Projectors at CEDIA Expo 2012 - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 384 Old 09-19-2012, 12:11 PM
blee0120's Avatar
Quoted: 561 Post(s)
Liked: 278
Originally Posted by Toe View Post
Sorry for asking since I am sure this has been covered, but what are the differences between the 48 and 4810?
I believe the 4810 is 3 year warranty and the 48 is two
blee0120 is offline
post #362 of 384 Old 09-19-2012, 12:17 PM
millerwill's Avatar
Quoted: 484 Post(s)
Liked: 278
Originally Posted by blee0120 View Post
My HP is electric. I raise it up to eliminate the bars, then raise it back down if the film is in 1.85 or 1.78. Works perfectly for me
A great way to do it!
millerwill is offline
post #363 of 384 Old 09-19-2012, 12:31 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Interesting on the electric screen. Never thought of that. You would only really have to mask the top then if you have this.
Holiday121 is offline
post #364 of 384 Old 09-19-2012, 12:35 PM
Owen's Avatar
Unfortunately the sound image does not move up-down with the screen image, a Trinnov processor can fix that.biggrin.gif
Owen is offline
post #365 of 384 Old 09-19-2012, 12:43 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Originally Posted by Owen View Post
Do you really get up in the middle of a movie to readjust the masking to suit a change in aspect ratio?eek.gif
Of course not.
fleaman is offline
post #366 of 384 Old 09-19-2012, 01:13 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
I have an electric screen and could do the same, but the image would just be too high for me, so I shift the image to the bottom then mask the top. More trouble but worth it (I keep telling myself tongue.gif)
fleaman is offline
post #367 of 384 Old 09-19-2012, 01:13 PM
stanger89's Avatar
Quoted: 3381 Post(s)
Liked: 1841
I'll leave it at this since it is OT.
As far as I am concerned the viewed decides what deserves to be bigger.
Fair enough.
37 degrees is very modest, no wonder you have no issues with the image quality of scope at that viewing angle. I am happy to view 2k scope at as much as 50 degrees for good transfers and 16:9 at even larger viewing angles as its typically higher quality then scope, the size of the image is no problem at all. With higher quality source I would go to 57 degrees for scope without hesitation.
I dont view TV of any kind on a projector, quality BD content only.
I'd actually like to go a bit bigger/wider but the room won't allow it, and I kind of built myself into a corner as far as moving the seating forward. It sounds like you don't actually have a CIW system, it sounds like you have a VIA system like Rich does, so I'm not sure why you're arguing "pro" CIW. But my point was not limited to TV, TV is just an extreme example of the idea that scope content is meant to be bigger than 16:9.
Maybe so, but it is the way it is so I choose to work with what I'm given not fight it. The upcoming 4k format is almost certainly going to be 16:9 along will 4k projectors so it seems Sony and hardware vendors have not leaned anything. wink.gif
I'll be happily running a CIH setup (probably with a lens) when I upgrade to 4K, just like I did when I upgraded to Blu-ray from DVD. Resolution doesn't determine relative presentation IMO.
CIH is a "problem" because video is CIW, some people may not be concerned about this "problem" but others are and I am one. I cant view scope 33% wider than 16:9 because image quality drops too much for my liking.
It might have tradeoffs you don't like, but it's not a "problem".
We only sacrifice impact if the screen is too small. With a suitable screen width for scope some people may find the 16:9 image too big but others wont.
It's up to the individual for sure, but my point, my contention is scope is supposed to be larger than 16:9, with the exception of stuff like IMAX which is in a different category.
We also sacrifice the impact and immersion of quality 16:9 content, thats acceptable to some but not to others and definitely not me.
