Offical JVC DLA-RS4810 Owners Thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
Old 01-20-2013, 09:03 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Everybody has a Darbee because it improves their sex life. They just don't want to say.
Seriously, I saw the Darbee in prototyoe form years ago and have been plugging it ever since. I started the original thread years ago Most perceive it as an inline device that makes contrast detail in picture more visable in a way a higher quality lens might let one see more fine detail. It does have some negatives but most conclude that used in moderation 9it is settable) there is a net improvement in PQ. I like it a lot but even i would say the improvement in PQ is in the neighborhood of a few percent, maybe 5. Worth it in my opinion at its current price. Give Mike a call at AV Science, he will set you up and there like most things AV Science sells is a trial period.
mark haflich is offline
Old 01-20-2013, 10:00 AM
Schwa's Avatar
Quoted: 1008 Post(s)
Liked: 1068
Originally Posted by freebits View Post
Oh... below 3 in CIE94? In my case, if I increase saturation, hue is lowered and vice versa with green. Brightness works okay.
Which color mode & profile did you choose?
Here's my calibration report...as you can see, green is under 3. In my case it did take some farting around with the two effective green controls because adjusting brightness would affect hue and saturation and adjusting hue would affect brightness and saturation. Adjusting saturation, in my case, did nothing.
I used the Natural color mode and Standard color profile.
Schwa is offline
Old 01-20-2013, 10:11 AM
plissken99's Avatar
Quoted: 129 Post(s)
Liked: 35
Oooh yeah from the screenshots on their site I am definitly ordering that, the price is a bargain in the A/V world. Can someone who knows the AVS price PM me? I know they don't like disclosing their prices on the forums. Because I can get it on Amazon for $320 with a return policy, and on credit(which sad to say is necissary at this moment).
The more things change, the more they stay the same.
Snake Plissken
plissken99 is offline
Old 01-20-2013, 10:23 AM
Kelvin1965S's Avatar
Quoted: 260 Post(s)
Liked: 161
Originally Posted by edfowler View Post
One other consideration that doesn't get mentioned much is that, in my observation, motion blur seems to have been greatly improved. Maybe I had a horribly jerky jerky Rs40, I don't know.
I was watching some end credits last night and I suddenly thought that I must have accidently put CMD on low as it seemed so smooth. I checked and CMD was off, so it's just that I do find the motion smoother on the X35 compared to the HD350, but then I've missed quite a few generations out (the best way to upgrade IMHO).
Originally Posted by Geof View Post
That's an excellent approach. Given that I have a Lumagen and don't care for this years eshift I would have opted for the RS46 if I had known then what I know now. That said the PQ on the RS54810 is excellent and it comes with an extra year of warranty.
That's interesting to hear. I thought long and hard about the choice, but I've seen an X55 since and wasn't overly troubled that I made the choice for an X35. I'm also going to calibrate an X55 for a UK forum member (in return for a chance to listen to some high end PMC speakers) so that will give me chance to have a bit more in depth viewing of the X55.
Thanks for posting this, as per my above comment, it helps to know a good starting point when I calibrate the X55 mentioned above. I would however recommend that you revisit the low end gamma as it looks like it's well above 2.3 at the low end (maybe even 2.4) which will ruin any shadow detail. If it isn't too difficult I'd even suggest lowering the gamma on the 5% adjustment perhaps to 0.1 or even 0.2 below your target.
@ Plissken99 The Darbee is a great little device, but IMHO if you haven't got the cash I wouldn't sweat it: Not worth getting into debt over (as is any of the gear we talk about on here, it's a luxury after all).
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
Old 01-20-2013, 10:30 AM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Originally Posted by plissken99 View Post
Sounds more and more like I might be better off with the RS46 and investing in a Lumagen eventually. What is this Darbee thing? And why does everyone seem to have one?
Sorry......no mocking intended.....that question just struck me funny biggrin.gif
RonF is offline
Old 01-20-2013, 10:41 AM
Schwa's Avatar
Liked: 1068
I didn't calibrate gamma...I think I set the "Custom Gamma" adjustment value to 2.4 or 2.5 in the 4810's menu and left it at that. As you suggest, I'd prefer that the gamma curve "swing" the other way (low at the low end, high at the high end), but CalMAN recommends a gamma between 2.4 and 2.6 for a darkened room so I figured that a low-end gamma of under 2.4 would be fine. I'll fiddle with it the next time I get my meter out.
