).
plasmaowner is offline
post #3 of 7 Old 04-10-2012, 06:55 AM
Moderator
rboster's Avatar
Quoted: 1212 Post(s)
Liked: 1310
Here's an existing discussion that maybe of help
http://www.avsforum.com/avs-vb/showthread.php?t=1404164
We also have a forum dedicated to HDMI cables too
rboster is online now
post #4 of 7 Old 04-10-2012, 07:56 AM
Hyper_Eye's Avatar
Monoprice has introduced their high-speed with redmere cables that they claim are high-speed up to 65-feet. Here is the 30-foot version.
Hyper_Eye is offline
post #5 of 7 Old 04-10-2012, 08:38 AM
Generally yes. HOWEVER, what I have found is that more commonly the receiver/prepro can cause issue than the cable. I have done installs where I have had sync issues, but when bypassing the receiver it is aok. Just something to put in the back of your head should you run into occasional problems.
AV Science Sales 3 is offline
post #6 of 7 Old 04-11-2012, 08:08 AM
Moderator
rboster's Avatar
Liked: 1310
Here's an overview from Cnet of the Monoprice RedMere cables:
http://reviews.cnet.com/8301-33199_7...?tag=mncol;txt
post #7 of 7 Old 04-12-2012, 12:47 AM
Joel Solid's Avatar
I have two monoprice 35 ft cables. Both run 1080p without any issues.
I have 2 of these..
Joel Solid is offline
