Projector Mini-Shootout Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 4227Likes
post #361 of 17732 Old 10-30-2012, 02:42 AM
alebonau's Avatar
Quoted: 1373 Post(s)
Liked: 937
Hi, you didn't miss anything, I haven't had a chance to A/B the Sony / JVC in 2D mode yet, but will soon in a few days once this storm passed.
thanks. be very interesting how they compare. hoping your going to check out how they are 3D wise too ? I know the rs55 is average for 3D but wonder just how much better the sony is smile.gif
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #362 of 17732 Old 10-30-2012, 05:28 AM
audiohobbit's Avatar
Black uniformity was good on the preproduction sample I had. We saw no bright corners there. But I think not every unit will be that good here.
For me thats not a problem anyway. Normally you need some time to adapt to the dark screen before you see the bright corners. Most movies do not have totally black scenes for such a long time. Except 2001..
What concerned me more was the shading in grey pictures with that unit, it was blue-ish in the middle and reddish at the sides. I hope this will be better with the serial production units. However it was not visible in the movie scenes I watched.
@zombie:
I only measured the lumen output in 3D (uncorrected ~1064 at near shortest throw)
You measured this without the glasses I suppose?
@sarangiman: Those diagrams of the manufacturers for how the sequential 3D works usually refer to 60p material.
When you count 1/240, 3/240, 5/240 and so on, you get 120 Hz, this is for both eyes, so 60 Hz for one eye.
normally with 24p 3D material there is no pulldown, therefore the frequency per eye has to be an "integer multiple" (don't know if thats the right word) of 24 per eye.
Since those projectors can only show 120 different pictures per second, only 2*24 per eye is possible. Otherwise you would have a 24 Hz flicker per eye and this would be unwatchable.
So in my opinion with 24p material (without FI) it looks like this:
L1 - D - R1 - D - L1 - D - R1 - D - L2 - D - R2 - D - L2 - D - ....
(D: Dark, both shutters closed).
With that you have 48 Hz per eye and thats the flicker you see.
In digital cinema with Real D system they show every picture 3 times, known as triple flash, so thats 72 Hz per eye, and most people don't see flicker with that frequency. In total that's 144 Hz for the projector, but the LCOS and LCD home cinema projectors can't do that.
With the Sony a new image will be "drawn" on screen in a 1/240 s. Thats the dark pause and there both shutters must be closed.
Epson and Panasonic (using the Epson Panels) "draw" the new image in 1/480 s, so the dark pause is shorter, but only with this interlaced trick that only half of the lines are drawn in the dark pause and the rest of the image is added when one shutter is open again.
So I think because the dark pause is that short you don't see that much flicker with these LCD-panels.
With JVC it's a different thing. While Sonys SXRD- and the LCD-panels are driven analog, JVCs drives the panels digitally, so they don't have to "draw" a picture line by line but can adress all pixels at one time. At the JVC original glasses both shutters are never closed at the same time. The dark pause is only on screen, by switching all pixels to dark at the same time.
JVC claims that this causes less ghosting but at least until the newest generation the opposit was the case! Also many people saw more flicker with the JVC projectors in 3D than with other projectors.
Now looking again at the FI in 3D with the Sony: It has still 2 modes: low and high.
As I said (or supposed at least), by default every frame is doubled per eye so there is a chance to interpolate one of those frames for the FI. This is then the low-setting I think.
But where is the chance for the high-setting to interpolate more than one image then?
The only solution I find is that then there will be a 3:2 pulldown and each eye will have 60 Hz and the FI in high setting will smooth the judder.
But I'm absolutely not sure about that.
Interesting, you think the flicker in 3D is b/c of 48Hz frame doubled 24p material? In that case, if I turned off 1080/24p mode on my PS3 player itself, would flicker be better with the 60p signal?
I'm not sure if you can turn off 24p mode with 24p framepacked material from a 3D Bluray!?
