Offical JVC DLA-RS4810 Owners Thread - Page 63 - AVS | Home Theater Discussions And Reviews
post #1861 of 1881 Old 11-21-2014, 03:30 PM
DavidHir's Avatar
Quoted: 427 Post(s)
Liked: 587
Correct, there was never a firmware update for this projector. HDMI 1 is fine on my RS4810, but I only using 1080p. However, the handshake can be tricky if I don't follow a certain order as I always turn on the projector, then AVR, then Blu-ray player.
DavidHir is online now
post #1862 of 1881 Old 11-21-2014, 04:29 PM
tqlla's Avatar
Originally Posted by ScottJ View Post
Beats me.
I had a similar HDMI issue. HDMI2 worked better. Since I only needed one input, I just used HDMI2 for everything.
What? So this HDMI1 issue is a common problem? Thats a bummer. Well at least I have a 4 year Best Buy warranty. If this isnt addressed via firmware by then, I will have to take it in for warranty repairs.
I actually use both of my HDMI's because my AVR doesnt pass 3D(AVR347). My Blu ray player has 2 outputs(Panasonic BDT500). I havent upgraded my AVR because the new HKs have lost a lot of weight and power.
tqlla is offline
post #1863 of 1881 Old 11-21-2014, 04:47 PM
ScottJ's Avatar
Quoted: 158 Post(s)
Liked: 88
There's essentially zero chance of a firmware update for this model. You're going to work around the problem for 4 years and only then try to fix it?
I don't know if HDMI1 is a "common" problem. HDMI issues are common for all projectors because of the long cable runs typically required. I know I tried three different 50' cables to find the one that worked best for my setup. HDMI1 was usable with some of those cables but HDMI2 always worked better.
How long is your cable run? Have you tried a Redmere cable from Monoprice? That's what I settled on and they are very popular for longer HDMI cables.
ScottJ is online now
post #1864 of 1881 Old 11-21-2014, 05:31 PM
tqlla's Avatar
I am running 2 cables, 1 Monster 1000 25ft cable(Goes from the AVR directly to the Projector), and a Monster 1000 16ft cable(That terminates at the wall).
I am having a problem with my AVR run, which uses 720P for its menu, and my FIOS box uses 720P/1080i. Its possible that the cable got damaged when I was putting the drywall up. The picture becomes split on JVC-HDMI1, but if I take the cable right out of JVC-HDMI1 and plug it into JVC-HDMI2.. it works fine. The exact same cable and components work fine on JVC-HDMI2, but not on JVC-HDMI1
I know people hate monster and all, but the inwall Monoprice cable had a terrible jacket and puts a lot of stress on an HDMI port. Plus I dont mind spending, when its a product going in the wall.
tqlla is offline
post #1865 of 1881 Old 11-24-2014, 08:04 AM
tqlla's Avatar
It looks like the HDMI1 port is slightly looser fitting than the HDMI2 port. using a coupler and a newer HDMI cable(with clips on both sides) fixes the issue.
ScottJ likes this.
tqlla is offline
post #1866 of 1881 Old 11-24-2014, 09:51 AM
rhale64L7's Avatar
Quoted: 360 Post(s)
Liked: 74
Glad you figured it out.
rhale64L7 is offline
post #1867 of 1881 Old 12-16-2014, 12:30 PM
ezrangel's Avatar
Guys, does the RS4810 work with the autocal function of the Calman5 software? Via RS232 or LAN?
Is it worth the extra $100?
Sorry for bad english...
ezrangel is offline
post #1868 of 1881 Old 12-17-2014, 04:49 AM
Schwa's Avatar
Quoted: 344 Post(s)
Liked: 330
Yes, autocal works fine. IMHO it was worth the extra $100.
ezrangel likes this.
Schwa is offline
post #1869 of 1881 Old 01-08-2015, 04:46 AM
ezrangel's Avatar
Sorry, I took so long to thank you for your answer but Thanks!
I got the Calman Control. Autocal really is great. It got the grayscale and the gama perfectly! Of course, I had the same old issues with the undersaturated greens and it seems thereĀ“s no workaround it besides buying an external video processor like a Lumagen.
ezrangel is offline
post #1870 of 1881 Old 01-17-2015, 09:40 AM
holmern's Avatar
Are anyone else having IP control issues with their projector? I cannot get control by using IP commands. I have triple checked the IP address and tried using DCHP as well instead of static. I can ping the projector just fine, but if I try to send commands its no dice. I also tried using their iOS app to gain control, but app states that it cannot establish connection with the IP address (I get a reply when pinging the same address).
