Official Sony VPL-HW50ES Owners Thread - Page 55 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
Old 04-03-2013, 06:05 PM
xb1032's Avatar
Liked: 26
Originally Posted by Scott_R_K View Post
Hello all you lucky HW50 Owners . I'm looking to upgrade to this PJ fairly soon but I have a concern I haven't found answered in this
Thread yet . I would like to do the "Zoom" method for 2.35:1 but I'm worried how black the black bars will be when they're zoomed off
the main screen . I have black cloth walls behind my screen which also has a black border .
Would someone be willing to throw a 2.35:1 movie up in a 16:9 frame and then hold your hand in the light path for the black bars ?
Does your hand shadow appear darker than the black bars or can you not see the shadow of your hand ? (This would be good)
I'll assume you've all set up the Black and White levels already or even Calibrated the picture .
Also , while I'm here , is anyone using the Sony ImageDirector Software ?
Thanks in advance ,
I have a darkened room but I do have a Dalite HP screen and for reference I can see my hand fairly easily. For comparison, It's just as easy to see the black barks on my RS45 as well but the JVC's black bars are slightly darker. Hope that helps.
xb1032 is offline
Old 04-04-2013, 06:56 AM
Sona Kakoo's Avatar
Slightly darker probably because you have a darkened room + high gain screen...(with 1.0 gain + long throw, or if you don't have a dedicated room, it's a tie with rs46...)
scott is talking about black bars zoomed off the screen, i don't understand if he is using a 2.35 screen, or 16/9 ? and what is the "zoom method" exactly ?
Sona Kakoo is offline
Old 04-04-2013, 09:17 AM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Quote:"I'm doing this right now and have black velvet outside of my screen. With the lights off, can't even tell there are bars. Will try to grab some pics next time I fire it up."
Thanks blipszyc , that's encouraging ! Love to see some pics when you get a chance . smile.gif
Quote:"I have a darkened room but I do have a Dalite HP screen and for reference I can see my hand fairly easily. For comparison, It's just as easy to see the black barks on my RS45 as well but the JVC's black bars are slightly darker. Hope that helps."
Thanks also xb1032 . Not so encouraging . Are you doing the Zoom Method or using an A-Lens for Scope Films ?confused.gif
Quote:"scott is talking about black bars zoomed off the screen, i don't understand if he is using a 2.35 screen, or 16/9 ? and what is the "zoom method" exactly ?"
Yes , I have a 2.35:1 Scope Screen and have been using a very early Model of a Prismasonic A-Lens . I won't know if the A-Lens will work in front of the Sony until I pair the two together so I'm trying to find out if the Zoom Method will work as a backup . I think it should , depending on how black the black bars are when they're zoomed onto the trim .
Thanks for all the replies .
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
Old 04-04-2013, 10:21 AM
coderguy's Avatar
Quoted: 408 Post(s)
Liked: 315
If someone has the Sony s790 bluray player, can they compare the sharpening to the RC of the Sony hw50 and see how close the two are?
Some are claiming the s790 is VERY close to the same algorithm as the RC in the hw50.
"Thats because they dont call it reality creation on the s790. Its hidden in the custom picture setting 1 and 2. Its like reality creation, in 2 parts, First called texture remapping, and the second slider is called super resolution. I compared it to the RC on my sony HW50es projector and it does more or less the same thing. Makes cheap projectors such as the HD33 and W1070 a LOT better especially in 3D mode."
If someone can try the above, much appreciated. Otherwise, if someone is shopping for a new Bluray player, I can safely say that Sony's make good ones anyhow and the s790 might be a good choice. I've had LG's and Samsungs in the past constantly breaking and not reading disks well even with TINY scratches, whereas never had the issue with the Sonys.
Access HERE from this thread
coderguy is offline
Old 04-04-2013, 02:18 PM
Stretch002's Avatar
I just ordered an HW50ES and am super excited! It's my first projector and I can't wait! Any suggestions for setting it up? Anything in particular I should be wary of or change in the settings to start? My room is dark but I don't have complete light control (white ceiling) and will be using a 100" SI screen in Lunar Gray sitting 10' from the screen. Great stuff here in the owners thread! Thanks for helping me choose this projector with all of your stories and pictures.
Stretch002 is offline
Old 04-04-2013, 03:16 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
^^^^Turn off film mode!
jkasanic is offline
Old 04-04-2013, 04:20 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Originally Posted by Iam74Gibson View Post
Maybe one of you can answer a simple question that I cannot seem to find anywhere.. What is the distance between the feet? I will be shelf mounting mine when I get it and want to see what the minimum would be for a surface to set it on.
