Basic questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-22-2012, 08:06 PM - Thread Starter
stanwelks's Avatar
I know nothing about projectors, though I was at someone's house and they had a 3D projector and about a 65-inch screen.
1. Can someone give me an idea of how much a good quality 3D projector will range?
2. What are the drawbacks to using a projector and screen VS. a plasma/lcd display?
stanwelks is offline
post #2 of 7 Old 06-23-2012, 08:02 AM
stanger89's Avatar
Quoted: 2635 Post(s)
Liked: 1354
Some of the more popular 3D projectors are in the $2k range (BenQ W7000, etc), all the way up to Sim2s that are way more than that. Though if you check the <$3k forum, you'll probably find people there happy with even less expensive machines too.
As far as projector vs "regular" display, IMO there's really only one thing to consider, ambient/room lighting. The quality of a projected image is directly related to how dark you can get you room. Projected images are at their best when there is no light from other sources hitting the screen. Any light that hits the screen that doesn't come from the projector raises the black level and washes out the image.
Now that's not to say you can't get an acceptable/usable image with some light, but for critical viewing with a projector you really want all lights off, and you pretty much can't use a projector during the day if there are windows in the room.
stanger89 is online now
post #3 of 7 Old 06-23-2012, 08:56 AM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
I will tell you this. I have been on this forum for many years and the number of people that have switched from projector back to TV are so few, that I can count them on one hand. Nearly all that I have read about that have switched back to a TV did it because them moved into a different house and did not have a room that they could set up for a projector. Most say, they can't believe what they were missing, once they go to a projector.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 7 Old 06-23-2012, 02:41 PM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
That is the truth. We bought a Samsung LCD 52" tv 3 years ago for our living room which at the time was the top of the line LCD. A year later I built a 21x19' theater room with no windows, painted the screen wall and ceiling flat black, added my projector, sound, etc and never looked back. I hardly use the LCD now since looking at HD on a 106" screen is pretty much unmatched.
If you can do it right you will be beyond pleased with the outcome.
dolphinc is online now
post #5 of 7 Old 06-24-2012, 08:19 PM - Thread Starter
stanwelks's Avatar
Thanks everyone for the responses.
What is the average lifespan of a projector bulb? How much on average do these cost?
post #6 of 7 Old 06-24-2012, 10:15 PM
coderguy's Avatar
Quoted: 303 Post(s)
Liked: 271
Well, it depends on the projector, but if you averaged it out:
Figure 2500 - 3500 hours on a bulb at a replacement cost of $250 to $350
Access HERE from this thread
coderguy is online now
post #7 of 7 Old 06-26-2012, 12:42 PM
Generous ballpark. I will say that though a lamp can last that long, it depends on many factors. But, what I find with our resident nuts (myself included) is many will RARELY go beyond about 1500. Why? Not necessarily because they die. But lamps dim over time...faster at first, and then slower. Especially in the OP's situation...more of a "TV Replacement" there is likely the potential that given that amount of hours it will get too dim for that type of use.
Of course each person is different in that regard...
AV Science Sales 3 is offline
Benq W7000 Home Projection System
