JVC RS45 ceiling mount - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-06-2012, 01:33 PM - Thread Starter
colleycol's Avatar
Morning forum,
Can anyone direct me to a cost effective ceiling mount for the JVC rs45? I will need a pole extension, 18 inch I believe also
Thanks for any help.
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #2 of 2 Old 07-06-2012, 04:13 PM
Mike Garrett's Avatar
Quoted: 5583 Post(s)
Liked: 3564
Don't know if it is cost effective enough for you, but i would look at the Chief RPA281 mount. The nice thing about this mount is the ability to lock it into position, so that the projector holds its registration. You can also quick release the projector from the mount, for lamp changes or cleaning if wanted. Then just pop the projector back onto the mount and your registration is still there. Also if you buy another projector, you can buy a new plate to fit, rather than buying a new mount and you will be able to have the same features that you would be enjoying with the RPA281. Most of the cheap universal mounts will not fit the RS45 and they certainly do not do as good of a job for mounting. If you have some specific questions, shoot us an email.
mjgarrett100@gmail.com
Mike Garrett is online now
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Lcd Inverted Ceiling Projector Mount Style Rpa281
