OFFICIAL THREAD SONY VPL-HW50ES new SXRD Projector IFA BERLIN 2012 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 302 Old 09-28-2012, 11:30 PM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Originally Posted by kraine View Post
A video review from CINE4HOME in german
By going at 14 minutes40 you can see the reality creation in action.
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
post #32 of 302 Old 09-29-2012, 03:19 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
looks pretty good coming from a youtube video
Holiday121 is online now
post #33 of 302 Old 09-29-2012, 08:32 AM
HiFiFun's Avatar
Yes here :
http://www.audiovideohd.fr/tests/295-Sony-VPL-HW30ES-5.html
7875:1 but with less lumens
According to Cine4Home the Sony 1000 contrast ratio is reported:
"The native contrast ratio amounts, as with the previous series, depending on the zoom and iris settings (it can also be operated static), (on iris, zoom, max) between 8,000:1 and 18,000:1 (iris, zoom min) . "
From the above video the similar 50ES calibrated, measured contrast is 6800:1 (at 11:53 minutes) @1400 lumens.
Their 30ES measure 3200 to 5000.
The native contrast appears to have improved over the 30ES.
HiFiFun is offline
post #34 of 302 Old 09-29-2012, 08:52 AM
conan48's Avatar
Quoted: 290 Post(s)
Liked: 349
Also looks like dynamic contrast is 45 000:1 calibrated.
conan48 is offline
post #35 of 302 Old 09-29-2012, 10:05 AM
zombie10k's Avatar
Quoted: 2805 Post(s)
Liked: 2742
Lucky you if it come true, in Europe we have almost 3 more weeks to wait (ETA the 18/10)
There's no specific date yet here in US, it's likely a similar time, a few weeks away. AVS is checking with Sony this week to find out the ETA.
zombie10k is offline
post #36 of 302 Old 09-29-2012, 10:37 AM
zombie10k's Avatar
Liked: 2742
http://www.hifi-forum.de/viewthread-94-12265-7.html
a current discussion on the lens and theories on how they improved sharpness over the HW30. Current information states they are sharing the same lens that caught some flack last year. The topics include possible optimization of the optical path. The other possibility could be the reality creation software causing a perception of increased sharpness, similar to the Darbee effect.
My specific RS55 has an excellent lens. The focus is dead on for the entire screen and pixels in the farthest corners of the 142" screen are clear and well definied. Having owned the HW30 for a year, I'm curious to see how these improvements were made (hardware / software or both ).
One of the popular topics this year will be RC vs. E-shift vs. Darbee, etc. Good camera techniques will be able to give a basic idea of what's going on between these various methods of attempting to increase overall PQ.
post #37 of 302 Old 09-29-2012, 10:43 AM
mech27's Avatar
The sony style website is saying estimated shipping is 10/1
mech27 is offline
post #38 of 302 Old 09-29-2012, 10:47 AM
zombie10k's Avatar
Liked: 2742
I saw that too but my understanding is that it's not accurate. We'll find out for certain next week.
post #39 of 302 Old 09-29-2012, 11:11 AM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3549
Correct. I just checked. All of the Sony distribution locations in the US currently show:
Qty 0
On order from vendor 0
ETA date (is blank)
mjgarrett100@gmail.com
Mike Garrett is offline
post #40 of 302 Old 09-29-2012, 12:56 PM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
post #41 of 302 Old 09-29-2012, 02:09 PM
TedO's Avatar
Quoted: 26 Post(s)
Liked: 27
Looking at the pictures on te Sony web site, there is no 12v trigger for the projector, just an RS232 input.
Has it been confirmed that the DI will not be active in 3D?
TedO is offline
post #42 of 302 Old 10-01-2012, 03:39 PM
dsm1212's Avatar
I'm on pre-order and I have a couple random questions:
1. My first/current projector is a venerable mitsubishi hc5000 and the lens is on the right side of the projector. So unless I move the ceiling mount the sony will be ~4 inches off center from the screen. I'm assuming horizontal lens shift will deal with this or should I move it?
2. Will my universal spider mount work with this or is there something special about the bottom of a sony?
3. Any recommended 3rd party glasses that will work with Sony projectors or should I buy more sonys? Two are not going to be enough and I'm assuming the samsung led glasses I have won't work with it.
thanks!
dsm1212 is offline
post #43 of 302 Old 10-01-2012, 05:53 PM
Seegs108's Avatar
Quoted: 4198 Post(s)
Liked: 2088
To answer your questions:
1: This Sony does have horizontal lens shift. I'd personally avoid using it, especially if you need to use the vertical lens shift a bunch as well. You want to keep the light coming through the lens as close to the center sweet spot as possible. You'll get the sharpest picture from corner to corner this way. If you have the means to move the mount, move it.
2: Yes, it should work fine. I have a universal mount from Peerless and it has worked with over a dozen different projectors over the past year. The only thing you might need to change are the screws/bolts that will go into the projector. They will most likely be a different size. Check the Sony's manual. I don't know if one has been posted on Sony's site. If its not check the HW30's as it has virtually the same chassis and will almost certainly take the same screw size to mount.
3: I would check out XPand. They make cheap high quality universal glasses for both IR and RF emitters.