I think most 16:9 content is not meant to be more immersive than scope.
stanger89 is offline
post #368 of 384 Old 09-19-2012, 01:20 PM
millerwill's Avatar
Quoted: 484 Post(s)
Liked: 278
Good point.   I agree that shifting the pic down to line up with the bottom edge of my screen makes for a much more pleasant 2.35 image.  It's also good to have light-absorbing black material below the screen, so that the 'black' (actually dark gray) over-spill (from zooming) is fully absorbed.
post #369 of 384 Old 09-19-2012, 01:32 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
I don't do any zooming. The 2.35 is just shifted to the bottom of the 16:9, so there is no overspill at the bottom of the screen, just a double sized gray bar above the image.
fleaman is offline
post #370 of 384 Old 09-19-2012, 02:10 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
This has me really thinking of getting a electric screen. I was so fixed on a fixed frame
post #371 of 384 Old 09-19-2012, 02:23 PM
blee0120's Avatar
Quoted: 561 Post(s)
Liked: 278
I tried shifting to the bottom but it was too low for me, plus I have my screen about a foot from the ground, so when I raise it up, the image is about 1.5ft from the ceiling.
blee0120 is offline
post #372 of 384 Old 09-19-2012, 02:34 PM
SOWK's Avatar
Quoted: 506 Post(s)
Liked: 431
Anyone interested in JVC's new projectors, AVS is taking Pre-Orders now and have great prices. Please call one of the AVS sales reps for all the info.
SOWK is offline
post #373 of 384 Old 09-19-2012, 02:37 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Took advantage of it.. Got a Rs46
post #374 of 384 Old 09-19-2012, 02:53 PM
fleaman's Avatar
Quoted: 74 Post(s)
Liked: 115
Yeah, the bottom of my screen is about 3ft from the floor. And it's on the smaller side which I sit fairly close too (9-10ft), so going higher is uncomfortable in my set up.
fleaman is offline
post #375 of 384 Old 09-19-2012, 03:40 PM
Toe
Toe's Avatar
Quoted: 1839 Post(s)
Liked: 2112
Originally Posted by Kelvin1965S View Post
About '10' biggrin.gif and an extra QC check before shipment AFAIK. There might be a difference in warranty too, but not completely sure.
tongue.gif 10 more just sounds good!
That is cool. Thanks for the info!
JVC CMD Vertical Banding: Affects all currently shipping lamp based JVC Projectors
http://www.avsforum.com/forum/24-dig...rojectors.html
PLEASE CALL JVC AND REPORT THE CMD BANDING IF THIS BOTHERS YOU
1-800-252-5722
Choose option 1, then 4 and have your serial# ready (located on back of unit or box).
Toe is online now
post #376 of 384 Old 10-04-2012, 07:40 AM
Thebes's Avatar
Originally Posted by sanderdvd View Post
There not much talk about the Mitsubishi HC8000D yet. Would love to hear more about it as it seems a real 3D killer!
Hi,
there are here a review from Projector Central :
http://www.avsforum.com/t/1432352/mitsubishi-hc8000
Thebes is offline
post #377 of 384 Old 10-04-2012, 08:23 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3834 Post(s)
Liked: 3827
I've used electric screens since I got into home theater. They have some advantages over fixed screens ( except for cost ). A " free " electric screen salvaged off a construction site got me started - that " free " screen has cost me tens of thousands of dollars by now ( every one well spent !! ).
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #378 of 384 Old 10-04-2012, 01:05 PM
noah katz's Avatar
Quoted: 1032 Post(s)
Liked: 366
Originally Posted by Craig Peer View Post
I believe electric HP's are quite a bit cheaper than fixed.
Noah
noah katz is offline
post #379 of 384 Old 10-04-2012, 02:36 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3827
post #380 of 384 Old 10-04-2012, 05:07 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Don't you have 2?
GetGray is offline
post #381 of 384 Old 10-04-2012, 06:07 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 3827
2 screens? Yes - a 2.35:1 and a 16:9 screen.
I think they both cost me more than a fix screen would have..........eek.gif
post #382 of 384 Old 10-12-2012, 05:28 AM
icecold1936's Avatar
Anybody have an idea when the Mitsubishi HC7900DW will be coming out? IM very interested in that projector from the specs that has been posted on the net..
icecold1936 is offline
post #383 of 384 Old 10-12-2012, 07:37 AM
nikonf5's Avatar
Might want to shell out the extra $500 for the 8000.
Projector Central review on the HC8000
nikonf5 is offline
post #384 of 384 Old 10-12-2012, 07:46 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Maybe you should give me one since I still can't make a decision on a screen smile.gif
Cedia