There's no standard workflow for calibrating gamma in the CalMAN 5 Basic software that I have and I got into a real mess trying to do it with HFCR so I decided to save myself the frustration this go around. I suppose I can simply bump up the custom gamma curve at the low end to achieve the results you suggest.
Schwa is offline
Old 01-20-2013, 11:00 AM
Liked: 1010
The problem with a set accross the board gamma number is that the on/off at the screen will not be high enough to support a high gamma at the very low end. Its a fact. If the on/off is not high enough, you will experience black crush or in other words a loss of low end detail as the blacks merge into nothingness. It is imperative that to avoid this, a non linear hign number gamma be used. An S curve gamma must be employed with the gamma number being lowered t the low end. at the high end a higher number can be supported, even higher than the supportable gammma at mid levels.
gamma depends on viewer preference. How contrasty a image do you like but then once again, your preference may bot be obtainable given the limitations of your projector and how you set it up, high lamp/low lamp, iris setting and throw.
I laugh at people who thing there is somethig magic about 2.2 and paying a calibrator set set you a straight line gamma at 2.2 (really a curve, just calling it a straight line). Most calibrators do not understand gamma and want you to think you have bettered your projetor by giving you a nice graph showing a perfect 2.2. What a joke. They have given you black crush at the low end and not the magic of movies which are often displayed at their best at higher mid and high end gammas. but once again the exact gamma at any point is a metter of preference avoiding choices that crush the blacks and/or clip the whites.
Old 01-20-2013, 11:05 AM
5mark's Avatar
Quoted: 47 Post(s)
Liked: 25
Your gamma curve looks very much like the gamma presets when my RS55 was new. It gives the impression of lots of very deep blacks but loses shadow detail. The best way to get the detail back without calibrating is to raise the Dark Level control which tweaks the low level gamma. But at some point I would highly recommend using the custom gamma controls to get it perfectly flat. And as Kelvin mentioned, tweaking 5% for that last bit of shadow detail.
5mark is offline
Old 01-20-2013, 11:18 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Yes, I read your comments about cal'ing his x55. I'll be most interested in hearing about how well it calibrates and your impressions of the unit compared to your X35.
I went with the x55 because I really liked eshift1 on my RS55 (which ended up with a very significant purple-ish cast in blue skys which is why I no longer have it). But I should have acted on my first impressions of eshift2 and returned it for the RS46. With all the adjustment options I thought I could dial it in but I have yet to get there. Zombies eshift1/eshift2 comparison photo clearly shows eshift2 is adding artifacts that eshift1 did not so I have given up trying. I wish they would have given us a mode that simulates/emulates eshift1.
Geof
Geof is offline
Old 01-20-2013, 11:40 AM
Toe
Toe's Avatar
Quoted: 1474 Post(s)
Liked: 1843
Interesting gamma discussion guys and thanks for all the info. I just did my auto cal with the Mini/CP a few days ago and right now I have a flat 2.22 gamma. My question is what is the best way to tweak the low end back down a bit to reduce black crush and can I do this without getting out the meter and calibration gear AND will this screw up the rest of my calibration? Can I simply put on some sort of reference type shadow detail scene (any suggestions?), pause it and tweak the low end (5%?) up a few clicks or so? Next time I pull out the meter and calibrate I assume I can either tweak this in the Mini or JVC (does it matter which place I tweak it?), but I was hoping I could just tweak the low end by eye until then without damaging the rest of my calibration. Any tips/advice would be appreciated! smile.gif Hoping I can just tweak this in the JVC by eye at the low end without getting out the meter.........
EDIT: I just read 5Marks post. I dont have a dark level control in my 45 so this is not an option unfortunately. What is the next best attack to improve low level detail?
Toe is online now
Old 01-20-2013, 12:46 PM
vesa's Avatar
Ah, great for you!