I too would like a Drawing of the VW50 for the exact same reason . I will be shelf mounting mine and there is nothing in the Manual , in any language , that shows this .
The JVC Manuals have this kind of detail but I've spent an hour with Google to no avail . Strange this isn't somewhere .
If anyone has access to a Drawing , please post it .
Scott..........
Old 04-04-2013, 06:05 PM
dannoooo's Avatar
Hey Scott
If you are talking about the adjustable feet on the bottom of the projector I measured it at
10 1/8 inches from outermost edge to outermost edge , or 9 3/8 center to center
Let me know if I can measure anything else for u
dannoooo is offline
Old 04-05-2013, 09:29 AM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Originally Posted by dannoooo View Post
Hey Scott
Excellent , thanks for doing this . I'm looking to shelf mount the PJ and was looking at something like this...
http://www.solutions-stores.ca/ecommerce/control/product/~category_id=030003001004/~product_id=SB003
The shelves are adjustable , wire mesh for ventilation , black finish and very stable actually . price isn't too bad .
To keep the PJ more stable all I have to do is add specific support for where the feet will sit . Easy !
Old 04-05-2013, 09:33 AM
plasmaowner's Avatar
Quoted: 39 Post(s)
plasmaowner is offline
Old 04-05-2013, 11:10 AM
Mariano's Avatar
Hi,
English is not my native language so please forgive mistakes.
I bought the sony hw50es a few weeks ago,
I am looking for a screen for my "family room" (ambient light),
What screen gain would you recommend?
diagonal screen: 110" (16:9)
throw distance: 420cm (13.9 ft)
40% video games, 40% watching 3D movies, 20% watching 2D movies or TV
Can you help me?
Thank you very much
Mariano
Mariano is offline
Old 04-05-2013, 01:20 PM
Quoted: 39 Post(s)
Originally Posted by Mariano View Post
Hi,
Can you help me?
Thank you very much
Mariano
You would be fine with a 1.0 gain screen at that throw distance and screen size. The Sony is very bright. Something like a 1.4 gain screen should give you plenty of brightness. IF you want ultra brightness and you can shelf mount the projector get yourself a HP screen from Da-Lite.
Old 04-05-2013, 02:53 PM
Mariano's Avatar
Infact, I'm undecided between 1.0 and 1.2.
Ciao
Mariano is offline
Old 04-05-2013, 03:18 PM
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 73
Ciao
In a room with ambient light, I would go with a 1.2 gain screen. While the HW50 is super bright already, age of the bulb will reduce that. Also, I believe it's better to adjust brightness down, if needed, rather than up.
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
Old 04-06-2013, 01:46 AM
Mariano's Avatar
After how many hours the lamp will reduce its brightness?
Now I am very undecided: some say 1.0, others 1.2.
Mariano is offline
Old 04-06-2013, 12:49 PM
Iam74Gibson's Avatar
Quoted: 27 Post(s)
This is what I use and it's a much cheaper option. Works great with my setup.
http://www.homedepot.com/p/t/202520616?catalogId=10053&langId=-1&keyword=shelf&storeId=10051&superSkuId=202858079&N=5yc1v&R=202520616#.UV78oqI4tDQ
I guess my shelf will be a little different than you guys :-) I am getting a custom piece of glass cut so it looks like the statue is just holding the projector ( a little glass may show)... I will be setting the table on a slab of Granite for stability...
http://iam74gibson.smugmug.com/Other/Camera-Awesome-Photos/i-GdHxQsS/0/XL/CA_04061314385239-XL.jpg
The table can hold 40 lbs. This glass on it now is about 20x20
I am doing the new theater in a Dragon theme.
Cheers
Iam74Gibson is offline
Old 04-06-2013, 03:59 PM
Sona Kakoo's Avatar
It's apparently turned off when you buy it now...mine was.
Some questions :
- Guys, do you see any changes when you move contrast enhancer from low to high ? I can't see anything (and just a little thing from off to low, is it normal ?
- are you using sharpness (default is minimum) ?
Thank you.