Christian
audiohobbit is offline
post #363 of 17732 Old 10-30-2012, 09:47 AM
dagameballa's Avatar
Jason, any word on 5020 today or tomorrow? hopefully today!
dagameballa is offline
post #364 of 17732 Old 10-30-2012, 10:38 AM
fabrixce's Avatar
Can you guys recommend a screen to buy? I'm planning to get the JVC X55r and need to buy the screen but i have no idea which one. I will have a completely light controlled room and the projector will be shooting from 13ft. I can spend up to $800 and i'm looking for a 120" screen, i will mostly be watching 2D.
fabrixce is offline
post #365 of 17732 Old 10-30-2012, 11:44 AM
bass addict's Avatar
Quoted: 370 Post(s)
Liked: 446
If you have any fabrication skills at all you can build one for about half that amount.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #366 of 17732 Old 10-30-2012, 01:15 PM
fabrixce's Avatar
I don't my self but I know someone who can help me out. What would I need to buy?
fabrixce is offline
post #367 of 17732 Old 10-30-2012, 01:20 PM
Quoted: 370 Post(s)
Liked: 446
1x3 or 1x4 poplar, MDF trim, and some velvet. (A pneumatic stapler really helps too. biggrin.gif )
http://www.seymourav.com/screensDIY.asp
post #368 of 17732 Old 10-30-2012, 04:42 PM
mbw23air's Avatar
Quoted: 166 Post(s)
Liked: 155
Hey, don't take this the wrong way but this is not the appropriate thread to post what screen you should buy. You need to post in the screen forum. This thread is for the shoot out between the various projectors and should stay on topic.
Mike
JVC RS600(Fantastically calibrated by ChadB), Stewart Cima Neve 2.35 115" diagonal screen, Darbee Darblet, Denon AVR-X7200WA(7.6.4), M&K Speakers, 6 ported 18" subs powered by 3 inuke 6000dsps, 2 Behringer B1200D Mid Bass Modules, Buttkicker transducer, Oppo BDP-93 blu-ray player
mbw23air is offline
post #369 of 17732 Old 10-30-2012, 06:15 PM
fabrixce's Avatar
Mike
Sorry I guess... I'm interested only on the projectos in this shootout so I wanted to get opinions on screens good for these projectors. Thats why I posted here.
fabrixce is offline
post #370 of 17732 Old 10-30-2012, 06:16 PM
fabrixce's Avatar
Thank you Bass Addict...
fabrixce is offline
post #371 of 17732 Old 10-30-2012, 08:00 PM
gamemaster000's Avatar
This thread is dangerous... My wife just walked in and asked me why I was staring at Dwayne Johnson's chest! It's detailed! Honest!
Conrad
gamemaster000 is offline
post #372 of 17732 Old 10-30-2012, 09:56 PM
freebits's Avatar
Quoted: 39 Post(s)
Liked: 27
Yes! We need new screenshot like this.
freebits is online now
post #373 of 17732 Old 10-30-2012, 10:32 PM
filecat13's Avatar
Quoted: 41 Post(s)
Liked: 105
Yeah, it's great she still had lipstick, teeth whitener, and a razor to shave her armpits while her wet tank top fell apart. Too bad we couldn't see if she shaved her... Oops! Never mind.
On thread, will the new Mits HC8000 make it into the comparison? What's the word?
What I can afford, when I can afford it...
filecat13 is offline
post #374 of 17732 Old 10-31-2012, 04:17 AM
RickAVManiac's Avatar
Quoted: 206 Post(s)
Liked: 182
Pretty sure Zombie mention it will be include in the comparasion.
RickAVManiac is offline
post #375 of 17732 Old 10-31-2012, 01:35 PM
Quoted: 127 Post(s)
Liked: 49
zombie10k,
Any updates on the 5020.
jsil is offline
post #376 of 17732 Old 10-31-2012, 02:08 PM - Thread Starter
zombie10k's Avatar
Quoted: 3480 Post(s)
Liked: 3568
Originally Posted by jsil View Post
zombie10k,
Hi guys, sorry for the delay. I'm sure many of you have seen the damage from Hurricane Sandy, we have about 200,000 people without power in my town since Sunday. I am running off a Honda generator for essentials, but don't dare power my HT equipment as much as it's tempting.
I have the 5020 and will resume the shootout tests in a few days once our power is restored.
RE: HC8000 - we are definitely going to see the HC8000, i'm trying to find out the availability date. stayed tuned for more info.
zombie10k is offline
post #377 of 17732 Old 10-31-2012, 02:25 PM
Quoted: 127 Post(s)
Liked: 49
Hope you and your family are OK.
jsil is offline
post #378 of 17732 Old 10-31-2012, 02:30 PM
BrettJB's Avatar
I, for one, am delighted that posting to AVS is one of the "essentials"... tongue.gif
Glad to hear you were able to weather the storm - stay safe, and do what you gotta do first. As much as we don't like to admit it, the HT stuff can indeed wait until things are calm again.