I measured most all color profiles and here are the initial out of box Green errors for my unit:
Code:
Stage:      ∆E = 6.1
Anime:      ∆E = 6.2
Standard:   ∆E = 6.7
Natural:    ∆E = 7.7
Film/Film:  ∆E = ??
Note: The film color profile is only available in the film Picture Mode and I did not measure this - yet.
In fact I used picture mode User1 with color profile STAGE (X55´s Manual page 38).
vesa is offline
Old 01-20-2013, 12:51 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
You can't fix the JVC's slight black crush without washing out the image.
My biggest pet peave of the JVC line.
Set it to the gamma you like and leave it.
I've put in countless hours trying to pull out the shadows, only to find out it looks great in certain scenes and totally destroys others.
I have a lot of real world pics that the JVC struggles at:
Here's 2
You "should" be able to see the v shaped lapell on bonds right side (your left)
*** below pic is overexposed to show the detail ***
You "should" be able to see the individual church pews. Not on the JVC... Lol.
Toe: does the Lumagen allow you to create a gamma point at 1% or less?
If so make sure that is 2.22 or just under. That may not mess with the image enough to screw up the rest.
SOWK is offline
Old 01-20-2013, 01:58 PM
Quoted: 260 Post(s)
Liked: 161
I guess I'm too used to the Lumagen, because I don't have a problem with low level gamma causing crushing. On this occasion I'm going to disagree with Mark as don't find that a measured 2.2 crushes black at the low end as I can see the 17 bar flashing on the AVS disc whereas if it were crushed I wouldn't be able (16 is as dark as 15, 14, etc, so black level can't go any lower).I find that a gamma of perhaps 2.3 that drops to 2.2 at 10% looks good to me (when I had a temporary black room treatment up anyway). If you slightly raise up the 5% in custom gamma it may well help without raising the absolute black level unless perhaps the RGB offsets have been adjusted away from 0.
IMHVO getting the gamma response right is paramount to seeing a good image: No good having a perfect greyscale and gamut if the gamma means shadows are hidden and brighter parts look washed out. Putting the projector in 2.4 or whatever and leaving the other settings alone is only doing half the job. In fact I'd argue that colour temp could be a little way off and you may not even notice since our eyes will tend to compensate, but poor gamma stands out (or it does to me anyway).
It is possible to move the 21 point greyscale around on the Lumagen so that you could have a 1% setting should you wish, but not sure how this effects the autocal result (perhaps you could just move the 5% on down in the Lumagen and use the JVC's 5% control if necessary).
Old 01-20-2013, 02:10 PM
Liked: 1010
The 21 point merely divides 0 to 100 in 20 equal steps. i believe you could measure and customize gamma at 1% increments if you wanted to but certainly not using an auto cal function. I have never done more than a 20 step, twenty onepoint but I think it is possible.
Old 01-20-2013, 02:11 PM
erkq's Avatar
Quoted: 622 Post(s)
Liked: 442
Yes!!! Getting a good gamma curve on my pj was the biggest eye-opener (pun intended) I've ever had in home theater. It made a huge difference! More than grayscale or gamut.
erkq is offline
Old 01-20-2013, 02:23 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
I'm with you that having a good gamma response makes a huge difference. Then I'd rate grayscale and then gamut.
As Mark states, one can adjust Lumagen greyscale and gamma in 1% increments but that is of course limited to doing it manually. Have fun financing a meter that can do this accurately below 5% though.....rolleyes.gif
SOWK: Have you tried a BT1886 gamma curve? I'm sure you also realize that jumping up higher in the JVC food chain (higher contrast ratio machines) would yield more luminance separation between level 16 and 17.
Geof
Geof is offline
Old 01-20-2013, 02:30 PM
Quoted: 260 Post(s)
Liked: 161
You couldn't adjust at 1% increments unless you only wanted to adjust from 0 to 20% as the 100% and 0% can't be moved and you only have 19 points that can be moved around where you feel they would work best.
