Thinking of a Runco Q-750i - Looking for advice - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 94 Old 02-28-2015, 04:46 AM
GabeG's Avatar
Originally Posted by Seegs108 View Post
I've seen the insides of all three units. Yes, as far as hardware goes, all three are identical. All three units are OEM'ed from Delta, the parent company of Vivitek. The only thing that differs between the three are minor software changes and outside chassis design. The Runco has a better LED modulation implementation (dynamic contrast) over the other two units and it also has a more robust/user friendly color management system.
Thanks! So it sounds like the Runco would be the best of the three. I saw an early review of the vivatek that complained of softness in the picture. Is that true compared to the other two?
GabeG is offline
post #92 of 94 Old 02-28-2015, 01:49 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2581
No, not at all. The lenses are the same in all three. The review unit must have had a bad lens sample. If I had to choose between the three, the Runco would be the one I'd choose to own.
Seegs108 is offline
post #93 of 94 Old 02-28-2015, 02:07 PM
GabeG's Avatar
Got it. Assume you'd choose the runco for superior contrast performance.
GabeG is offline
post #94 of 94 Old 02-28-2015, 02:09 PM
Seegs108's Avatar
Liked: 2581
It doesn't have superior contrast performance, just a better implemented dynamic iris (LED dimming). You just see the LED modulation working less on the Runco compared to the Vivitek and NuVision.
Seegs108 is offline
