Projector leveling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-31-2012, 10:04 AM - Thread Starter
Raine0's Avatar
Quoted: 57 Post(s)
I was looking at my friends pj and seem to notice it wasn't level. It didn't seem to be trapezoid in shape but the left/right vertical seems to be straight but the top and bottom seem to slightly slope in the same direction. As in both the left side, top and bottom, seems to be lower than the right side top and bottom. Is this possible lol?
Raine0 is offline
post #2 of 4 Old 05-31-2012, 04:56 PM
Mike Garrett's Avatar
Quoted: 6603 Post(s)
Liked: 4293
Often times, people will not have the screen perfectly level and then they just adjust the projector to match the screen.
Added
If the image is filling the screen completely and any over scan lost in the velvet screen frame, you probably could not tell if the image is trapezoidal shaped unless you threw up a test pattern.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 4 Old 05-31-2012, 05:02 PM
Brad Horstkotte's Avatar
Liked: 69
Is the projector ceiling mounted? If so, ceiling mounts usually have roll, pitch and yaw adjustments to get everything lined up. Also, its easiest to tune the physical adjustments with the electronics ones off (zero horizontal and vertical shift, no keystone).
Brad Horstkotte is offline
post #4 of 4 Old 05-31-2012, 06:11 PM - Thread Starter
Raine0's Avatar
Quoted: 57 Post(s)
Thx for the replies guys. I think the problem was, that he had a slightly wonky cupboard shelf.
Raine0 is offline
