Official Sony VPL-HW50ES Owners Thread - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #2341 of 3692 Old 08-01-2013, 04:31 PM
kevini's Avatar
There are discrete Power codes for the Sony, I configured them in my URC remote. I would imagine Logitech would use them,
kevini is offline
post #2342 of 3692 Old 08-02-2013, 12:24 AM
Metabolic's Avatar
Not sure if this earlier post from Texas steve will help but just in case, here it is:
Originally Posted by Texas steve View Post
For those who have the HW50ES and are programming a universal remote  - attached are the dedicated HEX Codes (note this is for this mdl as well as others) directly from Sony.    Hope this helps.
I have not yet tested them with on my NEVO remote, but as they are from Sony Im sure they will work
hw50 IR Hex Codes.docx 16k .docx file
Metabolic is offline
post #2343 of 3692 Old 08-02-2013, 05:13 AM
cemo62's Avatar
Quoted: 48 Post(s)
friends for Sony HW50ES what setting do you suggest for Gamma Correction? off or others-2.4, gamma8, etc? (bluray content)
Thank you
cemo62 is offline
post #2344 of 3692 Old 08-02-2013, 05:27 AM
Andreas21's Avatar
Quoted: 1028 Post(s)
Liked: 666
It depends on you room, 2.2 for normal light rooms and 2.4 for batcaves. Of corse the best is to get the projector procalibrated as this includes gamma calibration.smile.gif
cemo62 likes this.
Regards
Andreas
My Homecinema
Calibration software: Lightspace and Calman. TPG: Murideo Fresco SIX-G
Meters: Klein K-10 A and Jeti 1501. THX II certified.
Andreas21 is offline
post #2345 of 3692 Old 08-02-2013, 07:25 AM
Texas steve's Avatar
I have now tested them and they work
Texas Steve
Texas steve is offline
post #2346 of 3692 Old 08-02-2013, 09:23 AM
mbuck's Avatar
Quoted: 23 Post(s)
Originally Posted by mlrtime3 View Post
Does anyone have a logitech harmony one with the HW50ES? I'm having a hard time getting the unit to power off with the 'double power off' feature.
I managed to program the remote to send power off twice however when I'm in an activity it seems to only send once. Otherwise can you turn off this 'feature' to prompt for power off?
mlr
I have the Harmony Ultimate (great remote and LOVE the Philips Hue control). At first the double power off worked, but once I added AppleTV it stopped working. My solution:
Teach the remote a new power off command and name it Power2, then go to Activities, select the Activity you want to modify, select Customize this Activity. Click on Activity shutdown commands and then tweak all you want.
Also contact Logitech, they have great (though not quick) support. They loaded a new command in for me, though after I had already figured it out.
mbuck is offline
post #2347 of 3692 Old 08-02-2013, 11:26 AM
mlrtime3's Avatar
Thanks for sending the discrete codes, is there a easy way to get them on the harmony or do I need to hack with the software or pass through another remote?
mlrtime3 is offline
post #2348 of 3692 Old 08-02-2013, 11:27 AM
mlrtime3's Avatar
I'll try this method as well. How did you contact Logitech, through email or support forums?
mlrtime3 is offline
post #2349 of 3692 Old 08-03-2013, 08:01 AM
scchang's Avatar
Are you saying that the new command is now part of the code library for the pj? In other words, when we add the device to our device list, it will now power off correctly?
scchang is offline
post #2350 of 3692 Old 08-03-2013, 11:19 AM
Done Deal DR's Avatar
Quoted: 94 Post(s)
Liked: 142
I think he's saying that he thought it the same power off command but named it differently so that Harmony would treat it as a different power off code.
Home Theater Build in Progress (Contemporary living room, Klipsch RF-7 II 5.2 audio, Sony VPL-HW50ES Projector, Da-Lite 16:9 159" HP, recessed Mid Atlantic rack, etc)
Done Deal DR is offline
post #2351 of 3692 Old 08-03-2013, 03:45 PM
ktoolsie's Avatar
Quoted: 27 Post(s)
My 50ES came in a couple of days ago. Unfortunately, my previous mount would not fit the Sony, so i can't ceiling mount until I can get a new mount. I had a quick look with it set up on a table. The image seemed to be at a slight roll angle, but it may have been the projector legs weren't all zeroed. Out of the box, the convergence wasn't great on a white grid test pattern. I did a quick panel adjustment - shifted red 5/4 clicks (V/H). Blue needed a couple clicks in each axis. Convergence is now very acceptable, I just hope there's no downside to using the panel shift.
