What is the actual brightness of Epson 5010 after fully calibrated? - AVS Forum | Home Theater Discussions And Reviews
Old 07-01-2012, 10:09 AM - Thread Starter
supercop's Avatar
Just want to know the actual figure on the brightness of epson fully calibrated:
projector review suggest 630 lumen but the member here say 1400 lumen.
supercop is offline
Old 07-01-2012, 11:43 AM
BobL's Avatar
Liked: 56
If using the best picture quality mode ~600 +/- 20% depending on lamp variance and where in the zoom range the projector is positioned. More than this would be in one of the projectors less accurate modes which aren't bad and can be useful for dealing with ambient light or very large screens.
BobL is offline
Old 07-01-2012, 08:25 PM
nirvy111's Avatar
Quoted: 119 Post(s)
Liked: 39
I measured my 6010 set to thx/cinema lamp low 460 lumens, lamp high 610 lumens and living room mode lamp low 860 lumens and lamp high 1200 lumens. That's at 3/4 full zoom with 50 hours on the lamp.
My light metre is cheap and probably not that accurate but it measured pretty close to projectorreviews readings. Keep in mind you most likely won't use the Epson in high lamp mode because it's a bit loud, 22db in low lamp and 32db in high lamp, so the low lamp measurement is what you should be looking at.
nirvy111 is offline
Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Pro Cinema 6010 Projector
