Offical JVC DLA-RS4810 Owners Thread - Page 67 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #1981 of 2113 Old 05-29-2016, 01:30 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Well...I'm trying to follow all the "details" in the HD Fury Thread and the Posts by Manni01 as he too is looking for a solution like me .
I've not quite finished the entire Thread but this Post caught my eye today...
"At the moment, I have a JVC X500 projector, which doesn't have native 4K panels even if it accepts native 4K content and displays it in faux-K using e-shift. As it doesn't support HDCP 2.2 or HDR either, I would like to get the 4K24 HDR 10bits BT2020 4:2:0 (or 4:4:4 if chroma is already upscaled by the player, such as the Samsung) from a UHD Bluray player and convert it to 2K24 8bits 4:4:4 SDR for my 1080p display. This would allow to make use of the fact that the chroma resolution in UHD Bluray 4:2:0 content is 1080p, hence this would give us an excellent 1080p 4:4:4 quality in 8bits, which should be fine with a good dithering as we're not using BT2020 or PQ Gamma. On a screen size such as mine (88" diag 16/9), even from my fairly close 1.2SW sitting distance, I would much rather take a native 1080p 4:4:4 content, even at 8bits (not even using eshift to upscale it) than a 4K resolution than needs eshift to work, causing a loss of sharpness on my non native 4K display."
This was a Post by Manni01 to HDFury for suggestions to the HD Fury Integral Product . This is why I'm a little excited by this . The Company is taking all kinds of suggestions and implementing them on a weekly basis . They are also intending on building a Scaler into the Integral at a future date .
I'm just looking for a solution to not being able to Upgrade without winning the Lottery . This Tech looks promising .
Scott......................
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
post #1982 of 2113 Old 05-29-2016, 01:35 PM
DavidHir's Avatar
Quoted: 2047 Post(s)
Liked: 1674
Manni is now using an RS500.
DavidHir is offline
post #1983 of 2113 Old 05-29-2016, 02:47 PM
ScottJ's Avatar
Quoted: 318 Post(s)
Liked: 162
It sounds like he's asking HD Fury to make some changes to their product to enable this. It would give him double the chroma resolution vs standard Blu-Ray.
That would be advantageous on paper, but could you really see any difference on actual program material? I seriously doubt it.
DavidHir likes this.
ScottJ is offline
post #1984 of 2113 Old 06-02-2016, 06:09 PM
CHUCKCHILLOUT's Avatar
Quoted: 41 Post(s)
Adjusting Convergence,
So I recently acquired an X55RBU. I have seen that convergence is a subject talked about quite a bit. Never having a LCD, LCOS display, I have never witnessed the shortcomings of this technology, nor would I know how to properly adjust it. Can anyone give me any pointers or a guide on how to properly assess or adjust convergence?
Thank You
CHUCKCHILLOUT is offline
post #1985 of 2113 Old 06-03-2016, 06:09 AM
DavidHir's Avatar
Liked: 1674
You really don't want to adjust convergence as you lose pixel resolution unless you move one full pixel...but most units don't require that large of a change. You can do the small zonal adjustments if an area is really bad and you see color fringing in content - so it could be worth the compromise of less resolution. But in general, it's best to just leave it unless it becomes noticeable and distracting on content.
DavidHir is offline
post #1986 of 2113 Old 07-02-2016, 12:08 PM
Quoted: 41 Post(s)
So for a couple of weeks I have tried IRIS @ -15, the lamp I have has 1600 hours on it. Iris @ -7,or -8 seems a lot better, this is on low lamp power mode. If I buy a new lamp, can I go back to -15 iris and still have a comparably bright image to -7, -8? Screen is 1.1 gain, dark walls, blacks out curtains etc. Thanks.
post #1987 of 2113 Old 07-03-2016, 07:27 AM
DavidHir's Avatar
Liked: 1674
A new lamp will allow you to obtain the same light output you had before...until it starts to age again.
