150 hours on a lamp table mounted, will it cause problems to now ceiling mount? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-02-2012, 12:27 PM - Thread Starter
Chris Albert's Avatar
Quoted: 24 Post(s)
Hey guys,
It's a JVC RS10, wondering if flipping it after 150 hours table mounted right side up and then flipping it over and ceiling mounting it will cause any issues? I had heard the lamp 'burns in' and then can flicker if you flip a projector.
Any help would be great.
Cheers.
*Running Quad 22L/C/12L/11L (6 Ohm), 2x HSU VTF15H MkII subs in a 6.2 config
*Denon 4520 Rx
* JVC RS-45 PJ
Chris Albert is offline
post #2 of 3 Old 07-02-2012, 01:20 PM
vullcan's Avatar
vullcan is offline
post #3 of 3 Old 07-02-2012, 01:27 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 36
I have an HD2K Optimized by William Phelps in 2007. I had it on for like ten minutes on a table, and he could tell when he had it ceiling-mounted during his optimization process. However, you have to consider the source.
Mark
giomania is offline
