Offical JVC DLA-RS4810 Owners Thread - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1711 of 2092 Old 01-15-2014, 11:16 AM
Mike Garrett's Avatar
Quoted: 5658 Post(s)
Liked: 3620
Originally Posted by curlyjive View Post
1) I do have an i1Pro and calman and would be measuring and calibrating. Now, it may not present itself as a very noticeable on screen issue, other than measurements, so that is a factor as well. Still I am trying to get to the bottom of whether this is something most units are affected by. My RS40 measures very well (at least at 75% Stimulus), so I wonder if I would actually see the issue.
2) Good
3) Good
4) I'm not a fan of dynamic irises. And I'm pretty stuck on going Bstock because you get a much better value, thee is little year to year variation in most cases, you don't take a HUGE depreciation hit, and you still get a full warranty! Same reason I refuse to buy a brand new car and go with pre-certified cars that have a warranty
5) That is good to know. It also seems that the out of the box RGB measurements show much more red in the these lamps. I have to pull green and blue down like 40-50 clicks on my RS 40 (2 bulbs) in order to get good greyscale tracking. Having to pull much less green out would be a huge benefit to brightness. I realize there is lamp to lamp variance, but this seems to be a common observation for both respective models.
I have not been a DI fan either, but most of that comes from LCD with it's low native contrast. The DI implementation in Sony and this years JVC is very good and I would definitely use it.
mjgarrett100@gmail.com
Mike Garrett is online now
post #1712 of 2092 Old 01-15-2014, 12:19 PM
isisyodin's Avatar
Quoted: 35 Post(s)
I have a RS50 and a 4810. I've had 2 Epsons prior to the JVCs. No matter what model and brand you get, all projectors will have some sort of "issue". To me it's all about calibrating and enjoying what you have while you have it.
I wish I had more time to enjoy my gear
isisyodin is offline
post #1713 of 2092 Old 01-15-2014, 01:50 PM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
No doubt, all displays have idiosyncrasies or even flaws. It's knowing what they are and if they are small or something you can live with. I know of no perfect display, and if there is I certainly can't afford it!
I love my RS40. Is my calibration perfect, nope, but it's good enough. My Gamma has some errors, but I can't see the effect. My calibrated FtL with iris all the way open is only 8! Thats with a 100" 1.1 gain screen and 12 Ft throw. Biggest issue with the RS40 for me is reliability. So I am weighing upgrading vs. holding out for affordable 4K with comparable overall performance....question is how long will that be? No one knows for sure, but I'd wager 3 years at least until very good 4K projectors hit the 3-5k price range. Another year if, like me, you try and scoop up a deal on last years model.
That's where I am at weighing this decision. I've also tossed around the idea of looking for a used Sony 95es, but as I said I'd prefer not having a dynamic Iris. Even with it, I think the JVC still has the edge in black level and contrast.....question is would I be able to tell in my room! Decisions decisions!!!
curlyjive is online now
post #1714 of 2092 Old 01-17-2014, 10:34 AM
zachfine's Avatar
Originally Posted by ahmadka
Guys, do I have to get the PK-EM2 3D Transmitter to try out the 3D functionality of RS-46 ?
Also, are there are cheaper 3rd party 3D glasses which work with RS-46 ? ... Preferably something which also works with Optoma HD131Xe, since both can use RF for their 3D ?
EDIT: Sorry, I thought this was the RS-46 hangout ... Google's fault, not mine
I bought this IR emitter ($25), and two of these Xpand X103 3D glasses ($19/ea), and the combination works great for watching 3D content streamed from Netflix. With Blu-ray 3D I've run into a sync problem (video demo of problem), but it may be related to the chain of devices the signal passes through from disc to projector/emitter (PS3 > HT-S5300 > RF-WHD200) rather than the emitter and glasses.
zachfine is offline
post #1715 of 2092 Old 01-17-2014, 11:09 AM
zachfine's Avatar
Originally Posted by Seegs108 View Post
I'm just wondering if a few owners could do me a favor and check to see which firmware version is installed on your unit. If you go into the menu under Information it will list the firmware number there. I'm just curious if my unit is up to date. I do have an X55R. I'm not sure if that matters or if both the 4810 and X55R get the same firmware updates.
