Offical JVC DLA-RS4810 Owners Thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #2071 of 2095 Old 02-13-2017, 02:44 PM
Quoted: 1332 Post(s)
Liked: 342
Originally Posted by makaveddie81 View Post
That was my gut feeling initially before I started seeking answers online. It will be a fun and educational experiment to compare both screens, though.
Actually by low gain I meant a so-called "negative gain" one, I.e. < 1.0.
It may be obvious that a lower gain screen will produce darker blacks along with a darker overall picture, but I'm referring to the case where the projector is re-adjusted to produce the same luminance on the screen. Even then the black will still be darker (and that was not obvious to me initially).
makaveddie81 likes this.
Dominic Chan is online now
post #2072 of 2095 Old 02-13-2017, 05:36 PM
makaveddie81's Avatar
Quoted: 481 Post(s)
Liked: 273
Interesting. I'd have to find a negative gain floor pull up screen. I think DNP makes a floor pull up Supernova screen, but it's only 80 inches. I think a 1.2 gain 90 inch screen is a good sweet spot for size / blacks.
Pioneer Kuro KRP-500M
Pioneer Kuro PRO-141FD
Pioneer Kuro PRO-111FD x 2
Pioneer Kuro PDP-5020 x 2
makaveddie81 is offline
post #2073 of 2095 Old 02-13-2017, 06:22 PM
DavidHir's Avatar
Quoted: 1774 Post(s)
Liked: 1387
You might also try to get screen samples if they are offered.
DavidHir is offline
post #2074 of 2095 Old 02-14-2017, 01:16 AM
Quoted: 481 Post(s)
Liked: 273
Delivery estimate is now Monday even though it's Amazon Prime. Sigh.
post #2075 of 2095 Old 02-20-2017, 12:51 PM
Quoted: 481 Post(s)
Liked: 273
I was able to perform extensive testing and measurements on both screens and I'm still torn on which one to keep.
The candidates are an 87 inch 1.3 gain Celexon Mobile Professional Plus and a 90 inch 2.2 gain Da-Lite Deluxe Insta-Theater. Calman Enthusiast and an i1 Display 3 Pro were used for all measurements.
With regards to black level, the Celexon wins hands down according to my eyes and my meter. On an all black field, my meter was unable to get a read on the Celexon, meaning that it was below its .001 threshold. The Da-Lite measured .0022. On later readings, they both measured .0022, so not sure what happened there.
As far as brightness goes, with the iris fully closed and contrast at 0 using Film picture mode and HDMI Standard, the Celexon measured at 12ftl on an all white field. The Da-Lite was around 18ftl under the same conditions and seemed much too bright for my taste.
I attempted to perform a calibration on each screen, but I'm positive that the light being reflected by the walls was affecting my readings, as I could not get the grayscale remotely close to linear. Gamma was even worse, as even with the 2.4 preset, it measured around 1.9 in low to medium stimulus, then dipped to 1.0 on high end. I used full fields for measurements, not sure if window patterns are preferred for projectors.
With content, the Celexon definitely had a more plasma like look due to its lower light output (which I prefer). The difference in black level was not as great as I initially thought, as black gets washed out on both screens during medium to bright scenes, which leads me to believe that a grey negative gain screen may be my best bet moving forward. A previous poster mentioned that using a high gain screen like the Da-Lite would make artifacts more visible. Not sure what is meant by artifacts, but I do see dark bands on the middle of the Da-Lite on overly bright scenes, with a white field being the worst case scenario and some bright sparkle like things in the center of the screen.
This should make the Celexon the slam dunk winner right? Well, the Celexon's build quality is not as good as the Da-Lite. It is much more heavier to carry around. The size difference between the two is more noticeable than I thought because I can't get the picture to use up all of the Celexon's screen real estate, as I run out of room on the top and bottom but end up with a one inch gap each side. On the Da-Lite, I can dial the picture up to occupy the entire screen up to all four borders. Further, I can't get the right vertical edge of the image to line up exactly parallel to the right vertical border of the Celexon screen, with the top of the image being about half an inch closer to the border than the bottom inch.
I attempted to get a lower peak light output to 14ftl on the Da-Lite by lowering contrast to -15 using HDMI Standard. Is this an acceptable way to accomplish this? Or is the Da-Lite's peak light output floor limited to what I get with the iris fully closed and contrast at 0? Would switching to HDMI enhanced and lowering contrast help? I'm trying to make it dimmer but not squash my contrast ratio.
If the Da-Lite's floor is limited to simply closing down the iris, then I think I'm going to return both and just use my wall as a screen until I have my own place to able to hang a fixed screen. I found a 0.95 gain grey 92 inch fixed screen from Silver Ticket for $350 ($200 for 1.0 gain grey), which I think would provide much better performance the the two portable screen and better bang for my buck.
Thoughts?
post #2076 of 2095 Old 02-20-2017, 02:19 PM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
Thoughts?
