Anyone go from a JVC RS2/Pioneer clone to the Sony HW30? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-05-2012, 12:44 PM - Thread Starter
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
I currently own the Pioneer's JVC RS2 clone and am considering picking up a used HW30 from a very well respected member of this forum. I have a few questions to ask.
1. How do they compare in picture sharpness? My Pioneer has poor red convergence and looks fairly soft.
2. Does the HW30 have considerably more light output?
3. How does the black level and contrast compare?
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #2 of 13 Old 07-06-2012, 07:25 AM
michaelscott73's Avatar
Are you only considering the Sony? I went from the Pioneer to the BenQ.
michaelscott73 is offline
post #3 of 13 Old 07-06-2012, 07:42 AM
Mike Garrett's Avatar
Quoted: 5572 Post(s)
Liked: 3553
The softness could be helped some by adding a Darbee Darblet. Yes the HW30 will be brighter.
mjgarrett100@gmail.com
Mike Garrett is offline
post #4 of 13 Old 07-06-2012, 08:12 AM
RGBHV's Avatar
I moved from an RS1 to the HW30. Made for a very happy update. :-)
Yes Brighter, and so far the bulb seem to hold their brightness better than most projectors. The black levers seem similar or better (with the help of the iris.)
but one of the best improvements is in motion. Pans and the like all feel smoother and make it easier to see what is going on when there is all that action on screen.
And for me 3D turned out to be a happy bonus. I did not enjoy 3D in the theaters or any of the demos in the store... until this projector. (and the Monster glasses.) Now I have collected too many 3D blu rays than I should have.
Overall you should be happy with the improvements. More so if you game on your projector. (I have done some PS3 gaming on it.)
RGBHV is offline
post #5 of 13 Old 07-07-2012, 11:48 AM
JayF's Avatar
I moved from the Pioneer FPJ1 to the HW30 and wasn't satisfied with the black level/contrast. It didn't look "bad" but 2D just didn't have the same pop as the FPJ1. I recently moved up to the 95 and am satisfied.
JayF is offline
post #6 of 13 Old 07-08-2012, 07:50 PM
xb1032's Avatar
Liked: 26
I saw the Sony HW30 in a darkened room as well and the black level looked to be a bit of a downgrade. Everything else looked grear otherwise but the contrast for me is a deal breaker. I did upgrade to an RS45 and am very pleased. At this point though you may as well wait. The HW30 came out last August so it's replacement could come next month. No details on improvements but IMO I would definitely wait and see. Just my 2 cents.
xb1032 is offline
post #7 of 13 Old 07-09-2012, 01:19 PM
That is not surprising. The reality is JVC is the best for black level...period. And they do it without iris tricks. Generally, forgetting specs, if you really measure units, especially those with DI's, they will not perform anywhere near what they claim, especially how one would actually want to watch it.
Don't get me wrong the Sony does some things better, like motion, but again, even though it is newer, it won't have the same black level performance.
AV Science Sales 3 is offline
post #8 of 13 Old 07-09-2012, 05:40 PM
xb1032's Avatar
Liked: 26
I'm surprised that after all these years Sony hasn't pulled a JVC apart and reverse engineered what JVC is able to accomplish for black levels and came out with a more comparable projector as far as contrast goes without the use of the iris.
xb1032 is offline
post #9 of 13 Old 07-09-2012, 05:52 PM
zombie10k's Avatar
Quoted: 2810 Post(s)
Liked: 2755
that's like saying JVC should have figured out how to have better motion, better 3D, lamps that are 1/2 their current price and don't burn out before their time... cool.gif
Both projectors (HW30 and RS45) have their pro's / cons, it's a matter of what fits the specific user's environment.
zombie10k is online now
post #10 of 13 Old 07-10-2012, 12:55 PM
I am sure to some degree it has been done. But Sony doesn't like to be a follower (no one does), even if their are better aspects.
post #11 of 13 Old 07-10-2012, 03:00 PM
Freewheeler's Avatar
I still LOVE my JVC HD100 (RS2) after all these years. No need to replace yet it as I bought a 3D plasma TV :-)
Freewheeler is offline
post #12 of 13 Old 07-11-2012, 06:05 PM
xb1032's Avatar
Liked: 26
I was going to give JVC another year before saying that since 3D is relatively new. wink.gif
Sometimes an old dog needs to learn new tricks (or in this case old tricks). smile.gif
xb1032 is offline
post #13 of 13 Old 07-11-2012, 10:31 PM
coderguy's Avatar
Quoted: 300 Post(s)
Liked: 271
Probably an issue on patent restrictions. Even if JVC doesn't have the patent on some of the critical parts, companies often get patents on methods or combinations of middle-ware parts to make it as a whole nearly impossible to reverse engineer something without opening yourself up to a major patent lawsuit. Projectors are complex enough to where patenting certain original aspects of a design are going to be fairly simple even if the actual parts are based on non-patentable technology.
If JVC left it open and easy, I'm sure their contrast specs would have been duplicated, they are obviously protecting the design to the best of their ability (which they should). Either that or they hold trade secrets that no-one can easily figure out, but either way it's basically the same result, not so easy to copy or reverse engineer.
Access HERE from this thread
coderguy is online now
Sony Vpl Hw30es 300 Inch 1080p Front Projector , Jvc Dla Rs1 Projector
