Limited space want longer throw question - AVS Forum | Home Theater Discussions And Reviews
Old 08-30-2012, 12:34 PM - Thread Starter
Not the Momma!'s Avatar
Hello all,
I have a unique problem. My theater space is roughly a 13x15 (so small) but unfortunately I can't put the projector screen on the 15' area so im relegated to using the 13' area. My projector is an Epson 8350 and will be projecting to a 110 16:9 screen. If i mount at the very farthest, the lens will be around 12' away from the wall... I can still get the 110" however I will be zooming a bit... And as I understand its sometimes better to try and use as little zoom as possible.
My space is unique in the fact that it has a crawlspace behind the room. I'm thinking about putting the projector in there still ceiling mounted, and cutting a viewing hole. Here is where i come into the problem.
The house is built in 1911 and has balloon walls and all the heat from the floors below (basement, 1st, and 2nd floors) travel up that wall and make that crawlspace very hot in the summer time and cold in the winter time. I am not in the business of destroying my projector. I'm looking for some suggestions on what I could do to make the best out of a situation.
Am i just better off mounting it inside and calling it a day or is it worth the extra effort to try and mount it behind the wall. Any and all suggestions would be greatly appreciated.
Not the Momma! is offline
Old 08-30-2012, 12:46 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
Have you heard any specific drawbacks of operating the 8350 at the wide end of the zoom range? When most people complain about the 'zoom' they are referring to the loss of brightness when the projector is mounted as far from the screen as possible. I'd just mount it where it makes sense within the room.
dougri is offline
Old 08-30-2012, 12:56 PM - Thread Starter
Yes I was referring to the decrease in light output... Currently my home theater environment is definitely not optimal in regards to light, however in the future this will go into a dedicated theater room, most likely completely light controlled.
So to clarify my original statement I was not referring to image quality rather decrease in light.
Extra note:
Hoping in about 3 years to build a house fresh and have the theater designed like so many of you guys do, as much as I love building things myself.
Old 08-30-2012, 01:23 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
If you are able to fill the screen while mounting the projector in the existing room, why would you want to move it further from the screen into an adjacent space? Doing so will decrease the brightness. If brightness (rather than noise) is your concern, you want it as close as possible while still filling the screen. confused.gif
dougri is offline
Old 09-02-2012, 05:15 PM
ChrisW6ATV's Avatar
As dougri said, the closer you can mount the projector, the better, definitely in the case of Epson projectors (I have their 6500UB).
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
Epson Powerlite Home Cinema 8350
