ADVICE NEEDED ON Upgrading JVC RS1x b/c unhappy with brightness under daytime ambient light. Which projector is best !? - AVS Forum | Home Theater Discussions And Reviews
Old 06-23-2012, 01:30 PM - Thread Starter
aal3723's Avatar
I just finished building my new house and built what I thought was the perfect den for ambient light viewing.
I have Stewart Filmscreen grey hawk fixed 106" screen with gain.
I have a DVDO VP50pro video processor
Projector is ceiling mounted on center about 7' high and a distance about 12.5', close to minimum distance of 11' for brighter picture.
I don't have and windows in den and most have some curtains in adjacent rooms so daylight is not directly on screen at anytime.
I work from home and use my projector for my main TV watching HD cable throughout day with about 5 movies a week.
Bottom line, I purchased the RS1x as I had read it was brighter that the RS2 which had also just came out when I purchased, but I see the new JVC projectors have almost double the Lumens (1300 vs 700). I read enough to want to purchase a new projector now and would like advice.
3D is a plus, but not necessary.
Brighter is the most important reason for upgrade, but 2D picture needs to be as good or better than RS1X.
I was considering a B-stock RS50U or RS60U, but then I just read a thread that said they were some of dimmest after calibration and RS45 is much brighter.
I am not married to JVC so suggesting any brand/model brighter and having at least equal picture quality of RS1X is greatly appreciated! Thanks!
aal3723 is offline
Old 06-27-2012, 11:51 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Do you care about 3D, if yes then the Epson 5010 is really bright and produces an image comparable to the RS1 as far as black levels (actually the Epson is slightly better).
That said, if you don't care about 3D, then you are not going to beat the image quality of the newer JVC's for overall contrast and black levels, and I also think on average the newer JVC's are some of the sharpest non-DLP projectors ever made.
Access HERE from this thread
coderguy is offline
Old 06-28-2012, 01:37 PM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
If you are worried about the brightness under daytime conditions, consider buy a black diamond screen. That's what I did..... I wanted a new PJ but decided on keeping the RS2 for 1 or 2 more years and decided to upgrade to a BD screen, which of course allows for the ambient light in the room and also will be a good fit with any new PJ I purchase in the future.
avsform1 is offline
Old 06-28-2012, 06:01 PM
xb1032's Avatar
Liked: 26
If you like brightness the first thing I would do is get a Dalite HP screen. I had an RS2 with about a 7-1/2' ceiling with the projector dropped down about 8" which is roughly your height and in the middle seats in line with the projector the brightness jump was very noticeable. Personally I would go that route first as that is going to be a noticeable difference in brightness and then I would look at a new projector when the new models roll around later this year (or look at closeouts from the current year then). Just my 2 cents.
Good luck!
xb1032 is offline
Old 06-29-2012, 05:43 AM
dragonbud0's Avatar
Quoted: 106 Post(s)
Liked: 49
I also have the da-lite HP 106 in a non-controlled LR, w/ my back facing the front foyer. Do have a screen/room divider behind me to block some of the lights. I could watch afternoon football game but would not able to appreciate my movies, esp. sci-fi. The RS10 is slightly brighter than the RS20, but still not good enough for me when there is too much sun.
My next upgrade would either be an Epson or Sony, due to their brightness. For sheer movie viewing, I love my RS20 after a dozen projectors. Just re-watched Alien last night to catch up after Prometheus; it was awesome black.
GL.
dragonbud0 is offline
Old 06-29-2012, 06:36 AM
Mike Garrett's Avatar
Quoted: 5569 Post(s)
Liked: 3550
Without seeing a picture of what your screen looks like during the day time, it is hard to say how much a brighter projector would help. I would guess that a specialty screen like the Black Diamond, Vutec Silverstar or DNP Supernova would probably help you the most for movie watching during the day. A High Power screen greatly increases brightness, but it can only do so much if there is very little black level to begin with. I have a 2.8 gain High Power in a room with a lot of ambient light. During the day the image is un-watchable and no amount of projector brightness is going to change that. If you have any questions, shoot us an email.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 06-29-2012, 03:18 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Get a cheap 2500 lumen DLP projector for daytime watching. Use the RS1 at night. Be happy! I am still amazed at what the little Acer 5360 does on my screen. Looks sharp for a 720p image too. Can be had for under $500 too. If you can see the screen glow during the day all you can do is go with a very bright projector but you will always have washed out dark scenes unless you go with that black diamond screen.
Ronomy is offline
Old 06-29-2012, 08:21 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
I use a acer h5360 with my RS40 and 55 that I had. Saved a lot of hours on my jvc projectors and the acer only cost me $400
blee0120 is offline
Acer H5360 3d Dlp Projector
