DLA-RS45: JVC emitter or MonsterVision Max 3D? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-28-2012, 01:59 PM - Thread Starter
jbn008's Avatar
Quoted: 119 Post(s)
Liked: 54
I currently have a RS45 and have been thinking about trying out the 3D. I've heard good things about the MonsterVision, but was wondering what the consensus was for those that have tried both.
Headless Petie
jbn008 is offline
post #2 of 10 Old 04-29-2012, 01:08 PM - Thread Starter
jbn008's Avatar
Quoted: 119 Post(s)
Liked: 54
anybody?
Headless Petie
jbn008 is offline
post #3 of 10 Old 04-29-2012, 01:38 PM
zombie10k's Avatar
Quoted: 3477 Post(s)
Liked: 3560
The MV3D's won't ghost any less than the original or new style JVC glasses, but you might prefer the color tint better on the MV3D's as I do.
if I had to go with the JVC's, I'd use the original style. I think the new models are too small, especially for those that wear glasses. They perform identical with the same color tint so they might be good for younger visitors.
The MV3D's are a little more fragile than most active shutter glasses, you have be somewhat careful with them. You can use both the JVC emitter and MV3D transmitter if you make a cable like I demo'd in the signature link.
zombie10k is online now
post #4 of 10 Old 04-29-2012, 02:16 PM - Thread Starter
jbn008's Avatar
Quoted: 119 Post(s)
Liked: 54
thanks for the help.
Headless Petie
jbn008 is offline
post #5 of 10 Old 04-30-2012, 11:11 AM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
You may have a very dim image with the Monster vision glasses and a JVC projector. The polarization is different in the glasses and light cancels out. I had this issue and couldnt use them with a JVC projector. Maybe if your screen doesn't retain polarization it would work. Don't know for sure.
Ronomy is offline
post #6 of 10 Old 04-30-2012, 11:19 AM
mrfattbill's Avatar
Quoted: 108 Post(s)
Liked: 94
Did you try adjusting the settings in the Monster emitter with the software that is floating around?
Bill
mrfattbill is offline
post #7 of 10 Old 04-30-2012, 05:19 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Bill
To reduce ghosting yes but the polarization issue is a different problem. The JVC glasses are designed to have the same polarization as the projector. I talked directly to Bit Cauldron the makers of the Monster glasses. If you turn the glasses around and look through them from the front of the glasses lens the image is a lot brighter but I think if you get a screen that doesn't retain polarization it might be OK. My screen retains polarization. If you have a high power Dalite screen it might be OK. I didn't have one to try.
Ronomy is offline
post #8 of 10 Old 04-30-2012, 05:27 PM
rwestley's Avatar
Quoted: 144 Post(s)
Liked: 97
I agree that the JVC glasses are brighter but to me they look a little washed out compared to the MV glasses. It all depends on the screen you are using and its size. In my situation I really like the MV glasses much more.
rwestley is offline
post #9 of 10 Old 05-01-2012, 09:55 AM
Ron Jones's Avatar
Quoted: 907 Post(s)
Liked: 917
Check out the thread on Screens for 3D Projection for a discussion on using screens that retain polarization and why with such screens you need to use active 3D glasses that have the some polarization as the projector. JVC projectors use horizontal polarization and the universal glasses from Monster and Xpand have vertical polarization (to match what is used with LCD and plasma flat panel 3DTVs). So before you decide to use any non-JVC (e.g., universal) active 3D glasses you really need to understand how your screen reflects polarized light.
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is offline
post #10 of 10 Old 09-01-2012, 08:09 PM
mstarks3d's Avatar
hi
you can get around polarization issues for just about all screens, tv's monitors and glasses by using depolarizing acrylic and/or wave plates in front of the lens or on the glasses as I explain in detail in the JVC section of the FAQ on my page www.3dtv.jp
mstarks3d is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
