Factory Reset on a Sony VPL-FH30/35 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-04-2012, 11:50 PM - Thread Starter
technicaldaniel's Avatar
Hi there,
So I have had some problems with getting into the network (web) config page of a Sony VPL-FH35 style projector as it requires a password that no one seems to remember (it was set a while back).
So my question is, is there anyway to factory reset the projector so all the settings will go back to their original defaults and I can get in under the default root account.
I have tried entering Service Mode on the projector but that has no options to reset the projector. I have also tried the RESET,RIGHT,LEFT,ENTER key sequence but that only reset the lamp counters.
Any help would be very much appreciated.
Thanks!!
technicaldaniel is offline
