Offical JVC DLA-RS4810 Owners Thread - Page 61 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1801 of 2113 Old 05-09-2014, 09:23 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
Sent from my SCH-I545 using Tapatalk
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
post #1802 of 2113 Old 05-09-2014, 09:34 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
post #1803 of 2113 Old 05-09-2014, 09:35 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
These actually look yellowish in real life.
post #1804 of 2113 Old 05-10-2014, 12:56 PM
DavidHir's Avatar
Quoted: 2049 Post(s)
Liked: 1674
Ron or anyone else,
Do you notice any very subtle swirling waves in the picture on a 100 IRE pattern? It almost looks like it's from the front exhaust of the RS4810, but not sure. I start to see them after the projector has been on for 5-10 minutes. My projector does not get terribly warm, however, the one side (same side as lamp) does get warmer than the opposite side. That side of the exhaust port is almost about 8" off the corner of the wall. I really cannot see this effect during real images, but just curious what I am seeing and if it means anything.
DavidHir is online now
post #1805 of 2113 Old 05-11-2014, 01:12 AM
DavidHir's Avatar
Liked: 1674
Perhaps I am just seeing the front heat exhaust getting in the view of the lens while projecting.
post #1806 of 2113 Old 05-11-2014, 05:55 AM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
That's the only thing I can think of. Maybe because there is a wall there to the side of it. The vents angle out so to avoid that. But if there is a wall there it would bounce off that wall and then go in front of the projected image.
post #1807 of 2113 Old 06-10-2014, 09:08 AM
Home Theater Lover
Craig Peer's Avatar
Quoted: 4124 Post(s)
Liked: 4212
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #1808 of 2113 Old 06-10-2014, 09:30 AM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Few Quick Questions:
1) projector reviews reports a yellow tint on skin tones, even after calibration. Is this something you all are seeing?
2) What does the Axis setting in the CMS do? Not a typical CMS control. Do you use it or leave it alone when calibrating? I will be using Calman 4.x and an i1Pro for reference.
3) As a starting point I was thinking of using user1, but what color profile is best to start with?
4) Does the info screen show the frame rate as older models did (i.e. 1080p24)
5) What HDMI setting is recommend. I have used extended on my previous JVC's and adjusted brightness and contrast accordingly.
curlyjive is offline
post #1809 of 2113 Old 06-10-2014, 10:27 AM
DavidHir's Avatar
Liked: 1674
My unit was calibrated by Chad B, so I am not sure of all of the CMS adjustments. He did use the Stage profile on mine.
Skin tones look excellent and natural. I've never seen any kind of yellow or unnatural look. Very good color, overall. My basis for comparison would be my Panasonic 65" VT60 plasma which has reference quality color (also calibrated by Chad).
post #1810 of 2113 Old 06-10-2014, 12:32 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
No help with the pictures? Just wondering what to even call it when I call for service.
post #1811 of 2113 Old 06-10-2014, 05:20 PM
Schwa's Avatar
Quoted: 1122 Post(s)
Liked: 1172
Vertical yellow streaking??
Schwa is offline
post #1812 of 2113 Old 06-10-2014, 05:32 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
I noticed it in a all blue field also. This is what has me stumped.
post #1813 of 2113 Old 06-10-2014, 05:43 PM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
You've been JAMMED!
ScottJ is offline
post #1814 of 2113 Old 06-10-2014, 06:16 PM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Thanks! I've seen others use the stage color profile as a starting point for cms calibration. Anyone else use this, or recommend another?
Would it be best to measure each color profile using user 1 and see which has the lowest errors or widest gamut points?
post #1815 of 2113 Old 06-10-2014, 06:24 PM
DavidHir's Avatar
Liked: 1674
I do recall he checked/ran the numbers on each profile and Stage was the best starting point.
post #1816 of 2113 Old 06-10-2014, 07:45 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
I think mine was stage also. Mine was calibrated by zombie10k here on avs.
post #1817 of 2113 Old 06-10-2014, 08:30 PM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Anyone notice the yellowish tint on skin tones that projector reviews noted? Hoping this is not the case.
post #1818 of 2113 Old 06-11-2014, 02:57 AM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
No yellowish skin tones here.
post #1819 of 2113 Old 06-12-2014, 05:47 AM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
Originally Posted by ScottJ View Post
You've been JAMMED!