My firmware's 29.001. I bought it the projector as a refurb a week ago. I'd be happy to update it to whatever the latest is (presumably 29.004 or greater), but I can't find any mention of a firmware updater for this projector on jvc's site.
Can anyone confirm whether or not the RS4810 and X55R are the same projector with the same firmware? I've seen some occasional allusion to this on the net, but nothing that seems definite.
zachfine is offline
post #1716 of 2092 Old 01-17-2014, 12:14 PM
rhale64L7's Avatar
Quoted: 831 Post(s)
Liked: 327
Yes I would like to know this info also. I will check mine. Mine is 29.001
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
post #1717 of 2092 Old 01-17-2014, 12:24 PM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
Does anyone know what the fan noise in db is for the 4810 in normal lamp mode? It is not listed on JVC's page. The RS 40 is listed at 20db I think and I can't hear it at all unless I put my ear to it. I've read high lamp mode is louder on the 4810, but I won't be using that much if at all. I've also read that eshift can raise the noise floor?
post #1718 of 2092 Old 01-17-2014, 12:25 PM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
I don't see an update listed on JVC's site for the 4810...so was there never a firmware update or change for it? Makes you feel bad for the 4910 owners....
post #1719 of 2092 Old 01-17-2014, 02:14 PM
rhale64L7's Avatar
Quoted: 831 Post(s)
Liked: 327
^ Yeah I know. I just assumed there wasn't any firmware updates for the 4810.
post #1720 of 2092 Old 01-17-2014, 02:22 PM
Seegs108's Avatar
Quoted: 4229 Post(s)
Liked: 2102
My X55R was 29.004. I'm assuming that unless the firmware is making a major fix they won't release it to the public.
Seegs108 is offline
post #1721 of 2092 Old 02-02-2014, 01:19 AM
Robinson ------'s Avatar
One of the AVS guys told me there was no firmware updates at all for the 4810.
JVC rs4810 (115)
Pioneer Kuro-9gen (50)
Oppo 103d
Marantz sr7001
Klipsch rb81/rc62/rs52
Robinson ------ is offline
post #1722 of 2092 Old 02-02-2014, 07:22 AM
rhale64L7's Avatar
Quoted: 831 Post(s)
Liked: 327
I figured that. But since everyone was asking thought maybe I had missed something.
post #1723 of 2092 Old 02-02-2014, 09:48 PM
colleycol's Avatar
Quoted: 23 Post(s)
Guys, anything to key on as far as settings for the 4810? I am having a hard time with blacks and grainy looking video.
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #1724 of 2092 Old 02-02-2014, 10:03 PM
ScottJ's Avatar
Quoted: 298 Post(s)
Liked: 152
Turn down the three settings on the MPC menu page. I don't know about the blacks but that might fix the grainy looking video.
ScottJ is offline
post #1725 of 2092 Old 02-03-2014, 08:31 AM
ezrangel's Avatar
Quoted: 21 Post(s)
I have a 4810 for a few months and calibrated it after 100 hours. Now, I am about to re-calibrate it and was wondering... should turn off eShift for calibration or just leave it on and calibrate using "film mode" (which I use 100% of time)? What about Darbie?
Sorry for bad english...
ezrangel is offline
post #1726 of 2092 Old 02-03-2014, 09:42 AM
ScottJ's Avatar
Quoted: 298 Post(s)
Liked: 152
Leave them both on. Generally you want to calibrate what you watch.
ScottJ is offline
post #1727 of 2092 Old 02-04-2014, 02:56 PM
ezrangel's Avatar
Quoted: 21 Post(s)
Ok! Thanks, Scott.
ezrangel is offline
post #1728 of 2092 Old 02-05-2014, 05:03 PM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Gamma issue.... I see the users of 4810 were having issues with the Gamma. I was able to get a good gamma curve on a RS60 by lowering the brightness factor. Not exact sure that the control is light factor. But there are controls that allow you to set the contrast and brightness(black level), I think those controls are called Dark an Light, without using the actual brightness and controls. I haven't tried this on my own 4810 yet.
avsform1 is offline
post #1729 of 2092 Old 02-06-2014, 01:25 PM
CPat's Avatar
Wondering if anyone has experienced a similar issue. I have the X55 and in the last few weeks the remote control power will not turn on the projector. The red light on the front of the projector is on but will not turn on (turn green). The only solution I have found is to unplug the projector completely and wait 10-15 seconds and plug back in. I contacted JVC and they are suggesting I send it in for repair.
