Need help on projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-13-2012, 04:06 PM - Thread Starter
Shawn25's Avatar
I have a customer that want a projector that will be 72 feet away from the screen. He wants the screen to be 10 by 8 with an aspect ratio of 16 by 10. What projector can do this? It is for a church.
Thank you
Shawn25 is offline
post #2 of 2 Old 07-15-2012, 09:43 AM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
Any projector that offers a 7.2:1 lens option. If the projector can be 70' away instead of 72', you could get by with a lens that goes to 6.9:1. In either case, the projector that would handle these types of lenses will not be inexpensive...unless you go with an older 720p model (which might well be adequate for this application).
Pete is offline
