Projector mounting question - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2012, 01:49 AM - Thread Starter
karl75's Avatar
Hi everyone,
I am interested to get the Panasonic PT AE7000 but I would like to check first if this projector is compatible with our current lounge set-up.
Can I can use the vertical lens shift together with the "lens memory" function (to convert 16:9 to scope screen) at the same time?
I would like to mount this projector at the back of our lounge room but we have a small chandelier in the middle of the room, it is mounted directly from the ceiling and is about 16 inches in height (from ceiling to edge of chandelier). I am getting a scope screen but I am not keen on spending $$ for the anamorphic lens. Hence, I am getting this projector (has both lens shift and lens memory).
Thank you.
karl75 is offline
Old 07-31-2012, 08:00 AM
Mike Garrett's Avatar
Quoted: 5715 Post(s)
Liked: 3658
Originally Posted by karl75 View Post
Hi everyone,
Thank you.
This projector has strict mounting limitations, if you want to use the CIH setup. The projector lens, must be mounted between the top and bottom of the image. The way that this projector does CIH is not by lens shift, but by shifting the image on the chip. This means it can only shift the image the height of the top and bottom black bars. That is why the lens has to be mounted between the top and bottom of the image.
mjgarrett100@gmail.com
Mike Garrett is online now