Seegs108 is offline
post #44 of 302 Old 10-01-2012, 05:57 PM
dsm1212's Avatar
Thanks for the quick reply Seegs108. I think it should not be too hard to move the mount and patch the old spot so I'll probably give it a shot. I'll check out the glasses too.
dsm1212 is offline
post #45 of 302 Old 10-01-2012, 07:59 PM
Liked: 3549
post #46 of 302 Old 10-02-2012, 09:03 AM
leo9000's Avatar
Quoted: 16 Post(s)
Qty 0
ETA date (is blank)
I preordered from Sony site. Today my order updated on the site and say "Ready to Ship", estimate ship date 10/02/2012. Let hope this is accurate!
leo9000 is offline
post #47 of 302 Old 10-02-2012, 09:57 AM
velvetpoet's Avatar
Any updates from avs team on ship dates?
velvetpoet is offline
post #48 of 302 Old 10-02-2012, 09:59 AM
dsm1212's Avatar
Sony site for my order says Ready to Ship for 10/2. I had to call them about something else so I asked them what that status means and they confirmed it will ship today.
dsm1212 is offline
post #49 of 302 Old 10-02-2012, 10:06 AM
leo9000's Avatar
Quoted: 16 Post(s)
Thanks for the update. I was about to call them about my order. Really looking forward to this new projector. I'm replacing my old VPL-HW10.
leo9000 is offline
post #50 of 302 Old 10-02-2012, 02:49 PM
Liked: 3549
I just called the Sony's store since the store shows it as out of stock. The salesman told me that they have not received any HW50ES projectors. I am hearing a date of availability of the 17th.
post #51 of 302 Old 10-02-2012, 05:13 PM
zombie10k's Avatar
Liked: 2742
This reminds of when they were ready to ship the HMZ 3D Headsets, the Sony site said they were ready to ship, but it was delayed for weeks. Only when it says 'processed' and they email a tracking # would I be getting excited.
post #52 of 302 Old 10-02-2012, 07:59 PM
leo9000's Avatar
Quoted: 16 Post(s)
Just got shipping confirmation email from Sony and FedEx. Shipped out from CA today.
leo9000 is offline
post #53 of 302 Old 10-02-2012, 09:34 PM
zombie10k's Avatar
Liked: 2742
good deal, then it's time to get excited! you guys are getting the first production models being released. Is this your first projector?
post #54 of 302 Old 10-03-2012, 07:22 AM
leo9000's Avatar
Quoted: 16 Post(s)
Yes, very excited. This is my 4th projector. Started with a Sony CRT back in the day, then moved on to a Runco in 2003, then the Sony VPL-HW10, now on to the HW50ES. Looking forward to seeing how the 3D looks on a big (110") screen.
leo9000 is offline
post #55 of 302 Old 10-03-2012, 07:43 AM
dsm1212's Avatar
Mine was shipped yesterday too, but it must be coming by Fedex-Pedestrian because it's not due to be delivered until next Tues :-(.
dsm1212 is offline
post #56 of 302 Old 10-03-2012, 07:26 PM
Elkhunter's Avatar
This quote from Art's review of the 50ES has me interested in the 50ES:
"I spent over an hour playing with Reality Creation, and Epson's Super-Resolution, side by side (HW50ES an HC5010). No question, even on the low default of 20, the Sony makes everything look sharper than the Epson even with its Super-Resolution up at maximum of 5."
I have the Super-Resolution of my 5010 set at 4, and my Darblet (in HD mode) set at 60, when viewing HDTV shows via Comcast, on my 159" HP screen at 11'-4".
An even sharper image (which Art claims the Sony has), has me thinking about upgrading this winter - even though I know that I'll want to upgrade again to 4K in a year or two.
I want images in my HT to look like 'real life'. I don't give a rat's a** about maintaining the director's intent.
In this forum, this makes me a J6P.....right???
Elkhunter is offline
post #57 of 302 Old 10-04-2012, 04:10 AM
sanderdvd's Avatar
Quoted: 162 Post(s)
Liked: 30
I m thinking about 'upgrading' my JVC RS45 to the Sony HW50 which is just around the corner. Only thing I m worried about is black level. I m a real black level entheusiast and I don t want to loose this on a new projector. Will this become a problem for me when switching from my RS45 to the HW50 you guys think? My HT room is a total bat cave. Also, when looking at the review of Projector Reviews I did notice some things that Art stated that I do not agree with (and I think more users here will too). He says the black levels of the last years Epson topmodel are better then the JVCs. Well, thats not true at all. The JVC is a state-of-the-art black level projector. Also, he compared some screenshots and says the HW50 is better in blakcs then the HW30. Well, maybe it s me but when you look at the screenshots he made the HW30 is by far the better one in black level:
HW50: http://www.projectorreviews.com/images-projectors-q3-12/vpl-hw50es_5thelement_starship_over_large.jpg
HW30: http://www.projectorreviews.com/images-projectors-q3-11/vpl-hw30es_5th_element_starship4_large.jpg
sanderdvd is offline
post #58 of 302 Old 10-04-2012, 05:52 AM
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
I've had the 30 and JVC 45. Unless there are night and day changes between the 30 and 50, you probably will regret your decision.
To me watching these two projectors (30 and 45) are not even close. I know a lot of people here compare these two projectors but have never figured out why.
tigerfan33 is offline
post #59 of 302 Old 10-04-2012, 06:39 AM
Joesyah's Avatar
Unless youre looking for a upgrade in 3d..best to stay put. 6800 vs 20,000 native equals no contest.
Joesyah is offline
post #60 of 302 Old 10-04-2012, 06:44 AM
Yusuf.0088's Avatar
I guess people compare hw30 and rs45 because of 3D.
Not a secret, that JVC has best black level and worst ghosting, though I never owned it.
sanderdvd, If your budget allows, I advise keep rs45 for 2d, and buy hw50 for 3d. If you will be satisfied with hw50's black level, you always can sell rs45.
Yusuf.0088 is offline
Sony Vpl Hw50es 3d Projector
