Trying to buy Sony vpl vw95es/ vpl hw30es from Sony center uk no luck - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-20-2012, 09:09 AM - Thread Starter
Nazz66's Avatar
Hi
did nybody buy VPLVW95ES or VPLHW30 ES from a Sony center in uk? I did try, emailed every Sony in uk but no luck, even the sony website displays these projectors but with no price tags, are these projectors been discontinued?
But there are plenty sold on line and most of them here in uk are not sony accredied deralers , what a dilemma .
Can anybody shed some light on this matter, can anyone recommend an online store here in uk which is also an accredited Sony dealer?
Nazz66 is offline
post #2 of 3 Old 08-22-2012, 01:21 AM
kbfern's Avatar
I am sure Allan at Ideal a/v should be able to do you a 30/95.
kbfern is offline
post #3 of 3 Old 08-22-2012, 11:21 AM
sheridd2's Avatar
Check out www.chromapure.co.uk. I've bought the Darbee Darblet from them and found Ricky very helpful with excellent customer service.
I made an enquiry on your behalf, hence the late reply, they don't have either model in stock due to the IFA coming next week, new model(s), but should be able to get them pretty quick as they are Sony dealers.
sheridd2 is offline
Sony Vpl Vw95es Full Hd 3d Home Cinema Projector , Sony Vpl Hw30es 300 Inch 1080p Front Projector