Just wondering if anyone has had a similar experience in lieu of shipping it for repairs.
Thanks, Chris
CPat is offline
post #1730 of 2092 Old 02-06-2014, 04:46 PM
Liked: 3620
We have a limited amount of B-stocks coming in.
post #1731 of 2092 Old 02-07-2014, 10:24 AM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
I'm considering one on the bstock 4810 (and maybe even the sony 95es) I have an RS40 that I am happy with PQ wise and I only care about 2D blu ray movies. I hate to upgrade now with 4K around the corner, though I think it will be a few years until 4K hits my $3K max budget. I can't afford a new PJ every year, but I am concerned the RS40 will not last that long.
Does anyone have a PQ comparison between the RS40 and the 4810, or even the Sony 95ES? Or opinions on what you would do?
post #1732 of 2092 Old 02-09-2014, 09:29 PM
raullopez1234's Avatar
ihave my 4810 for sale in the classifieds .I will lower my asking price 25$ a day untill it sells,or untill it reaches 3k.
raullopez1234 is offline
post #1733 of 2092 Old 02-10-2014, 09:38 AM
Liked: 3620
The JVC B-stocks are now sold.
post #1734 of 2092 Old 02-10-2014, 04:25 PM
jbn008's Avatar
Quoted: 100 Post(s)
Liked: 48
I went from the rs45 to the rs46 to the vw95 to the rs55 to the 4810. The Sony's nice, but I prefer the 4810 for it's better (non auto iris) contrast and blacks.
Headless Petie
jbn008 is offline
post #1735 of 2092 Old 02-10-2014, 04:27 PM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
Would you say there was much different in the 2d picture quality between the rs45 and the 4810?
post #1736 of 2092 Old 02-10-2014, 04:33 PM
jbn008's Avatar
Quoted: 100 Post(s)
Liked: 48
- a little bit brighter
- contrast a little better
- much sharper (I'm sure this is mostly due to the eshift, but it's worth the upgrade for this alone imo)
- ISF calibration (for someone who would take advantage of this with a professional)
Headless Petie
jbn008 is offline
post #1737 of 2092 Old 02-10-2014, 04:33 PM
Seegs108's Avatar
Liked: 2102
I've made that jump before. I would say there is small but noticeable jump in PQ especially when you enable e-shift. You also get access to the CMS which will enable you to get more accurate color than the RS45. There isn't a night and day difference but overall you will see a small one.
Seegs108 is offline
post #1738 of 2092 Old 02-10-2014, 04:37 PM
jbn008's Avatar
Quoted: 100 Post(s)
Liked: 48
If you're looking for something to hold you over until 4k, the lamp upgrade (New Illumination System: 230W NSH lamp & new power supply Up to 4,000 hour lamp life/low lamp mode) in the 4810 might be reason enough.
Headless Petie
jbn008 is offline
post #1739 of 2092 Old 02-10-2014, 04:46 PM
curlyjive's Avatar
Quoted: 504 Post(s)
Liked: 223
I actually have an rs40 and a darbee. Color tracking on my sample is actually pretty good. I calibrated grayscale and gamma and honestly I'm still pretty happy with it. More worried about the reliably of it for another few years until 4k is around $3k. Otherwise I'd hold out for 4k.
I missed out on this round of b stock rs4810's. I just couldn't decide what do to. There may be more at some point. It was hard to justify replacing something that still looks great out of fear that it might break. But doing so resets my budget to $0 where as if I keep saving, more $$ for a 4k unit.
Hard choice to make. Pretty much a gamble either way.
post #1740 of 2092 Old 02-10-2014, 05:41 PM
johng's Avatar
Quoted: 22 Post(s)
I purchased a b-stock from AVS. It was an upgrade from the RS45 and we could not be happier. It was definitely an upgrade in picture quality. Jump on it while you can
Good Viewing,John G  JVC DLA-RS4810 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 disc player, Darbee Darblet, Onkyo TX-NR708 Receiver/Processor, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,  Adcom & Yamaha Amps
johng is offline
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