This projector is very bright as most have said. It's noticeably brighter than my old Infocus 7210 (720P) ever was and that had a reputation as being a light cannon. It's also VERY quiet. even right behind it at High lamp setting it was inaudible. This will be a welcome improvement over the Infocus. I couldn't see any uniformity issues with all-white or all-black scenes, no hot corners as some have reported. Black levels were a huge improvement over my old DLP unit. I could only just barely make out the black bars on wide (2.35 aspect ratio) movies. The dynamic iris was imperceptible.
I watched some 2-D and the picture had a lot of pop. Significantly more so that the Infocus 7210. Those worried about losing the DLP pop, need not concern themselves. Colors seemed accurate so far but I will need to see some more demanding material before I can say anything definitive. Sharpness seemed fine and focus seemed pretty uniform. The picture was definitely sharper than I remember my old Infocus being (I haven't run it in 3 months) but I wouldn't say it blew it away, as far as sharpness specifically is concerned. DLP just tend to be very sharp, with the very defined pixel structure making them seemed even sharper still. Also, the Infocus was about $7K when first released, so one would assume a top quality lens was used. I also didn't see any drift in focus as the unit warmed up. When one add the increase in sharpness, extra pop, hugely improved black levels, richer colors and lack of noise, the Sony 2-D image was a huge jump up over the old Infocus, which probably should be expected given that the 7210 is 5 or 6 years old.
3-D was plenty bright. However the image seemed to lack some solidity. Brightly lit foreground images seemed to have a slight flicker. it was almost as if they disappeared for every 3rd or 4th frame (i'm sure they didn't - just trying to describe the perceived effect).
I had to pack everything up as my chairs were supposed to be delivered today (by 2 PM at the latest) and I needed to have my room empty so the delivery guys could set up my chairs without knocking over the new projector. 5:30 PM and not even a call, BAH!!!. I'll set everything back up again and play around some more in a bit.
ktoolsie is offline
post #2352 of 3692 Old 08-03-2013, 06:03 PM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3554
Give me a call and we can talk about what you need for the mount.
mjgarrett100@gmail.com
Mike Garrett is online now
post #2353 of 3692 Old 08-04-2013, 09:39 AM
sirjetblack's Avatar
Hi all ,
Taking the plunge n going to purchase the Sony hw50es very soon. Now I need help in which screen to buy. The three screens I'm considering are grandview , da-lite n draper.
The units will be installed in the basement with control lightening n light colour walls n ceiling.
Any advice will be greatly appreciated! Thanks!!!
sirjetblack is offline
post #2354 of 3692 Old 08-04-2013, 03:05 PM
mbuck's Avatar
Quoted: 23 Post(s)
Originally Posted by sirjetblack View Post
Hi all ,
I'm using a Dragonfly high contrast 110" and it is great!
mbuck is offline
post #2355 of 3692 Old 08-04-2013, 04:14 PM
neokeelo's Avatar
I got a dragon fly 120" 1.2 gain Matt White and am mounting the projector 16ft back. I will post my impressions and pictures later this week.
neokeelo is offline
post #2356 of 3692 Old 08-04-2013, 05:13 PM
cemo62's Avatar
Quoted: 48 Post(s)
Brothers for 3D Depth setting what do you suggest? 0(default)? or +1,2 -1,2?
cemo62 is offline
post #2357 of 3692 Old 08-04-2013, 09:31 PM
Quoted: 94 Post(s)
Liked: 142
0.
cemo62 likes this.
post #2358 of 3692 Old 08-05-2013, 08:56 PM
Linda's Avatar
My partner and I just bought a house that had a home theater in it. Though well maintained it was a roughly 13 year old InFocus projector that wasn't HD and didn't have any digital inputs. We decided on the hw50es and just received it today and all I can say is, WOW!
Though we've been home theater enthusiasts for years we've never had the room for a front projector and we were blown away with the image quality.
The existing screen is a 120" 4x3 screen. I don't know what it is except that it appears to be a roughly 1.0 gain white screen. We'd like to replace the screen with a 16:9 screen in the 120-130" range. I'll have to do some more precise measurements to see how much room our speakers will need. The room is light controlled. The existing paint is roughly equivalent in tone to a medium oak color. The ceiling is a darker brown but the carpet is fairly light colored. We can paint or use curtains to darken the room (eventually) and will eventually replace the carpet so the room will get even darker over time.
With the existing screen (probably being filled to the equivalent of a 100" 16:9 screen) the image is subjectively plenty bright (we're in the reference preset with the auto iris set to limited and low lamp mode).