I also tried a factory reset from the service menu to see if that helped. Any information would be appreciated.
Edit: Forgot to mention that ECO mode is set to "OFF"
holmern is offline
post #1871 of 1881 Old 01-18-2015, 12:14 PM
avsform1's Avatar
Quoted: 12 Post(s)
I always had issue with Calman and IP control, therefore I always use RS232. Control with the IPHONE app works fine. Note that I hadn't tried using it since Calman 5.3
avsform1 is offline
post #1872 of 1881 Old 02-19-2015, 08:09 AM
zachfine's Avatar
you can use this kit on both the JVC and the Optoma:
http://www.amazon.com/EStar-America-ESG6100-RF-3D-Starter/dp/B00D39AUCI/ref=sr_1_8?s=electronics&ie=UTF8&qid=1385312802&sr =1-8&keywords=RF+3D+glasses
glasses are not that cheap though depending on your price range, the replacements are in the $50 range, I don't know of any inexpensive RF glasses that work with this transmitter.
Does this kit work with standard JVC RF 3D glasses, or does it require one to use a different line of glasses? Is its emitter functionally equivalent to the JVC RF emitter?
In the photo on Amazon, it kind of looks as though the emitter features a line of IR LEDs (and the words "IR-Sync" are visible on it). Does it emit both RF and IR?
Thanks for any info.
zachfine is offline
post #1873 of 1881 Old 02-19-2015, 09:07 AM
zombie10k's Avatar
Quoted: 690 Post(s)
Liked: 538
hi, that kit is proprietary and not compatible with the JV RF glasses. The transmitter is RF output only but certain kits do include the IR receiver in order to use the original IR JVC transmitter + this RF transmitter as well.
check out this inexpensive kit. it says Mitsubishi but it works perfect with the JVC's. The RF transmitter that is included works with the JVC RF glasses as well.
http://www.amazon.com/EX105BT-Shutte...dp/B009ZW7SR2/
zombie10k is online now
post #1874 of 1881 Old 02-28-2015, 10:30 AM
CarsandCigars's Avatar
Best place to get replacement bulb?
How many of you have replaced the bulbs on your 4810? I am coming up near the end of life on my original and am getting ready to buy a new one, but not sure the best place to purchase it online. It seems like when I google PK-L2312u to find replacements, bulbs show up that end in UP or UG, so I fear they are not truly OEM replacements, so I am hesitant to order.
CarsandCigars is offline
post #1875 of 1881 Old 02-28-2015, 11:14 AM
ScottJ's Avatar
Quoted: 158 Post(s)
Liked: 88
The best place is right here at AVS. They are sure to have OEM bulbs.
post #1876 of 1881 Old 02-28-2015, 01:56 PM
Scott, so I noticed the one on AVS is also listed as a PK-L2312UP, where the owner's manual lists the part number without the P on the end. Any idea what the difference is?
post #1877 of 1881 Old 02-28-2015, 02:24 PM
ScottJ's Avatar
Quoted: 158 Post(s)
Liked: 88
My guess is, the difference is the same as the difference between the X55 and RS4810 -- same PJ, sold through different sales channels.
Also see here.
post #1878 of 1881 Old 02-28-2015, 03:15 PM
Also see here.
Makes sense. Just didn't want to order the wrong thing and then have to deal with returning it and all that fun stuff. I'll be placing my order with AVS this weekend. Any benefit for you if I say you referred me?
post #1879 of 1881 Old 02-28-2015, 03:19 PM
ScottJ's Avatar
Quoted: 158 Post(s)
Liked: 88
Haha no. I'm just a happy customer. Call Mike or Craig (they post regularly here) and tell them what PJ you have and they'll hook you up with the right bulb.
post #1880 of 1881 Old 03-01-2015, 06:08 AM
RobZ's Avatar
Quoted: 79 Post(s)
Liked: 24
I posted this in the RS49 thread and thought I'd ask here.
For those that are using a Panamorph lens or anyone who may know of options, what are RS48 owners using to mount the lens and transport? I currently have the UH480 and manual sled mounted on my RS20 using the steel AK8J plate.
RobZ is online now
post #1881 of 1881 Unread Today, 09:00 AM
dropzone7's Avatar
Quoted: 87 Post(s)
Liked: 84
I have had my X55 on a Chief mount and Panamorph JVC plate (not sure of model #) with powered sled and lens mounted at the front of that plate just the way it was made to. Works perfectly.
dropzone7 is online now
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
