jvc hd750 color shift issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-09-2012, 05:17 PM - Thread Starter
kiliksun's Avatar
HI,
Wasn't exactly sure where to post this. I recently purchased a Jvc hd750 used via the videogon Classifieds. Unfortunately it's exhibiting a display issue where about a 100px to the left of the screen a gradient of blue shadowing is apparent. Examples attached. 700
700
700
I'm assuming the worst, but I thought it would prudent to get some feedback first.
Thanks guys.
kiliksun is offline
post #2 of 4 Old 07-09-2012, 08:03 PM
Mike Garrett's Avatar
Quoted: 5609 Post(s)
Liked: 3591
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 4 Old 07-11-2012, 03:01 AM
Highjinx's Avatar
Quoted: 343 Post(s)
Liked: 160
Activate the masking, there is a 2.5% and a 5% in the menu...one will loose a bit of the frame but it will be useable, without distraction.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is online now
post #4 of 4 Old 07-11-2012, 04:48 AM
dvcdude's Avatar
Quoted: 14 Post(s)
My HD750 has a red gradient on the left edge of the screen. I have it masked 2.5% and have been going strong for over 6 months with no other visual issues. I will probably replace it after CEDIA when I see the new models. Hopefully, it will hang in there until the replacement arrives. The cost of the optical block makes it prohibitive to repair.
ISF Level II Certified Calibrator
CEDIA Member
Serving Central Indiana
www.indyvideocal.com
dvcdude is offline