My question for the group is in this environment, what screens should we be looking at? Most of our viewing will be 2D with the occasional 3D movie thrown in. The screen will be a fixed mount.
I see so much marketing hype it's hard to make any evaluations. I'd appreciate the collective experience of hw50 owners before plunking down some cash.
Linda is offline
post #2359 of 3692 Old 08-05-2013, 09:11 PM
Liked: 3554
post #2360 of 3692 Old 08-05-2013, 10:52 PM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 116
Good to see people getting their projectors. I'm really hoping mine ships this week.
- Klipsch RF-82 ii, RC-62 ii, RS-52 ii
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
baloo_btru is offline
post #2361 of 3692 Old 08-06-2013, 12:10 AM
vince325's Avatar
Hey guys If I remember in the shoot out thread someone mentioned about a setting up thread or a site you would recommend to help set up my screen and projector. I did go through 25 pages but didn't find it here's hopping for some help to a projector newbie. Im most concerned about the screen and projector being square to each other so any helpful hints would be much appreciated. Thanks in advance.
Thanks, Vince
Pioneer Kuro
Sony VPL-HW50
Marantz 8801
Oppo 103D
DirectV
XBOX 360
vince325 is offline
post #2362 of 3692 Old 08-06-2013, 12:25 AM
Quoted: 60 Post(s)
Placed an order for an HW50 today through AVS. Silly me, I hadn't gotten far enough into this or the shoot out thread to know that these babies are all back ordered. It was a bit uncertain to me how long I'm going to have to wait, since it sounds like the next shipment is already all spoken for. Anyone have any insight into how much time is passing between shipments? Patience is not my strong suit, and that Panny 8000 is cheaper and in stock...
tbacos is online now
post #2363 of 3692 Old 08-06-2013, 06:49 AM
Threefiddie's Avatar
Quoted: 247 Post(s)
Liked: 121
woot well that means I am not dead last on the waiting sheet anymore! Today makes a week since I put my order in, but considering how many were ahead of me I'm sure I still got a lot of wait left.
tbacos likes this.
** FOR SALE-Price reduced**Sony HW50ES + extra bulb + 5 pairs 3d glasses + Chief Mount **Click me**
Threefiddie is offline
post #2364 of 3692 Old 08-06-2013, 06:49 AM
Quoted: 247 Post(s)
Liked: 121
post #2365 of 3692 Old 08-06-2013, 08:07 AM
booga24's Avatar
Quoted: 20 Post(s)
Liked: 44
8 weeks today and still waiting.
booga24 is offline
post #2366 of 3692 Old 08-06-2013, 09:15 AM
Quoted: 247 Post(s)
Liked: 121
oh man... you gotta be like #1
post #2367 of 3692 Old 08-06-2013, 09:44 AM
booga24's Avatar
Quoted: 20 Post(s)
Liked: 44
I hope you right, patience is a ............
booga24 is offline
post #2368 of 3692 Old 08-06-2013, 11:15 AM
Linda's Avatar
Originally Posted by JacobC1983 View Post
I use a harmony touch and I didn't have to change anything for the projector to turn off - it automatically sends the signal correctly even though I have to press the power button twice with the HW50es remote.
We've only had our projector one day and so the Harmony One has only powered down once but it worked just fine for us. I briefly saw the message to press power again before the screen went dark and the projector went into standby.
Linda is offline
post #2369 of 3692 Old 08-06-2013, 11:43 AM
baloo_btru's Avatar
Quoted: 114 Post(s)
Liked: 116
I thought they got several in that had shipped? How has yours not shipped yet? I was promised end of July, then first week of August but haven't heard any update yet.
Mike said they should be here this week though so fingers crossed.
- Klipsch RW-12D
- Sony HW50es
- Firehawk G3
- Denon 2113
post #2370 of 3692 Old 08-06-2013, 01:48 PM
Steve Ruddy's Avatar
I'm 6 days behind you. What makes it so bad is that Sony has them in stock and told me they would ship me one overnight at their expense since I've been waiting so long. I would go for it but I don't want to pay msrp so I'm waiting for my backorder with AVS. This is what happens when a company wants to wear all the hats. Sony is giving priority to their retail customers and screwing their wholesale customers like AVS. Last I heard is Sony has said all wholesale backorders will be filled by August 10 which is kinda weird since that's a Sunday.
Steve Ruddy
Steve Ruddy is offline
Sony Vpl Hw50es 3d Projector
