Sony Qualia 004 advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-06-2012, 08:52 AM - Thread Starter
cmgunn's Avatar
I am looking for a projector to replace my now defunct iVision SX+. A friend locally has offered me their Sony Qualia for $1000, which includes a lamp that has ~100 hours on it, and a new spare. My plan would be to use the Sony for 2 or 3 years then move to a 4k 3D projector.
I have a 165" diagonal screen in a light controlled room. Will the Sony be bright enough to work on a screen of that size? Are there any other projectors in the $1,000-$1,500 range I should look at? I'm looking at image quality, brightness, contrast ratio and black levels in that order.
cmgunn is offline
post #2 of 13 Old 06-07-2012, 04:52 AM
stephenbr's Avatar
Quoted: 161 Post(s)
Liked: 72
cmgunn - if you don't take the Qualia for that price I would happily buy it from your friend (seriously).
I am sure others are better able to advise on the Qualia's suitability for that screen size but it was my understanding that the Qualia had good light output and could probably manage that screen size. The Qualia lacked contrast/black levels but had very accurate colours and excellent image quality through its very good lens.
stephenbr is offline
post #3 of 13 Old 06-07-2012, 09:52 AM - Thread Starter
cmgunn's Avatar
That's what I was thinking. It is a really good price for it. I have enough technical skill for dealing with and electrical/power supply issues. I think I'll go ahead and buy it. If I don't find it bright enough I can always sell it.
cmgunn is offline
post #4 of 13 Old 06-07-2012, 07:38 PM
Perfectionist2's Avatar
Quoted: 43 Post(s)
I owned a Q004 but used a much smaller screen. While i won't comment on the light output, i would love to see the Q004 with a Darbee in the imaging chain.
Perfectionist2 is offline
post #5 of 13 Old 06-08-2012, 06:07 AM
SOWK's Avatar
Quoted: 472 Post(s)
Liked: 363
SOWK is online now
post #6 of 13 Old 06-08-2012, 07:20 AM - Thread Starter
cmgunn's Avatar
What's a Darbee?
cmgunn is offline
post #7 of 13 Old 06-08-2012, 08:04 AM
Quoted: 43 Post(s)
DarbeeVision - Darblet DVP5000. The Q004 had an incredibly sharp picture film like image but there was often a slight haze and lack of contrast so I'd be very curious to know if the Darblet improves on this.
post #8 of 13 Old 06-08-2012, 08:06 AM - Thread Starter
cmgunn's Avatar
I'll have to give it a try.
cmgunn is offline
post #9 of 13 Old 06-08-2012, 08:29 AM
Quoted: 43 Post(s)
Read the posts on AVS for more info. Lots of excitement about the product although it's only been out for a short time so in my mind the jury is still out. You can buy it on AVS. If you try it, please provide followup feedback.
post #10 of 13 Old 06-10-2012, 08:59 PM
thebland's Avatar
Quoted: 1497 Post(s)
Liked: 849
As a former Qualia owner,
It will not light up a 165" screen well (unless it's a very high gain screen). It'll be dim and the Qualia will lose at least 25% of its brightness in the first 300 hours.
Put it on a 120" wide screen and it'll be aces. That's an incredible price.. Take it!
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is online now
post #11 of 13 Old 06-10-2012, 09:34 PM - Thread Starter
cmgunn's Avatar
I'm not sure what my screen gain is, but when using the SX+ I always had it in Eco mode, which was around the 1500 lumen mark with a new lamp. Even with my lamp nearing the end of it's life, it was still plenty bright, though the black levels were horrible. (A fault of the projector)
The screen is 16:9, so it's 156" diagonal for 2.35:1. If the Qualia won't be bright enough, what else should I look at in the sub $5k range?
cmgunn is offline
post #12 of 13 Old 06-11-2012, 05:49 AM
thebland's Avatar
Liked: 849
I'd still buy it. For that price, you can't beat it (with a new bulb). If anything, get a higher gain screen if post calibration you want things brighter. I like a brighter image. Hopefully your room is dedicated without windows.. The Qualia has a film look to it that is hard to beat and is absolutely quiet. IT beats all garbage under $5K (and higher in many cases).
post #13 of 13 Old 06-11-2012, 07:54 AM - Thread Starter
cmgunn's Avatar
My room does have windows, but they have been totally blacked out. I think I'll proceed with purchasing. Thanks for the advise!
cmgunn is offline
