OFFICIAL THREAD SONY VPL-HW50ES new SXRD Projector IFA BERLIN 2012 - Page 11 - AVS Forum | Home Theater Discussions And Reviews
post #301 of 302 Old 12-24-2012, 06:18 PM
randman's Avatar
Originally Posted by dsm1212 View Post
Sorry for the late response. Yes that was probably me on the monoprice review. I ended up getting this cable for less than half the price and it works great.
http://www.amazon.com/gp/aw/d/B006LOFCQ6/ref=mp_s_a_1?qid=1356397362&sr=8-1&pi=SL75
Gave me a crazy delivery estimate after I ordered it of like 5 weeks but I got it in about 6 days. Seems very well made.
Steve
I bought 2 Monoprice ultra slim 40' HDMI cables. One is connected from my processor to the projector. The other one is connected from my Oppo Blu-Ray to the VPL-HW50ES projector directly. Both cables work great. I tested with 1080p and 3D Blu-Ray movies and both cables work great.
randman is offline
post #302 of 302 Old 01-24-2013, 03:42 PM
sarangiman's Avatar
Originally Posted by kraine View Post
And it's generate flickering so you better turn it off;
But it doesn't have to, if implemented correctly.
I drew up a little schematic of how I think DFI ('Dark Frame Insertion' or 'Film Projection' under 'MotionFlow') should work; here it is as a PDF:
http://cl.ly/MQB9
I believe the HW30/50 & VW95 are all using (2) in my schematic; namely, 96Hz processing with 48Hz flicker (frame doubling, then inserting a black frame between each frame).
Since VW1000 owners are indicating they *don't* see any flicker with DFI on with 24p content, I'd assume the VW1000 is at least using (3); namely 144Hz processing with 72Hz flicker (frame tripling, then inserting a black frame between each frame), if not higher.
72Hz flicker should not be objectionable. 48Hz flicker is. There are diminishing returns as you go to the higher frequency processing modes (4) & (5); in fact, they may be undesirable as asking the liquid crystal arrays to switch 240 times/sec is likely impractical.
144 times/sec (for 72Hz flicker) should not be impractical since apparently the HW50 can do 120 times/sec just fine, since that's what it needs to do for DFI with 60p content (which it handles just fine).
Note the cost in brightness for all the different modes should be the same, as I show in my schematics (total duration of dark frames remains the same; frequency increases and duration of each individual dark frame decreases).
However, there is a way to implement some of those modes I outlined with less of a loss in brightness, at the cost of more flicker. For example, in the 144Hz processing mode, you could handle the DFI in two different ways: one costs less brightness but causes flicker, while the other costs more brightness but reduces flicker:
144Hz Processing, frame-sextupling:
1-1-D-1-1-D | 2-2-D-2-2-D
----1/24s---- |----2/24s----
48Hz flicker, 2/6 frames are dark frames
... instead of:
1-D-1-D-1-D | 2-D-2-D-2-D
72Hz flicker, every other frame is a dark frame
The first case only causes a 33% loss in brightness (2 out of every 6 frames is a dark frame); the latter causes 50% loss in brightness (every other frame is a dark frame).
So there are ways you could play with this algorithm to cause more/less drop in brightness. Given that the HW50 does not lose that much brightness when DFI is enabled, I wonder if they're using something more like the former. In the two schemes above, I would prefer the latter... less brightness, but no flicker.
Looks like Sony figured out DFI for 24p content on the VW1000. They're the only company that even uses DFI in a projector (that I know of) to achieve near-DLP motion (without soap opera effect). Not sure what's holding them back from proper implementation in all their other projectors.
sarangiman is offline
Sony Vpl Hw50es 3d Projector