Old 04-07-2013, 12:08 PM
jimmy12's Avatar
I am just about to pull the trigger on a Sony HW50 and have two questions prior to doing so:
1-Pricing:
I would like to purchase this projector in Canada given that once you add in currency conversion, exchange rate, duty, taxes, cost of day trip, and have to have warranty work completed in the US, there is no incentive to purchase in the States. Is there any particular authorized Canadian retailer that you suggest I check out or anyone with pj upgraditis that is looking to sell? Pricing seems to be quite high at quebecacoustics and options for online Sony retailers in Canada appear to be very limited. Anything local is not competitive.
2-Blacks:
My only reason for purchasing this projector is to get rid of that washed out, flat, and gray look to very dark scenes that I have with my optoma hd8600, while still being able to game with it and enjoy sports on it. Will I continue to cringe every time a dimly lit, mostly black scene appears with this projector? I know it's not a jvc, but it needs to be a large step ahead of my optoma to make this upgrade worthwhile. The 'pro' reviewers seem to be very positive about the black level performance on the hw50 but I've read a few posts that sort of sound like this 'jvc kills the sony in black levels' or 'the blacks aren't great on the sony... but everything else is good'
Note that I will be at furthest throw possible on a 1.0 gain screen in a black velvet theater. I'm hoping the long throw helps with contrast and lowers that black floor even a bit further. Note also that there are no opportunities within any sort of reasonable distance for me to check this unit out in person, but oh how I wish there were.
jimmy12 is offline
Old 04-07-2013, 01:47 PM
KDH
KDH's Avatar
1-Pricing:
2-Blacks:
The blacks are great for me even a white screen and white walls. ON DARK secns blacks were very good.White screen white walls bright scens washed out and foggy at times. Black Diamond 1.4 wite walls and fantasic blacks, and pop bright or dim never any foggy look at all.
KDH is offline
Old 04-07-2013, 02:38 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
1-Pricing:
2-Blacks:
Sent you a PM.........
Old 04-07-2013, 03:35 PM
kaggy's Avatar
Quoted: 70 Post(s)
Liked: 29
Where are you guys ordering from? Looks like every reputable dealer in the US has stopped carrying this model including the Sony Store.
kaggy is offline
Old 04-07-2013, 03:53 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3446 Post(s)
Liked: 3415
That's news to me. Give us a call ! We have them !
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
Old 04-08-2013, 07:59 AM
dannoooo's Avatar
Can anyone suggest what 3d glasses they have been using with this projector, other than the sonys that it came with???
dannoooo is offline
Old 04-08-2013, 09:02 AM
Mikenificent1's Avatar
Quoted: 77 Post(s)
MonsterVision 3D. You don't have to worry about line of sight or IR synching issues, and you can tweak the shutter settings for better performance IMO.
Mikenificent1 is offline
Old 04-09-2013, 02:13 AM
tallnick's Avatar
The hw50 doesn't come with any 3d glasses here in nz. I'm going to get seven pairs of glasses eventually. So . . . The cheap ps3 ones or monstervision? Are the monster visions worth the 3x greater cost? Is the sync with the Sony glasses really that bad? People with experience please help.
tallnick is offline
Old 04-09-2013, 04:58 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
If you get the external emitter the sync issue goes away, i have not had any problems since i have been using it.This is with using the Sony glasses.
If you go with all monster vision 3d glasses it comes with an emitter so the sync issue will not be an issue. I actually use both glasses with my Sony 50es.I am thinking about some extra ps3 glasses for my guest,maybe i'll buy one pair and check them out.
buckley44 is offline
Old 04-09-2013, 05:25 AM
kaggy's Avatar
Quoted: 70 Post(s)
Liked: 29
Has anyone tried the new Xpand Lite glasses?
kaggy is offline
Old 04-09-2013, 11:11 AM
dannoooo's Avatar
Buckley
Are there different emitters depending upon which projector you have, or are they all the same?
also, are you able to use the MV3D glasses and the sony glasses at the same time?
dannoooo is offline
Old 04-10-2013, 05:09 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
Buckley
Yes i use the Sony glasses and the Monster glasses together, and they work fine. The Monster glasses come with their own emitter and you can change the delay and brightness on them which can help with any ghosting you may be seeing.The monster emitter will do nothing to the Sony glasses, it only works with my monster glasses.Yes there are different emitter depending on which projector you have,My dealer sent me one previously that did not work with the sony50, and then he sent me the TMR-PJ2 which works fine with my Sony 50.
Old 04-10-2013, 06:08 AM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Buckley
So the TMR-PJ2 emitter plugs directly into the projector and the Monster emitter needs it's own power source, correct?
jkasanic is offline
Sony Vpl Hw50es 3d Projector