DavidHir is offline
post #1988 of 2113 Old 07-05-2016, 12:17 PM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
Anyone have a step by step lens memory setup 16:9 and 2.35 on a 2.35 screen?
tony4k
tbase1 is offline
post #1989 of 2113 Old 07-05-2016, 12:23 PM
DavidHir's Avatar
Liked: 1674
I'm using lens memory with my 2:35 screen. What do you mean "step by step"?
DavidHir is offline
post #1990 of 2113 Old 07-05-2016, 12:58 PM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
getting the 16:9 to fit a scope screen. Is this done via zooming and masking the sides?
tony4k
tbase1 is offline
post #1991 of 2113 Old 07-05-2016, 01:06 PM
DavidHir's Avatar
Liked: 1674
Yes, it's done my zooming and then saving the memory. I have three zoom memories: scope, 1:85, and 1:78.
I don't bother masking for 16x9 content, but a number of people do.
DavidHir is offline
post #1992 of 2113 Old 07-07-2016, 07:21 AM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
As a old A-Lens owner I always fit the 16:9 vertical and fit the horizontal with the lens to a scope screen. With that being said, should I zoom the entire screen and mask all four sides?
tony4k
tbase1 is offline
post #1993 of 2113 Old 07-07-2016, 12:02 PM
DavidHir's Avatar
Liked: 1674
I'm not sure regarding the A-Lens. What are you trying to accomplish with it? I find just using the zoom method works great.
DavidHir is offline
post #1994 of 2113 Old 08-15-2016, 08:47 PM
Jim CL's Avatar
I just posted this in the general $3000.00+ forum, but found a dedicated area here, and ham hoping someone may know something:
I purchased a JVC DLA-RS4810 projector in September of 2013 and it has been a great performer. A few months ago, I had to replace the lamp (thankfully at the time I purchased it JVC was including a new spare lamp). Everything has been perfect since then until tonight. When the projector came on there was a bluish cast to all the highlighted and detailed areas of the picture. Everything else, the sharpness, the other colors, is perfect. What happened?
I just noticed that my warranty is good for three years, so at least this happened ahead of that, but I have no idea what's going on. Any expertise or assistance would be greatly appreciated. Thank you.
JC
Jim CL is offline
post #1995 of 2113 Old 08-16-2016, 09:35 AM
DavidHir's Avatar
Liked: 1674
It sounds like something with the panel/blue chip. I assume it happens on all sources?
DavidHir is offline
post #1996 of 2113 Old 09-12-2016, 05:23 AM
Quoted: 1617 Post(s)
Liked: 414
RS4810 Gamma and 4K Profile Issues
I had been using an x30 for a couple of years, and recently picked up a used RS4810 supposedly for an upgrade. Unfortunately there are two issues with it that I cannot resolve:
1. The projector is very dim - my light meter shows about 1/3 of the brightness of the x30, both running in the default Cinema mode. The problem persisted even after replacing the lamp with a known good one, and doing a factory reset. Finally, I noticed that setting the 4K Profile to Off would give me the normal brightness at 100% White. Does that make any sense? I can't find any discussions on the forum regarding the 4K profiles affecting the brightness.
2. Even with the 4K Off and the projector running at normal brightness for 100% white, the blacks are severely crushed. HCFR shows a gamma of 3.6 at the low end, and 1.2 at the high end. I was able to calibrate it to 2.2, but that involves some very drastic adjustments of the custom gamma curve, and I'm concerned about posterization that this may have caused. There is a JVC Auto Calibration program that works with newer (or higher) JVC models, which would largely take care of this in the firmware, but the program does not work with the RS4810.
[Follow-up EDIT 9/22/2016]: The post-calibration results are close to perfect, see post #2005. The black crush is completely gone with no trace of posterization that I was previously concerned about.
Any help on how to address these issues would be greatly appreciated.
