Most Hours on JVC Lamp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 09-25-2012, 09:09 AM - Thread Starter
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
I would like to know who here has had or has the most hours on a JVC lamp before dimming/blowing to be unwatchable on 2D.
Curious from last years models and prior.
tigerfan33 is offline
post #2 of 17 Old 09-25-2012, 09:56 AM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
I am on my third bulb and never made it past 500 hours.
space2001 is offline
post #3 of 17 Old 09-25-2012, 10:19 AM
JeffY's Avatar
I'm still on my original HD750 (RS20) lamp which now has about 1200 hours on it.
JeffY is offline
post #4 of 17 Old 09-25-2012, 10:22 AM
GoCaboNow's Avatar
Quoted: 862 Post(s)
Liked: 757
RS10 and 1800 hours. Still plenty bright on my 133" highpower screen.
My Dedicated Home Theater Room
GoCaboNow is offline
post #5 of 17 Old 09-25-2012, 10:33 AM
Quoted: 423 Post(s)
Liked: 346
I have a bit over 1200 hours on my RS10. Still watchable on 92" 1.0 gain screen, but dim to a point that replacement would make a world of difference.
Balthazar2k4 is offline
post #6 of 17 Old 09-25-2012, 11:00 AM
space2001's Avatar
Quoted: 65 Post(s)
Liked: 37
Hehe should have been more specific on my end I have a JVC X3
post #7 of 17 Old 09-25-2012, 11:33 AM
dolphinc's Avatar
Quoted: 86 Post(s)
Liked: 63
I have 2 003 bulbs new in the box waitng so I may not know anything for quite sometime. Hopefully I can get 1000+ hrs out of the 003 bulbs.
dolphinc is offline
post #8 of 17 Old 09-25-2012, 12:06 PM
cuzed2's Avatar
Quoted: 187 Post(s)
Liked: 236
OK - I know I have an antique PJ, an RS-1
I have not yet blown any bulbs. My spare has 1600 hours, and the current one has just hit 2K hours.
I view in a bat cave -so still have plenty of light; to run for a record smile.gif
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #9 of 17 Old 09-25-2012, 06:33 PM
audiovideoholic's Avatar
Quoted: 588 Post(s)
Liked: 186
My original RS1x lamp has over 2000 hours on it and still bright enough to watch but is dim compared to new.
I just sent my 2nd lamp which had over 1500 hrs on it to a fellow AVSer to test his pj with that was still good but a tad dim as well.
audiovideoholic is offline
post #10 of 17 Old 09-25-2012, 06:44 PM
rav7ks's Avatar
I had 1100 hrs on the PJ and the bulb cracked. During the bulb change, I found some buildup of film on the reflective surface that was opposite the bulb. I gave the interior a good cleaning.
With the new bulb it's now bright like new.
Sony VW 665ES, Denon 4520ci, PSB Imagine T2, SVS SB13Ultra X 4
rav7ks is offline
post #11 of 17 Old 09-26-2012, 06:16 PM
Zip3kx07's Avatar
RS10 original lamp, short throw, 100" screen I made it to just over 4200 hours! on the lamp before blowing. lol biggrin.gif
No I'm not trolling 4200 hours!!! Serious
Ya...the picture was pretty dim after going over 3K but then the curiosity of how long can this thing last takes over. lol
Zip3kx07 is offline
post #12 of 17 Old 09-26-2012, 06:32 PM
mbw23air's Avatar
Quoted: 154 Post(s)
Liked: 141
Nice...What kind of material is your screen?? HP?
Mike
JVC RS600(Calibrated with Chromapure using an iD3), Stewart Cima Neve 2.35 115" diagonal screen, Lumagen Radiance XD, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, Roku 4, Panasonic UB-900 UHD blu-Ray player, HDFury
mbw23air is online now
post #13 of 17 Old 09-26-2012, 07:42 PM
Mike Garrett's Avatar
Quoted: 5562 Post(s)
Liked: 3542
450 hours on version 2 lamp. Still using normal (low) lamp mode with the iris closed down 3/4's of the way. Shooting onto a 9' wide 0.85 scope screen.
mjgarrett100@gmail.com
Mike Garrett is offline
post #14 of 17 Old 09-26-2012, 08:30 PM
Mr Ian B's Avatar
Quoted: 53 Post(s)
Liked: 46
I am on lamp 5, the most any has lasted was 975 hours.
Ian B
Mr Ian B is offline
post #15 of 17 Old 09-26-2012, 08:33 PM
Googer's Avatar
Quoted: 306 Post(s)
Liked: 264
I replaced my first RS20 bulb at around 3000 hours as I recall. It still wasn't unwatchably dim by any means (heck I was still using it in normal mode and not high, iris fully-open but still rather impressive IMO) but I decided to heed the PJ's advice to replace the bulb before the extended bulb warranty I'd bought expired (which since has but even getting just a single new bulb with it means it more than paid for itself tongue.gif). I'm up to around 1300 hours on bulb 2 and it's holding out just great at well to this point. Obviously for me to put this kind of usage on my PJ it gets a lot more use than just the occasional movie and indeed it's my primary display for all use - TV, gaming, etc. smile.gif
Googer is offline
post #16 of 17 Old 09-27-2012, 06:05 AM
Zip3kx07's Avatar
Mike
Seymour AV Center Stage XD 1.2 gain
Zip3kx07 is offline
post #17 of 17 Old 09-27-2012, 07:35 AM
Fatshaft's Avatar
Quoted: 590 Post(s)
Liked: 904
So from what I can tell so far the older RS models do well with bulb life vs. the newer RS model are pathetic?
I have 325 hours on my RS45 and it's plenty bright! I even watch 3D on Normal lamp...to afraid to try HIGH for fear of failure.
Not encouraging reading all this.
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
Jvc Dlahd750 200 Inches 1080p Front Projector Black , Jvc Dla Rs1 Projector , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