Have you tried room treatment with black cloth on the side walls and part of the ceiling in front of the screen area? If you can hang curtain rods on the sides, it could make a huge difference. Just make sure that the black cloth is not reflective.
Regarding the screen, you need one that you can set up and take down, right? I'd look at Vutec or Draper. Both offer a variety of screen configurations. Arguably, both are considered a step up from Da-Lite (I'm not familiar with Celexon). I'm using a Vutec 110" "Bright White" (actually, it is 1.1 gain) in a room with light colored walls. It looks very good. A few years back I owned a Stewart Firehawk, an incredible screen but pricey at the time. Check this forums "Screens" section for other options.
Good Viewing,John G  JVC DLA-RS4810 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 disc player, Darbee Darblet, Onkyo TX-NR708 Receiver/Processor, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,  Adcom & Yamaha Amps
johng is offline
post #2077 of 2095 Old 02-20-2017, 02:44 PM
Quoted: 481 Post(s)
Liked: 273
The Draper 94 inch with contrast grey screen (0.8 gain) seems like my best bet. But the $600 price point is ridiculous. I'm sure these portable pull up screens are expensive due to their portability and convenience, but not sure if I want to spend that much on a temporary solution.
The Silver Ticket fixed screen only requires two screws on the wall for installation. I think I'm better off returning both portable screens, taking my chances and talking my landlord into letting me install it.
post #2078 of 2095 Old 02-20-2017, 02:48 PM
Liked: 342
In general, the on/off contrast ratio would be the same between different screens; i.e., their black levels would be directly proportional to their white levels.
Whatever effect the wall reflection has, should be proportional to the pattern being displayed; i.e., it may affect the WB but not the gamma.
An ALR screen may also help, depending on the direction of the reflection.
That is an acceptable way of reducing the brightness, although it will affect the on/off contrast ratio somewhat.
post #2079 of 2095 Old 02-20-2017, 03:06 PM
Quoted: 481 Post(s)
Liked: 273
Not sure if I understand this one. To me it seemed like it affected both, as I could never get WB close to being acceptable, with midrange being heavy on blue and high end (80 and 90) being high on red, low on blue. I used 30 and 80 IRE to calibrate the WB and could get one or the other perfectly flat but not both. Even if 80 was perfectly flat, 80 and 90 would always be heavy on red or blue and low on red or blue.
The gamma always being below 2.0, with it dipping down towards 1.5 as I increased stimulus tells me that the meter is picking up the reflected light that washes out my picture. Am I correct in this assumption?
If I were to use contrast as an additional way to lower brightness, would you suggest I use HDMI Standard or Enhanced? I noticed that with Enhanced, anything below 15 would make whiter than white show up on the pattern, with 16 being the value right before the pattern clips whites (17 and up clips). With HDMI on Standard, whiter than white would never show up, but clipping would occur on anything higher than 0.
I used contrast at 16, brightness at -7 and HDMI Enhanced with iris fully closed on the Celexon 1.3 gain and it looked superb (aside from blacks being washed out). I want to replicate this look on the 2.2 gain Da-Lite screen. On the Da-Lite, I had to lower contrast to about -20 on HDMI Standard to get around 13ftl light output, but the picture loses "pop" and seems dimmer than the Celexon. Is the low end white balance affected when using the contrast control to lower light output?
post #2080 of 2095 Old 02-20-2017, 03:43 PM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
$600 for a screen is a very competitive price. Most people will change their projectors 3-4 times while keeping the same screen. A strong argument can be made that investing in a good screen is a solid long-term investment. You've got an outstanding projector, but it needs a good screen, and in your case some room treatment, to make it really shine.
rhale64L7 and makaveddie81 like this.
johng is offline
post #2081 of 2095 Old 02-20-2017, 05:05 PM
Quoted: 481 Post(s)
Liked: 273
But I can probably get a better screen for that price in a fixed form factor or something that equals the performance of the portable screen at a fraction of the cost. I'd like to invest in a good, long term solution once I am able to install a fixed screen. The portable floor pull up is a tenporary solution in the interim.
I'm going to talk to my landlord first, and then take it from there.
post #2082 of 2095 Old 02-20-2017, 05:26 PM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
Good Idea. Hopefully he'll be OK with it. Yes, you pay a premium for portability, but portable screen's are not not usually Tensioned. They will develop ripples over time. I had a portable that claimed to be tensioned, but it really wasn't. Ripples in the screen material will drive you crazy. Look at the pricey electric roll down screens and you'll see that they use a 'tab tension' system to keep the material rigid.
johng is offline
post #2083 of 2095 Old 02-20-2017, 06:25 PM
Quoted: 481 Post(s)
Liked: 273
Agreed. Both these screens curve in a bit at the bottom corners and have minor waves.
