JVC RS-45 Uniformity - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-18-2012, 01:48 PM - Thread Starter
Willard Claxton's Avatar
For a while now I've gone back and forth on the uniformity of my RS-45. At times it's seemed fine, at others it's annoyed me. I had an LCD a few years back that had pretty bad uniformity, and my RS-45 is certainly better than that. However, I have noticed when watching some black and white movies that the top 10-15% of the screen has a yellowish tint and the bottom 20-25% of the screen has a reddish tint. I used different sources to test uniformity; I tried calibrating it away; I tried repositioning my projector to minimize lens shift. None of these made much if any difference. I'm wondering what level of uniformity is considered acceptable, both by you guys and by (perhaps) JVC folk. I used the 100 IRE pattern located off the service menu to get the clearest idea of uniformity, and looking at it really makes me want to try to get a replacement. I've heard that uniformity is a bit of a crapshoot, and I'm hoping to roll the dice again and get a better score. Oh, metaphors. I've got to do something about this since I watch a fair number of black and white movies and I think that, if I do nothing, I'm going to end up watching them on my plasma (perfect uniformity). I'd honestly rather watch ANYTHING on my plasma than on this projector right now. It provides a great picture otherwise, and makes movies look miles more cinematic than anything I've seen before, but the uniformity is killing me.
Willard Claxton is offline
post #2 of 9 Old 10-18-2012, 01:51 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
As an owner of the RS-45, I will say my brightness uniformity isn't perfect, but I never noticed any color uniformity issues (the color looks fairly uniform).
If it is visible in B&W movies while watching and it quite obvious, I doubt JVC would have an issue handling it under the warranty. If it does bother you enough, I guess I would send it back.
Access HERE from this thread
coderguy is offline
post #3 of 9 Old 10-18-2012, 02:28 PM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
This might sound crazy, but try inverting the image by changing it to the ceiling mode. I know the image will be upside down, but check to see if the uniformity is improved. I remember reading that these projectors have some kind of in built uniformity correction, but it sometimes doesn't react correctly until the image is inverted. You can then change it back the right way to see if it is solved. If no change, then fair enough, but if it is improved when inverted and/or when you put it back the right way, then it might just be a matter of a latter firmware.
Sorry if I'm not explaining this very clearly, but I'm sure I've heard of this from one of the more experienced users.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #4 of 9 Old 10-18-2012, 03:09 PM
John Ballentine's Avatar
I watch numerous B&W films too. I'm watching the Universal Classic Monsters collection right now. The first thing I check on a new projector (after convergence) is uniformity (shading). On my Panny 700 (LCD) B&W films were virtually unwatchable due to shading issues. My RS1 was much better - but still no cigar. My RS20 was further improved in this area - but certainly not perfect. My RS35 has close to perfect shading (main reason I'll hang onto it for awhile). Previous to the RS1, calibrators like wm phelps were able to calibrate JVC projectors to absolute shading perfection (using look-up-tables). Not so now (bummer). So I agree it's a bit of a crap shoot (as is convergence). Funny. My Plasma has superb shading too (for whatever reason).
John Ballentine is offline
post #5 of 9 Old 10-23-2012, 08:41 PM - Thread Starter
coderguy,
Do you ever notice the lack of perfect brightness uniformity while watching something? I wonder because I'm not even sure how that would manifest itself. I've had projectors with shading problems, with banding, RBE, etc., but I'm not sure how suboptimal brightness uniformity shows up (if at all). My projector has "bright corners," and I notice that when the screen is entirely dark, but that's about it, and it doesn't really bother me at all.
Kelvin,
I tried what you describe and it does nothing, unfortunately.
post #6 of 9 Old 10-23-2012, 11:31 PM
coderguy's Avatar
Quoted: 291 Post(s)
Liked: 270
Willard - Same as you, just bright corners is what I meant to say. It's not a problem for me, when the projector was really bright at first and I was watching Tree of Life, I thought it could be, but I changed my mind once I got into a reasonable fL zone (like 14fL to 19fL)...
coderguy is offline
post #7 of 9 Old 10-24-2012, 10:47 AM - Thread Starter
All this leads me to believe that what I'm perceiving is a problem not related to brightness uniformity but shading and which affects only some units. I'm going to contact JVC the next couple days and see if they'll help me out. I've never heard of this being a fixable problem, so hopefully they'll get me a new unit.
John,
I also make a point of checking white field uniformity (shading) whenever I get a new tv/projector. I checked on this one as well, but I think two things kept me from noticing it at first. One is that, as I mentioned before, the shading on this projector is not as bad as it was on my LCD. I didn't see something like that, so I figured mine was fine. But more than anything I think the problem has to do with the fact that I checked this stuff when the projector was still warming up. When it's still warming up the problem is not nearly as noticeable as when it's been on a half hour, an hour, or more. It's not really even very noticeable at all in color films, it's only black and white films that are severely affected; unfortunately, I watch plenty of black and white films, so if I don't get this taken care of this will really drive me crazy. I imagine that some viewers wouldn't even perceive such a thing, but I'm very sensitive to this kind of thing.
post #8 of 9 Old 02-03-2013, 12:16 PM - Thread Starter
I know everybody was waiting with bated breath to find out what came of my interactions with JVC. Well, it took me a while longer than expected to send it in, due to both an injury I suffered and some misunderstanding of how exactly the shipping would work. It got sent in mid-December, and it took over a month to get the projector back. I was surprised to see that they did repair it, trading out the old lamp and optical block. Another interesting thing is that the UPS guy did not need my signature to leave the item. I guess a $3000+ projector is just not expensive or tempting enough to require a signature! The projector now has very minimal uniformity problems (it seems slightly more yellow in the upper-right corner, but it's pretty slight), but I now have the "smeared text" problem, or whatever it's called, which I've read about on this forum. I actually had to return the first unit I got because it had this problem quite bad; the second one didn't have that problem but had pretty bad uniformity. Now they've replaced some parts in the second unit, but it has the first problem again (though less severe). So I've spent several months calibrating projectors and switching out units...all to get a projector with marginally fewer problems than I first had. Any thoughts on what I should do here? It is less visible than with the first unit (that one was VERY visible), but it's not exactly invisible, either. The major impact is that it causes text/fine lines to appear fuzzier than they should, which is especially noticeable if moving much closer at all than where I normally sit. Although JVC did try to fix the projector, it took over a month, and I don't look forward to waiting so long to have this problem taken care of. From what I've read about the projector on here, and from my own experience, this doesn't seem to be an either-or proposition. It seems possible to get units without any such problems, so I'm right now planning on getting a different unit/additional repair and making sure that whatever gets replaced has neither uniformity nor "smearing" problems. But I'd appreciate any input from you guys on what you think.
post #9 of 9 Old 02-03-2013, 12:21 PM
Seegs108's Avatar
Quoted: 4198 Post(s)
Liked: 2088
That's horrible. If you have a warranty, use it. Otherwise you'll never be satisfied. I've been going through a similar process with Vivitek repairing a projector of mine. Though this week it SHOULD be shipped back to me. The end of this week will mark the one month point of them having it. I'm lucky though, I have two other projectors at my disposal so I'm not really missing out on much.
Like I said before keep exchanging until you are fully satisfied. It isn't your fault that these units keep having issues. I'm pretty sure UPS doesn't know whats in the box (or how expensive it is) unless the sender puts down a value for insurance purposes and on top of that the sender can waive the signature if he/she so chooses. Blame JVC not UPS. smile.gif
Seegs108 is offline
Jvc Dla Rs45 Home Theater Projector 1080p Hdmi
