Panasonic PT-AE7000u issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-16-2012, 10:23 PM - Thread Starter
jgatsby's Avatar
I purchased this projector in May 2012 and started noticing that my perfectly black and white movies started to turn pinkish in the left corner of the screen. It's definitely not a calibration issue as it appears on all color profiles. Now, it's starting to get larger and more noticeable and definitely becoming an eyesore. Does anyone have any idea what is causing this, especially for a projector so young? It has about 278 hours on it.
Thanks for the advice!
Mike
jgatsby is offline
post #2 of 4 Old 07-17-2012, 05:00 PM
kthejoker20's Avatar
Panel is going bad. Send it in for repair.
I hope it has warranty.
kthejoker20 is offline
post #3 of 4 Old 07-17-2012, 08:20 PM - Thread Starter
jgatsby's Avatar
Yes, it's only 2-3 months old. I've contacted Panasonic and in the process of sending it in for repair.
jgatsby is offline
post #4 of 4 Old 08-26-2012, 10:01 PM
A Movieholic's Avatar
Hey Jgatsby, did you receive the projector back from repair and if so hows it working now? Mind posting any pics on your set up? I have been thinking about a projector and leaning towards the pt ae7000u.
A Movieholic is offline
Panasonic Pt Ae7000u 1080p Full Hd Projector
