Which part of projector lens needs to "see" top of screen? (Trying to mount as high as possible) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-06-2012, 08:24 PM - Thread Starter
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 66
I have a bulkhead (soffit) between my projector and screen. I want to put the projector as high as possible.
Which is the correct drop distance to install the projector? Option 1, 2, or 3?:
(Image features exaggerated for effect)
I'm assuming with digital projectors it's option 1? (Because it's the entire lens that forms the image). Correct?
The projector in question will be a JVC RS45 or RS55.
Kal
kal is offline
post #2 of 3 Old 06-06-2012, 09:07 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Generally, the top of the lens because the lens is indented and the light scatters/spreads fairly immediately, but lens shift is going to move it a little, so it will depend on the angle as well as the distance from the lens to the bulkhead.
The way you figure this out is to use the formula below that I posted:
http://www.avsforum.com/t/1375094/official-jvc-x30-rs45-owners-thread/3240#post_21863092
Just measure the distance from the bulkhead to the projector lens, and use that formula to calculate the inches instead of feet (you'll just make a small adjustment to it).
Then you will know about how far it needs to clear it.
Access HERE from this thread
coderguy is offline
post #3 of 3 Old 06-07-2012, 01:49 PM - Thread Starter
kal
kal's Avatar
Quoted: 16 Post(s)
Liked: 66
I figured that the entire lens was used but thought I'd check anyway.
The formula makes a lot of sense. I ended up pulling a string and using a laser pointer to double check too. I need a 6" drop minimum for my given throw.
The mount's been ordered:
Chief RPMA281 (which includes the SLB281 plate to fit a RS45 or RS55)
Chief CMA101 "designer" ceiling plate
Chief CMS003 3" pipe (1.5" NPT)
All combined the drop's slightly more than 6".
Thanks for the help!
Kal
kal is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Jvc Dla Rs55 Bundle , Chief Rpma281 Custom Elite Mount
