Wii on 7000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-12-2012, 04:17 PM - Thread Starter
Gummy69's Avatar
7000 is better than expected . Original plan was to use for Blu-ray, Netflix , and VUDU. Eye popping resolution and 2D-3D impressive- will have to expand. Now hooking up DISH (salivating) . I moved my Wii and connected the component lines to my Yamaha RX- V473; output by HDMI to the 7000. Audio OK but no video . Any thoughts?
Gummy69 is offline
post #2 of 3 Old 09-17-2012, 12:34 PM
derek's Avatar
Are you using Wii in 480i mode? Some receivers don't upscale and transcode to HDMI at 480i. Try setting the Wii into 480p mode.
Derek
derek is offline
post #3 of 3 Old 09-25-2012, 07:14 AM - Thread Starter
Gummy69's Avatar
Your suggestion helped me find the solution. Wii doesn't let you set to 480p unless using component cables. So I got some, but my receiver does not pass through component to the 7000. However there is an out to monitor on my receiver. I ran another set of component video to the 7000 and paired it with the audio input. Image is pretty decent and the kids love it.. I guess that is the best I will get with 480 on that size screen.
Gummy69 is offline
