Will JVC RS 55 throw a 113 in image (16x9) from 13 feet? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-22-2012, 11:34 AM - Thread Starter
Mako71's Avatar
Thanks, unfortunately I do not know how to calculate lens throw.
Mako71 is offline
post #2 of 3 Old 07-22-2012, 11:45 AM
Seegs108's Avatar
Quoted: 4206 Post(s)
Liked: 2090
Yes. For further measurements check here:
http://www.projectorcentral.com/JVC-DLA-X70R-projection-calculator-pro.htm
The X70 is the same as the RS55.
Seegs108 is offline
post #3 of 3 Old 07-23-2012, 02:29 AM
AV Science Sales 4's Avatar
Is the 113 the screen diag or is it the screen width? Divide your throw distance in inches, here 156, inches by the screen width in inches. If that number lies between 1.4 and 2.8, your in business with the JVC. Regardless, the JVC will work with either size.
AV Science Sales 4 is offline
Jvc Dla Rs55 Bundle