Dominic Chan is online now
post #1997 of 2113 Old 09-12-2016, 05:55 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
First question. Have you played with the iris?
Sent from my SM-G925V using Tapatalk
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is offline
post #1998 of 2113 Old 09-12-2016, 05:56 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
This is not a known problem with these projectors. So something is amiss
post #1999 of 2113 Old 09-12-2016, 05:57 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
Also how about your settings in your player?
post #2000 of 2113 Old 09-12-2016, 07:46 AM
DavidHir's Avatar
Liked: 1674
You can use Calman on the RS4810, but I don't think it will address your issues. Turning eshift on or off makes no difference for brightness on my unit.
DavidHir is offline
post #2001 of 2113 Old 09-12-2016, 09:46 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
Mine either.
post #2002 of 2113 Old 09-22-2016, 04:41 AM
tibz35's Avatar
Hey Everyone,
Bought this unit used, and the one issue I have is that with the eshift turned on, the lamp dims significantly. The seller of the unit was honest about this, but I'm hoping there is a way I can fix this issue. Has anyone encountered this before with 4k eshift engaged?
tibz35 is offline
post #2003 of 2113 Old 09-22-2016, 05:17 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
Originally Posted by tibz35 View Post
Hey Everyone,
Look a few posts before yours. That person has the same problem. Pm him or ask in here what he has found.
I know that mine doesn't exhibit this problem. So don't know what to say.
post #2004 of 2113 Old 09-22-2016, 06:28 AM
tibz35's Avatar
Interesting...I actually bought the unit from Dominic. Didn't realize there was the other issue with the black level.
tibz35 is offline
post #2005 of 2113 Old 09-22-2016, 07:23 AM
Liked: 414
There is no issue with black level. The "crushed black" I mentioned in the previous post was pre-calibration. I'm attaching the results after calibration here; they are close to "textbook perfect".
ID:	1676105   Click image for larger version
ID:	1676113   Click image for larger version
ID:	1676121   Click image for larger version
Edward Chen likes this.
post #2006 of 2113 Old 09-22-2016, 07:32 AM
tibz35's Avatar
Originally Posted by Dominic Chan View Post
There is no issue with black level. The "crushed black" I mentioned in the previous post was pre-calibration. I'm attaching the results after calibration here; they are close to perfect.
Excellent thank you sir! (Whew!)
tibz35 is offline
post #2007 of 2113 Old 09-22-2016, 08:01 AM
rhale64L7's Avatar
Quoted: 872 Post(s)
Liked: 355
Did you ever figure out what was causing the the e-shift brightness drop?
post #2008 of 2113 Old 01-05-2017, 05:39 PM
makaveddie81's Avatar
Quoted: 509 Post(s)
Liked: 278
Can someone provide a proven and reliable source for replacement lamps for this PJ?
I googled the model number but get results from stores I've never heard before (with varying prices) and the one sold on Amazon, according to some reviews, is not an authentic JVC bulb.
JVC DLA-RS4810
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-151FD
Pioneer Kuro PRO-111FD
Pioneer Kuro PDP-5020
makaveddie81 is offline
post #2009 of 2113 Old 01-05-2017, 09:13 PM
JackB's Avatar
Quoted: 576 Post(s)
Liked: 102
Mendtronics. Designated JVC repair station. Around $200 for replacement housing w/bulb.
Jack
JackB is offline
post #2010 of 2113 Old 01-15-2017, 12:40 AM
Quoted: 509 Post(s)
Liked: 278
I'm in the process of purchasing either an rs40 or an rs4810. The price difference between the two is around 700 bucks. My question is, is the image quality/black level improvement of the 4810 over the rs40 worth an extra 700 bucks or should I go with the rs40 and save myself that extra cash.
I own multiple Pioneer Kuros and have been spoiled by their black level, color and natural picture so looking for something that produces similar image quality and black level.
JVC DLA-RS4810
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