I'd rather invest on a good quality fixed screen solution.
post #2084 of 2095 Old 02-20-2017, 09:23 PM
Liked: 342
What I meant to say, is that this kind of issue is unlikely caused by the screen, or the reflection from the walls. It's the projector itself that has the issue. You can confirm this by measuring off the projector lens, with the meter in the ambient light mode (diffuser on).
It's always a good idea to run a grey scale sweep before you adjust the WB. If the colours do not track linearly (e.g., if there's a hump in one of the colours), then you won't be able to correct the WB for the entire range using only the 2-pt control.
I don't believe so. The wall reflection affects the measurement by equal % for all levels of stimuli, and hence does not affect the gamma.
It should not. This can be easily confirmed by repeating grey scale sweeps at different contrast settings.
post #2085 of 2095 Old 02-21-2017, 12:40 PM
Quoted: 481 Post(s)
Liked: 273
No go with the landlord. But, I found the 92 inch Draper 0.8 gain with Contrast Grey screen for $426 shipped from B&H. They accepted the Da-Lite return and emailed me a pre-paid shipping label. The Celexon is already on its way to Amazon for a refund.
Thanks for recommending the Draper brand, as I wouldn't have found this screen without your advice. It's a special order item so it will take a couple of weeks to arrive at my doorstep. Expect an update at that time.
post #2086 of 2095 Old 02-21-2017, 12:53 PM
Quoted: 481 Post(s)
Liked: 273
OK. I'll try both of your suggestions later this week. Is there a 10 point control for WB? If so, how do I get to it?
I was under the impression that the reflected light from the wall gets brighter and more intense as the simuli being displayed on the screen is increased.
I just purchased a 0.8 gain grey screen, which will hopefully yield better results. I can definitely see the potential in this projector, just need to pair it with a screen that can mask some of the shortcomings in my room.
post #2087 of 2095 Old 02-21-2017, 01:06 PM
Liked: 342
The 10pt WB control is the same as the 10pt gamma control. It allows you to change R,G,B level at each of the 10 points (actually 12 points: 5, 10, 15, 20, 30, 40, 50, 60, 70, 80, 90, 95).
Yes, the amount of reflected light increases with the intensity of the stimuli - you can probably see the whole room lighting up on bright scenes. However, the percentage of the reflected light is independent of the stimuli, so that means the gamma is not affected.
post #2088 of 2095 Old 02-21-2017, 01:11 PM
Quoted: 481 Post(s)
Liked: 273
Off the top of your head, do you know how to get to the 12 point WB control? I can't seem to find it.
OK I get it now. And yes, my room lights up like a Christmas tree on bright scenes. It's as if someone turned the lights on.
post #2089 of 2095 Old 02-21-2017, 02:05 PM
Liked: 342
It's under Custom Gamma, page 41 of the manual.
post #2090 of 2095 Old 02-21-2017, 02:17 PM
Quoted: 481 Post(s)
Liked: 273
That looks like 12 point adjustment for gamma not white balance.
post #2091 of 2095 Old 02-21-2017, 02:41 PM
Liked: 342
As mentioned in my previous reply:
To adjust gamma (alone), use White or adjust R/G/B by the same amount. To adjust white balance, change only 1 or 2 of the 3 colours, just like the 2-pt controls.
post #2092 of 2095 Old 02-21-2017, 03:07 PM
Quoted: 481 Post(s)
Liked: 273
Ah, got it, thanks!
post #2093 of 2095 Old Yesterday, 12:42 PM
Quoted: 481 Post(s)
Liked: 273
Here's a (very late) update on my situation.
The 92 inch Draper Traveller 0.8 gain screen ended up being the best of the bunch. While my room still lights up and my blacks get killed during bright scenes, albeit not as bad as the other screens, the black level is perceptibly improved during medium to low APL scenes and the image has more of the dim plasma look that I prefer.
Would an Ambient Light Reflection screen reduce or eliminate the amount of light that reflects off the screen and lights up my room? Or is my situation with the surrounding light beige walls too extreme for an ALR screen to make a difference?
Though I haven't found any ALR portable screens, I'd like to know if it would be wise to invest in one once I'm able to install a screen on my wall and have more control over my room conditions.
post #2094 of 2095 Old Yesterday, 01:00 PM
DavidHir's Avatar
Liked: 1387
With light beige walls, it will be impossible to get very good results with any screen.
DavidHir is offline
post #2095 of 2095 Old Today, 05:47 AM
Liked: 342
This essentially confirmed the earlier discussion that a low gain screen would work best with light-coloured walls and ceiling.
As long as most of the room light (including reflection) is not coming in the same direction as the projector, an ALR screen should help. With the projector on and displaying some bright scenes, you can stand in front of the screen facing the projector (not looking into the lens, of course), and see which part of the room lights up the most from the screen reflection.
JVC DLA-RS4910
HCFR Bug List
Jvc , Jvc America , Jvc Dla Rs4810 3d Home Theater Projector
