Mitsubishi HC9000 On 120 screen?? - AVS Forum | Home Theater Discussions And Reviews
Old 08-08-2012, 05:23 PM - Thread Starter
ander77's Avatar
Hello
I have a JVC X3, and now i have the chance to buy a Mtsubishi HC9000D in less than 2K €. I have read a lot of reviews, and i have a doubt, Is enough its 1000 lumens for a 120 inches screen? I am going to project in a white room, and the screen has 1.0 gain. Could someone tell me if HC9000D is a good choice for me?
ander77 is offline
Old 08-08-2012, 06:31 PM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
Originally Posted by ander77 View Post
Hello
What is your throw distance? Even at short throw, you will not be able to leave the projector in low lamp mode very long. Good news, the Mits is pretty quiet in high lamp.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 08-09-2012, 12:09 AM - Thread Starter
ander77's Avatar
Thanks for answering Mike
I am going to project from a distance of 5 metres.. Is it a good choice the Mits HC9000D or better i continue with the JVC X3 at home?
ander77 is offline
Old 08-09-2012, 02:01 PM - Thread Starter
ander77's Avatar
Another question: Could someone tell me how does it work with 3D? Better or worst than JVC X3?
Thanks!!
ander77 is offline
Old 08-09-2012, 04:32 PM
Liked: 3594
I would probably stick with the X3. You are going to be hard pressed to light up a 120" low gain screen in 3D with either projector.
Old 08-09-2012, 04:58 PM - Thread Starter
ander77's Avatar
Thanks Mike
It's hard to take a decisiona about his matter. In some reviews i read that it is a very bright projector, meanwhile in others i read it is not recomended for screens bigger than 100 inches... I have read also that HC9000 once calibrated is brighter than X3...
I do not know to do...
ander77 is offline
Mitsubishi Hc9000d 3d 1080p Lcd Projector , Jvc Dlax3 200 Inches 1080p 3d Front Projector 3 Chip Hd D Ila Black
