Official Sony VPL-HW50ES Owners Thread - Page 122 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #3631 of 3635 Old 01-01-2016, 10:01 AM
booga24's Avatar
Quoted: 20 Post(s)
Liked: 42
Originally Posted by ltd76gold View Post
Was the 3rd OEM sony lamp in a Sony box? New and sealed? About $240? AFAIK, all Sony uses are Phillips 200 watt hpl lamps in the 30/50/55 es series.
Not a recommendation, but from serious purchase quantity for clients and then having little back flow, Pureland Supply (about $185) has the Phillips lamps mounted in the Sony housings and as long as the Phillips lamps are in there... Only the normal arc issues rectified by high/low settings, run well for extended periods.
I reiterate again, lamp hours are directly connected to power cycles. The more cycles, the less and from the sounds of it, more problematic (shorter/arcing) issues.
Doug k
So which are the best lamps out there? and where are you guys buying em?
booga24 is online now
post #3632 of 3635 Old 01-04-2016, 09:45 AM
Mikenificent1's Avatar
Quoted: 34 Post(s)
Doug k
My 3rd lamp is as you described FYI.
Mikenificent1 is offline
post #3633 of 3635 Old 01-04-2016, 10:19 AM
WilliamG's Avatar
Quoted: 51 Post(s)
Liked: 32
And my 50ES started flickering again last night. Had been several months of low-lamp perfection but it didn't last. Back to high lamp for a while I guess! At 1020 hours now.
WilliamG is offline
post #3634 of 3635 Old 01-28-2016, 12:00 AM
ltd76gold's Avatar
Quoted: 58 Post(s)
All projectors with UHP lamps will display arcing/flashing. Iirc, only Christie's for a time had a flicker mode that automatically tried to eliminate the visible pulsing of the lamps.
I have over 6000 hours on my original lamp and have found that with just a few presses of buttons on my remote, switching from high to low or versa takes but a few seconds.
Just for grins and because the apps are free.... Take a light reading in lux with your phone of a 100% white full screen pattern. Do it in high and low mode.
Using the camera pointed at the PJ from the screen, get a reading in lux
Lux/10.67 = FL with a zero gain screen.
This will give you a very accurate FL measurement.
While your 51+fl would indeed be too bright in a dark room, I sincerely question whether the PJ even with a brand new bulb would produce that level.
Just trying to help...
Doug k
ltd76gold is offline
Sony Vpl Hw50es 3d Projector