Yep
post #1820 of 2113 Old 06-13-2014, 09:42 PM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
Well I broke down and snagged a used 4810 here on the forum. I'm currently using a Mits HC9000 that I've racked up a whopping 200 hrs on lol. I'm hoping this will be a noticeable step up over the Mits (which honestly I was pretty happy with).
Only thing I'm worried about is the brightness. I'm firing onto an AT 1.0 gain screen from 20' away. It's a dedicated theater but I'm hoping I'm not taking a step back in brightness compared to the Mits, as it was right on the edge IMO.
I do like the fact my AT lens mount will bolt right up to the JVC, whereas with the Mits I had to mount it in front of the pj.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #1821 of 2113 Old 06-14-2014, 06:23 AM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Can someone check something for me please.
I noticed last night that my horizontal lens shift has a bit of take up before it starts moving. So if you press and hold left or right, you hear the motor start but it takes a second for the lens to move. Where I notice this is when I need to tap the left or right buttons and I hear the motor but there is no movement until like 15 clicks. Doesn't do this vertically. My rs40 didn't have any take up.
Wondering if this is normal.
post #1822 of 2113 Old 06-14-2014, 08:10 AM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 99
I have been running my 4810 on high lamp for about 400 hrs now on a 10 foot wide seymour xd screen in a dedicated theater and it is plenty bright for me. The newer bulb lasts and lasts and I figure if I have to replace one every 1000 hrs it will be money well spent. Iris is at -13 I think.
One of the best improvements for me came when I moved from 2.2 to 2.4 gamma (and when I finally started using my panamorph 480). With the panamorph I was able to turn the e-shift off because of the extra resolution the lens provided, getting a more realistic, less digital looking image. Turning off eshift dramatically sharpened the picture.
edfowler is offline
post #1823 of 2113 Old 06-14-2014, 08:18 AM
Quoted: 441 Post(s)
Liked: 507
I really hate running in high lamp mode, or being required to. My screen is also 10' wide (Seymour AV), and I have a very long throw. I don't know, I might end up sticking with the Mits. It is very sharp with good motion and the DI isn't very noticeable. It certainly isn't perfect, but I'd give up PQ in a couple areas for a bright sharp picture, which it does well.
I just don't get why after years and years JVC can't figure out how to get more brightness. Even a couple hundred lumens would make a difference. It seems we havn't seen much improvement since the days of my RS20.
post #1824 of 2113 Old 06-14-2014, 10:29 AM
DavidHir's Avatar
Liked: 1674
I've never experienced that before.
post #1825 of 2113 Old 06-14-2014, 11:29 AM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Hmmm. Can anyone test this. Just got mine and am Trying to find out if it's just a quirk within spec or a problem.
post #1826 of 2113 Old 06-14-2014, 12:29 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
mine does this. it is like a fraction of a second delay before it starts actually moving. makes it a little more difficult to setup.
post #1827 of 2113 Old 06-14-2014, 01:44 PM
DavidHir's Avatar
Liked: 1674
I do get a fraction of a delay, but never had to wait for movement up to 15 clicks However, just make sure after performing a click, you give it time to move. Wait about a second or so.
post #1828 of 2113 Old 06-14-2014, 01:54 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
Definitely not up to 15 clicks. One click and a little delay
post #1829 of 2113 Old 06-14-2014, 02:14 PM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Maybe I'm wrong about the number of clicks. I say click to mean one button press at a time for fine adjustment vs press and hold to make larger moves.
But the behavior I'm talking about is most noticible when you press and hold left or right. When I do that, I hear the motor start and then about second later it starts to move. Like there is some slack before the lens moves. Vertical does not do this, nor does my old rs40.
So do you guys get that delay when you press and hold horizonatally, but your vertical is more quick to move?
Hoping this is normal and others have the same thing.
post #1830 of 2113 Old 06-14-2014, 07:09 PM
rhale64L7's Avatar
Quoted: 874 Post(s)
Liked: 355
Yes I do. It causes me to overshoot my alignment a lot
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