Using a Lumagen you could adjust the greyscale and gamma manually and move the 19 points where you see fit (and use the JVC's custom gamma too if you really had nothing better to do with your time), then run the autocal for the colour gamut. However, I find it's quicker to let the autocal do it all, maybe check the greyscale (make any slight tweaks if you wish) then do the colour gamut separately. Anything away from the target gamma will produce errors due to the way the cube works, but from those who have measured these errors they don't seem to be too major and we are talking about low % levels anyway, so you could argue that the gamma is more important here than absolute spot on colour temp at very low %.
While on the subject: I've seen the arguements about only aiming for 3dE, but my opinion is that it is better to aim for as low as is possible. Then any error of the sensor might still fall within limits:if only 1-2 dE meter error it might mean that the actual dE is still within 3dE if you hit near 0dE with your measurements. However, I don't spend so much time calibrating these days...I did lots and lots of experiments when I first got my old i1LT and Chromapure: I tried different gamma responses (flat and curved) and saved them in different memories. I would then pause different scenes (light, middle and dark) to try to understand which settings effected which parts of the image. Now that I know I personally prefer 2.3 that drops to 2.2 (maybe even 2.1 at 5% on my older HD350 with less contrast) then that's what I aim for...it doesn't take long these days either manually with Chromapure and the Lumagen or autocal with a few tweaks, so all the more time to watch films. cool.gif
Old 01-20-2013, 02:34 PM
erkq's Avatar
Quoted: 622 Post(s)
Liked: 442
When I go into CalMAN's DCC I find resolution to 0.1%. What am I missing? Do you mean 1% relative to the current point's level or 1% relative to 100IRE? The DCC shows 0.1% relative to 100IRE, right?
erkq is offline
Old 01-20-2013, 02:42 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
I was referring to 1% luminance steps (Autocal does 5% or 10% increments) but I think you may be right that you can go finer than that....I just don't recall at the moment.
And Kelvin, to be clear, I also try to get ∆E lower than 3 (lower than 1 if I'm in the mood) but if the meter is accurate a gamut ∆E error of 3 really isn't an issue.
Geof
Geof is offline
Old 01-20-2013, 02:58 PM
Quoted: 260 Post(s)
Liked: 161
That's the point Geoff, we don't know for sure how accurate our meters are: I have the i1 display Pro enhanced, which is supposedly pretty accurate, but without a $$$$ spectro to compare it to, I don't really know how accurate it is. So if it's 1-2dE out and I manage to hit below 1dE on my readings then I'm still good as my max dE is still under 3. If I hit just under 3dE and my meter is out by 2dE then I could be at 1dE or just under 5dE actual error depending which way the error is. Of course I don't even know if my meter is within 2dE, but all I can do is make it as accurate as I can in the light of the above.
Old 01-20-2013, 03:07 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
True but it's much much more then that.
DLP's and SXRD machines I viewed have no problem with the above scenes.
Only the JVC Line.
Even my Kuro that can not show 17/18/19 on a greyscale chart show the above shadow detail with ease.
It is something JVC is doing. Only Gamma A / gamma 1.8 / gamma 1.9 on the JVC will pull out the detail correctly. But overall Gamma A is very very low.
SOWK is offline
Old 01-20-2013, 03:10 PM - Thread Starter
SOWK's Avatar
Quoted: 475 Post(s)
Liked: 369
Kalvin1965s - do you have the Incredibles DVD?
If so, test this scene, can you see the individual pews like the overexposed pic?
I can see them on the JVC at gamma 1.8 / Gamma 1.9 / Gamma A.
But nothing close to a real 2.22.
SOWK is offline
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Yes, I understand. Lower is fine but if you can't get there then you can't get there. I didn't mean to imply (though I realize I probably did) that one should stop trying at ∆E of 3. That said, if one is using a profiled meter (by Chromapure or Calman) I don't think meter error is going to be a big deal.
Geof
Geof is offline
Old 01-20-2013, 03:22 PM
Quoted: 260 Post(s)
Liked: 161
Might still have it,but my son is 13 now and I think we got rid of most of the old discs now (he says they are too babyish for him to watch rolleyes.gif). I've got the Bond discs for sure though, so I'llhave a look at that scene if I can find it. However, my X35 is calibrated with the Lumagen, so it's cheating really, though I could bypass it and see if I can still see the detail in person, I can't take good photos as I only have a basic point and shoot 5mp Pentax.
