New PJ help.... Mostly sports. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-13-2012, 06:53 AM - Thread Starter
rr330i's Avatar
Friend is setting up an HT adjacent to his home office.
Fully light controlled and starting from scratch.
There will be a good amount of viewing with enough lighting so he can use his laptop.
Screen size 105-115"
Seating distance front row 11ft
Unsure of PJ distance to screen, as it will either be at back wall or mid room.
He'll watch approximately 70% sports.
He is eyeing the Sony 1000 and high end JVC.
What else should he be considering?
Btw he hates motion blurring he gets on some flat panels.
rr330i is offline
post #2 of 10 Old 05-13-2012, 07:15 AM
Joesyah's Avatar
A 3 chip DLP is what I would look at if considering this price range. Runco or Sim2 would be my main picks. For mainly sports and that size screen, your friend might be happy with a single chip DLP. Runco makes a nice LED projector in that price range. He'll never have to worry about changing lamps again. http://www.hometheater.com/content/r...-dlp-projector
Joesyah is offline
post #3 of 10 Old 05-13-2012, 08:30 AM
rovingtravler's Avatar
The Runco Q 750 or the the Sim2 M-150 are both very good and in his price range. His range is a little large the JVC is less than half of the Sony. I have a Q and the speed and sharpness is great. In a fully light controlled room it will be fine.
IMO the JVC is not fast enough for sports. IDLA has always had an issue there. It is getting better but DLP is still better for sports. The Sony is faster than the JVC, but any modern DLP will still have less lag and more fluid motion. With LED DLP you get the rich colors of IDLA / LCOS but with the speed of DLP. Also as mentioned you never have to worry about the bulb, so no $300-$1000 replacements which usually leads to watching more on the projector as you do not have to worry about the bulb.
hope that helps.
You may want to ask in the high end forum as well since some of these projectors have been talked about in there.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #4 of 10 Old 05-15-2012, 08:52 AM - Thread Starter
rr330i's Avatar
How will the runco Q 750 be w/ some ambient light?
Let's say compared to an Epson 9700?
Already neck deep w/ a dealer/builder.
Could I really buy just the PJ from another place, if i wanted the Sim2(since my dealer does not handle Sim2)
How hard would it be to integrate installation?
rr330i is offline
post #5 of 10 Old 05-15-2012, 11:50 AM
I am not sure what the Epson calibrates to in the way of light output, but the Q calibrates to about 435-450 without using brilliant color and other things.
This is similiar to JVC's line, but the bulb (LED) do not fade much at all.
Overall the Q is not meant for ambient light.
David
post #6 of 10 Old 05-15-2012, 02:49 PM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 3260 Post(s)
Liked: 1947
The 9700 calibrates to the same numbers in high lamp.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada & more.
Mike Garrett is offline
post #7 of 10 Old 05-15-2012, 03:35 PM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
I would not bother with high-end DLP projectors just for Sports when 30% of viewing is NON-Sports, get a 2-projector setup (DLP for Sports, and a JVC for movies), or I suppose the Sony 1000 would work. Not saying he shouldn't buy a high-end DLP if that is what he prefers, I'm just saying I wouldn't do it based on that one reason.
Access HERE from this thread
OLD --- Coder's Top Projector Picks of 2012 --http://www.avsforum.com/avs-vb/showthread....
coderguy is offline
post #8 of 10 Old 06-14-2012, 09:48 AM - Thread Starter
rr330i's Avatar
Thanks All... going w/ the Sim 2 Lumis 3D Solo.
rr330i is offline
post #9 of 10 Old 06-14-2012, 11:03 AM
AVS Club Gold
Liked: 1947
If we can help you, let us know.
mike@avscience.com
post #10 of 10 Old 06-14-2012, 06:30 PM
coderguy's Avatar
Quoted: 207 Post(s)
Liked: 235
Just make sure to demo them vs others so you know what you are getting for that high price.
coderguy is offline
Runco , Sim2