--Brett
BrettJB is offline
post #379 of 17732 Old 10-31-2012, 03:23 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1012
Its a great Darblet test. Its not porn, she's dressed. There isn't a lot of contrast in the white tee shirt and the Darblet can resolve the threads as well as make the hidden part of the chest peaks have greater depth and realism. This is the AV Science Forum. Make the explanation scientific rather than biological and you will be cool. remember in HT, the only forbidden organic is in the panels.
mark haflich is offline
post #380 of 17732 Old 10-31-2012, 03:53 PM
xb1032's Avatar
Liked: 26
Hope you are doing well Zombie10k! Use that generator wisely!
We all are anxious to hear your results but we know there are more important things in life than watching video! Take care!
xb1032 is offline
post #381 of 17732 Old 10-31-2012, 04:08 PM
Wishing all goes well for you zombie!!!
post #382 of 17732 Old 10-31-2012, 04:54 PM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Lol u zombie probably had the whole street at his place watching movies.
I'm in Ohio and sandy hit pretty good here lots of power out and a lot of basements flooded
Holiday121 is offline
post #383 of 17732 Old 10-31-2012, 05:36 PM
gnolivos's Avatar
Quoted: 361 Post(s)
Liked: 285
zombie10k,
FYI, on the 5020 thread it was tested that lag on the 5020 model is AT LEAST 60ms. It is a definitive test with proof.
Setup: Epson 5040 UB, 110" SilverTicket AT screen, PS3 bluray, Yamaha RX-V673 AVR, Polk and Athena speakers, Batcave room.
The Moderno Theatre! Slideshow (here!)
Pixar screenplay slideshows here!
gnolivos is offline
post #384 of 17732 Old 11-01-2012, 12:02 AM
Holiday121's Avatar
Quoted: 575 Post(s)
Liked: 158
Aint that higher then last year
post #385 of 17732 Old 11-01-2012, 04:30 AM
DaGamePimp's Avatar
Quoted: 424 Post(s)
Liked: 458
No, the 5010 was around 80ms.
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro / Xbox One S / WiiU / PS3 / 360 / Wii / 1080TI game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #386 of 17732 Old 11-01-2012, 05:25 AM
SOWK's Avatar
Quoted: 506 Post(s)
Liked: 431
DaGamePimp, please get a cheap CRT to do lag tests.
How much lag does your laptop LCD have?
SOWK is offline
post #387 of 17732 Old 11-01-2012, 05:31 AM
freebits's Avatar
Quoted: 39 Post(s)
Liked: 27
Art almost completed his review on Epson 5020. It's interesting
http://www.projectorreviews.com/epson/home-cinema-5020/index.php
post #388 of 17732 Old 11-01-2012, 08:35 AM
Yeah, it's still missing a few pages..but what I read..is my same observation..3d brightness is no longer an issue!
post #389 of 17732 Old 11-01-2012, 08:45 AM
Quoted: 127 Post(s)
Liked: 49
You got the brightness for 3D, now what about 3D quality I didn't see that. I'll wait for zombie10k review.
jsil is offline
post #390 of 17732 Old 11-01-2012, 09:28 AM - Thread Starter
zombie10k's Avatar
Liked: 3568
Our power is back on, so I should be able to get some 5020 lag measurements and 3D lumens, but it won't be until after 10pm EST tonight.
Benq W7000 Home Projection System , Jvc Dla Rs55 Bundle , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson V11h502020 Powerlite Home Cinema 3020e 2d And 3d 1080p Wireless Home Theater Projector , Sony Vpl Hw50es 3d Projector , Epson 5010 Powerlite Home Cinema 3d Front Projector , Epson Powerlite Home Cinema 3010 2d And 3d Projector V11h421020 , Panasonic Ptae8000u Hd Projector , Mitsubishi Hc7900dw Home Theater 3d Projector , Mitsubishi Hc8000dbl Dlp 3d Home Theater Projector With Spare Lamp 1300 Ansi 12 6 Lbs , Darbeevision Darblet Hdmi Video Processor , Epson 5020ub Powerlite Home Cinema 3d Front Projector
