JVC DLA-X3 vs JVC DLA-HD250 - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2012, 05:41 AM - Thread Starter
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
I have decided to purchase a JVC projector and I have narrowed it down to these 2. They are within my budget and the price difference between the 2 is about $350. My setup is listed below and I am looking for input from JVC owners or anyone with knowledge of these 2 models.
I have ZERO interest in 3D so that holds no value to me.
I have a 1.1 gain Elite Cinawhite 106" screen
Projector will be 12' to 13' from the screen
Seating is around 11' to 12' from screen
Flat black walls and ceiling
100% light controlled room
Yamaha Advantage A2000
Oppo BD-83
Other equipment
80% Blu-Ray Movies
10% Directv
10% Games (Xbox 360)
Thanks for any info.
dolphinc is offline
Old 07-31-2012, 06:44 AM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
How many hours per year do you use your projector?
If you use it more than say 500 hours per year, be aware the bulb cost can add up on the RS-45 (x3).
The JVC hd250 has slightly more reliable bulbs presumably. So that might account into your cost mechanisms.
Access HERE from this thread
coderguy is online now
Old 07-31-2012, 07:01 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Oppo BD-83
Other equipment
80% Blu-Ray Movies
10% Directv
In your room with the flat black walls the RS40 will achieve a bit better black levels and contrast. The RS40 will probably have a sharper image and the you gain power lens shift, FI and a little more brightness. If you are looking at one of the B-stocks, you get a full manufacturer's warranty and to me that would be a big positive over a projector without warranty. Both projectors will do a good job lighting up your screen. You have to decide if those things are worth it. I am not much of a gambler, so i like the safety of a warranty.
mjgarrett100@gmail.com
Mike Garrett is online now
Old 07-31-2012, 08:50 AM - Thread Starter
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
I use it about 800 hrs a year. I thought JVC fixed the early failure bulb issues?
dolphinc is offline
Old 07-31-2012, 08:53 AM - Thread Starter
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
The 2 companies I was looking to purchase from are both JVC authorized dealers, one is from JVC refurb division itself so warranty should not be an issue. I am just looking for the best deal.
dolphinc is offline
Old 07-31-2012, 11:14 AM
mbw23air's Avatar
Quoted: 159 Post(s)
Liked: 151
It's still unknown. I have a RS40/X3 and thought my "002" bulb was fine and right before the bulb hit 500 hours it dimmed tremendously and then died. I never watched 3D and only turned the lamp on high after bulb dimmed. I have a 003 bulb that is to be delivered today that JVC replaced for free and I don't think others who have the 003 bulb have been able to put enough hours on it to know if this bulb fixes the problem. So, just make sure to buy with a warranty as Mike at AV Science says. I would buy the b-stock RS40 from him as AV Science's service is great.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Oppo BDP-93 blu-ray player Panasonic UB-900 UHD blu-ray player
mbw23air is offline
Old 07-31-2012, 12:17 PM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
Or look at buying a bulb-only warranty online to go with your projector. That is what most of us probably should do when buying the JVC lamps.
At least it might cut the lamp costs by 40% in the long-term.
Old 07-31-2012, 03:42 PM
mbw23air's Avatar
Quoted: 159 Post(s)
Liked: 151
That is a good idea for next time I have to purchase a new JVC lamp if JVC won't cover it. I've never purchased a lamp warranty, do you have to purchase the warranty at the same place that actually provides lamp warranties as an extra or can you purchase your lamp at AV Science then add the warranty by providing a sales receipt to a place like Mack?
Mike
mbw23air is offline
Old 07-31-2012, 11:12 PM
coderguy's Avatar
Quoted: 339 Post(s)
Liked: 293
I am not 100% certain, I've bought one lamp warranty but that was so many years ago.
There is Mack, Square Trade, and a few others. I am pretty sure they will let you buy the bulb warranty separately, but you'd have to check with them.
I do not know which one is the best warranty company (easiest to deal with), you might want to start a separate thread for that.
Old 08-01-2012, 08:25 AM
Liked: 3594
Mike
You do not have to purchase the lamp warranty from where you purchase the lamp. You do need to purchase the lamp warranty within 30 days of lamp purchase.
Old 08-01-2012, 08:45 AM
mbw23air's Avatar
Quoted: 159 Post(s)
Liked: 151
Thanks Guys,
I'm hoping this third generation JVC lamp won't suffer any premature dimming or die early. If it lasts it's normal life then I will give you a call Mike to purchase my next JVC lamp and I will definitely get it covered by a warranty.
Mike
mbw23air is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Jvc Dla Rs40u
