Quiet FullHD 3D projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-03-2012, 03:03 PM - Thread Starter
Laree's Avatar
I'm looking for a quiet FullHD projector that has good 3D. Is there anything that can compete against Mitsubishi in decibels?
I'm used to listening Mitsubishi HC6800, which is quiet, and I wouldn't want get a noisier projector. Too bad HC9000 is too expensive. Panasonic PT-AE7000/AT5000 is at the very top of my budget but i hear it can be quite noisy. What would you recommend?
Laree is offline
post #2 of 8 Old 07-03-2012, 03:50 PM
zombie10k's Avatar
Quoted: 2802 Post(s)
Liked: 2734
I had the HC5500 and 6500 a while back, I am assuming the 6800 was just as quiet. The quietest projector I had this year was the Sony HW30. I have a high power screen and keep my projectors about a foot from my head.
Some of the noisier projectors are the Epson 5010/6010 & BenQ W7000. These projectors in low lamp mode are likely as bright, or brighter than the HC6800 was in it's best mode, so it might be OK if you get a chance to hear these in person. The 5010 has very bright 3D, but you will definitely hear the fan in 3D mode.
The safe bet is the HW30. You should start seeing a few for sale soon as the new models come out in the fall. If you look around, the HC9000 should be about 3k street.
zombie10k is offline
post #3 of 8 Old 07-03-2012, 06:48 PM
jnabq's Avatar
Liked: 39
The Epson 6010, I run, about 4' above my head, isn't noticeable in eco mode, at 22db its whisper quiet and plenty bright. In dynamic 3D, its rated at 32db and it can be heard in muted scenes. I am running the lamp in high altitude mode here, and was glad to find it is still very quiet in eco mode at that setting, and isn't bad in dynamic.
jnabq is offline
post #4 of 8 Old 07-13-2012, 02:59 PM
Seegs108's Avatar
Quoted: 4195 Post(s)
Liked: 2084
The Mitsubishi HC7800D is pretty quiet for a DLP projector. In eco mode I rarely heard it over the soundtrack of the movie. Also, it has some of the best 3D I've seen on a projector.
Seegs108 is online now
post #5 of 8 Old 10-07-2012, 11:12 PM
Dhuskey's Avatar
I am thinking of trying the HC7800. I just tried a Benq W7000 and it is way too loud. I would get the Sony HW30ES but it is still out of my price range (< $2000) but now the HC7800 is available for $1699.
Dhuskey is offline
post #6 of 8 Old 10-08-2012, 07:21 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Probably more recommendations for you in the under $3K forum. I really wouldn't know though because I don't spend much time there.
mark haflich is offline
post #7 of 8 Old 10-08-2012, 07:27 AM
Mike Garrett's Avatar
Quoted: 5553 Post(s)
Liked: 3539
Sent both of you PM's. Might want to ask about B-stock projectors.
mjgarrett100@gmail.com
Mike Garrett is online now
post #8 of 8 Old 10-16-2012, 12:06 PM
Dhuskey's Avatar
Yep from all I have heard the Sony HW30 sounds like the way to go. I just ordered my B-stock version, can't wait until it comes. Will update here once I get it.
Dhuskey is offline
Mitsubishi Hc6800 Projector , Mitsubishi Hc9000d 3d 1080p Lcd Projector , Panasonic Pt Ae7000u 1080p Full Hd Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Benq W7000 Home Projection System , Sony Vpl Hw30es 300 Inch 1080p Front Projector , Mitsubishi Hc7800d Projector Full Hd 3d Projector
