Quick Lamp Replacement Question for Sony VW 60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2012, 08:02 PM - Thread Starter
maestro50's Avatar
I am curious and a little confused.
After a couple thousand hours the message came up on the screen saying it was time to replace the lamp.
I did.
I replaced it with a cheap knockoff. Bad move. The new lamp quit after 600 hours. Just stopped dead.
Ok, lesson learned. That is not my question.
So, I've ordered my new replacement lamp from AVS and while I am waiting I reinstalled the old lamp.
(This is the same lamp that I was told by the message that I needed to replace. I had just never gotten rid of it.)
Here's the thing, I put it back in the projector, and it works fine.
I've had it in there for about a week now. I suppose it might be a little dim, but it's hard to tell. That is almost my question.
My question is this: If the lamp really is still in need of being replaced, why haven't I gotten another message telling me to replace the bulb? What is the "trigger" for the message in the first place?
maestro50 is offline
post #2 of 3 Old 08-13-2012, 10:53 PM
HokeySmoke's Avatar
I don't know about your specific projector, but there are two common triggers in general. The first one is simply lamp hours. Did you reset the hour counter when you replaced the original lamp? If so, then the projector may just wait until the hour counter gets back up to a couple thousand hours. At some point, however, your lamp will no longer strike because the voltage is too high. This leads to the second possible trigger.
The second trigger is the lamp voltage, which varies with the arc gap. Once the voltage is too high then the ballast will no longer be able to maintain the arc, and it will go out or be unable to strike. The ballast can read the voltage and may be telling you that it is getting close to an unusable voltage. However, there is a special waveform that is run through the lamp to sharpen the electrodes to keep it from flickering and this can actually reduce the gap (and the voltage) in the short term, especially if you run it for long periods of time. This is why near the beginning of life you might actually see the image get slightly brighter than when it was new (A smaller arc means a brighter image). However, in the long term you will need a new lamp as the "macro" burn back will overcome any "micro" sharpening eventually.
You also run the danger of lamp explosion whenever you go beyond the recommended lamp life, as the glass envelope degrades over time. This failure has become less common as the materials and processes get better, but it still happens from time to time.
HokeySmoke is offline
post #3 of 3 Old 08-14-2012, 01:28 PM - Thread Starter
maestro50's Avatar
Thank you for your kind and thoughtful answer.
That is exactly what I wanted to know.
Sony Vpl Vw60 Home Cinema Projector