@ Geoff I agre: I get as close as I can without spending hours over it, but if there is a greyscale point that is at 2.9dE I'll maybe try to tweak it down manually before running the colour gamut autocal. I'm really pleased with the D3 as it seems much more consistent as I can remeasure my TV the next day and get pretty much the same results. Of course projectors drift more quickly anyway, so in some ways it's a bit moot, but these days I just do a calibration at 100 hours, then maybe not until 400 hours (I did a calibration at 15 hours on the X35, but I fully expect it has drifted now that I'm near 100 hours).
Old 01-20-2013, 03:41 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Yeah, Kelvin with Grayscale I aim for a ∆E ≤ 1. My routine is to run just a grayscale/gamma auto cal then use Chromapure's Gamma module to manually tweak all 5% point to less than 1 ∆E...this usually goes pretty fast. I've found that the gamma/grayscale autocal gets things close but there are two things that fool it....first off, my projectors luminance is bouncing around at 100% (I'm hoping that next tiem I calibrate the lamp has settled down a bit). That results in "bouncy" gamma from about 75 to 95% -- Chromapure can't average the bouncing as well as I can by eye so I set it such that the average gamma is at my target (say 2.2). IOW....I adjust it so it's bouncing higher and lower then 2.2 by an equal amount. Likewise at lower stimulus levels (below 25% or so) it takes time to settle out (it takes progressively longer as the level is reduced). So I just watch and wait for things to stabilize...at 5% it may take minutes to get a consistently stable reading. When doing the manual tweaking I adjust both gamma and grayscale using the Lumagen remote so it usually takes but one pass to get both where i want them to be (if I had to do a lot a tweaking I'll take a 2nd pass). But I have found that by waiting for things to stabilize I get very consistent and repeatable results using my i1D3 Pro (it's a very nice meter) and my grayscale ramps look clean with no hint of tint.....Only then will I do a 125 pt auto cal.
Kelvin1965S likes this.
Geof
Geof is offline
Old 01-20-2013, 03:57 PM
Quoted: 260 Post(s)
Liked: 161
Sounds a good process to follow and not too disimilar to mine. I also find that 100% 'bounce' but I was only at 15 hours so it'll be interesting to see if it's better when I do my 100 hours calibration anytime soon. I hope the X55 I'm calibrating will have a good few hours on it too otherwise it could be a long one. I'm going to have a play with the JVC controls for custom gamma since he doesn't have the Lumagen so I'll have to have a practice first...
Old 01-20-2013, 04:40 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Yeah, 15 hours on mine as well. I'm probably close to a 100hrs now but I haven't looked at it recently. I have looked at the gray ramps (I just love having the Lumagen in the chain....no muss, no fuss.....anyway the gray ramps still looked excellent. I'm sure that gray ramps my RS55 would have not looked that nice after 100 hours...
have fun with the X55.....I'm glad I don't have to go the custom gamma route....eek.gif
Geof
Geof is offline
Old 01-20-2013, 05:43 PM
Schwa's Avatar
Liked: 1068
This worked great; thanks for the tip. Three clicks up on the Dark White Level setting got my gamma to 2.2 on the very low end -- just what I was looking to do without screwing around with custom gamma curves.
Schwa is offline
Old 01-20-2013, 06:15 PM
freebits's Avatar
Quoted: 16 Post(s)
Liked: 26
Do you use different color difference formulas?
CP use CIE94 while CM seems to use dE2000, Different color difference formula will result in different dE.
Btw, I run i1d3pro profiled against i1 pro and they were calibrated by the manufacturer a year ago. I don't think it has no such huge errors.
freebits is online now
Old 01-20-2013, 09:25 PM
Schwa's Avatar
Liked: 1068
dE2000 - I use what CalMAN is using. Having not seen the actual formulas I don't know how much of a difference CIE94 vs dE2000 actually makes, but CalMAN's targeted to produce dE's less than three, so I imagine the different dE formulas are roughly comparable or there would've been more mentioned about it on the forums.
Schwa is offline
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
